Windows
Thanks for your tip, I don't have a lot of faith in our local Skoda dealer. Which by the sounds of things is not unusual!!
Geobrett joined the community
Front consul bush which way do they fit Mk1 1.2htp
Hi Got to change my sons front consul bushes on his mk1 1.2htp and the old bushes are so worn so not sure which way new ones fit. I think the narrow slotted section in rubber is vertical and hex section has to be horizontal but they are offset so is it the narrower side or thicker side that is nearest engine. Photo from internet as example and his are about the same. Going to replace swing arms etc at same time. Using Febi reinforced bushes. Alasdair
Alasdair1 started following Front consul bush which way do they fit Mk1 1.2htp
Photography Thread
I like this one
Jamie1991 started following Cambelt / Timing Belt Quotes
Hi Posting for information as most of the posts I could see by searching for timing belt pricing were a few years old. Have received the following quotes in and around the Glasgow area over the past week. All quotes are for the timing belt and water pump on a Mk3 (2018) 2.0 TDi. All inclusive of parts and labour. Skoda Dealer: £990 (plus £110 extra for auxiliary belt) Local garage: £770 not incl. auxiliary belt VAG Independent: £800 incl. auxiliary belt Of course prices likely to depend on where you are / engine etc but significantly more than what seems to have been quoted a few years ago may give an idea to any prospective buyers or those planning ahead. I assume prices have just gone up over the years as all quotes are in the same / expected ballpark but if I'm being ripped off let me know!
- Loss of power, black smoke
Photography Thread
Roge joined the community
Exhaust Backbox
That’s great detail thanks @JR RS sounds like @tombee and I will get what we’re after from the kind offer from @travs !
Slartibartfast80 joined the community
Cleaning Veritate wheels
Much appreciated! I bought the extras expecting to screw up with the first or second attempt. This kind of thing is quite amusing. You pay a considerable pile of cash for what must be the most software complex car we've ever owned and.....I am buying a pack of three toothbrushes for £3 on my Tesco Clubcard to help clean the intricate wheels! It could be worse. Our RR Velar cost us £71k back in 2017 and I found myself stuffing pipe insulation to pack out the tension for the driver's window to stop it rattling - one if several DIY fixes. Whether its been the Mercedes, the Volvo x 2 or our earlier Ford Galaxy..... DIY, John Bull solutions have had their place! I'll post a photo of my remodelling attempt later in the week when I get some time to do this. Thanks again for the suggestion. Best wishes.
Exhaust Backbox
This type of rear diffuser, known as the Sportline diffuser does not come with exhaust cutouts. It comes with or without towball cutouts, and it comes in chrome or black trims. I changed my basic non-Sportline diffuser with no exhaust cutout on my 220 to a Sportline diffuser with no exhaust cutout, bout 7 yrs ago. The Sportline 280 4x4 and non-Sportline 4x4 both get a different diffuser, which has the exhaust cutout. They don't get a Sportline diffuser. Also, it's the same diffuser regardless of wagon or sedan. The bumper itself though IS different between wagon and sedan.
MK4 2021 Octavia RS back climate control rattle/buzz noise
Hello everyone! I am long time lurker, this is my first post. I own a 2021 MK4 Skoda Octavia RS and I love it, but some things are annoying my autistic brain, mainly - rattles and interior random noises XD But ok, I managed to identify main culprits and solve the issues to somewhat satisfactory extend, but one kept on bugging me, until my buddy finally identified the culprit: the back seats vent controls. At higher speeds on highways (which are fairly good in Croatia, regarding the surface quality) this thing produces a high pitched rattle/buzzing noise, it is kinda hard to describe it, but imagine having a coin on a metal surface that is vibrating at high frequency. So he identified it and moved it and then it stopped. Then I tried it the next day and it worked, but I can't find a permanent solution, so I am asking you if anyone has any ideas? I do have felt tape, silicone spray and white grease spray (lithium grease), should I perhaps first try with small amounts of grease on the plastic joints and contact areas? Thanks,
Frlja started following MK4 2021 Octavia RS back climate control rattle/buzz noise
Martin088 joined the community
Bodzio joined the community
- No crank no start
Amazed Skoda has become so BAD..
Unforunately the car developed electrical faults, Map detail disaappearing with an image of a car in a blank screen, an intermittent warning the active sign recognition wasn't working, a booming/resonance in the cabin plus others. Took it back and rejected it under the Consumer Rights act on monday 5 oct. After my Superb it was a disapointment.
- Yesterday
- 38 mph in 5th gear ?
- Noob!
No crank no start
No clicks when it played up for me. It clicked when starting normally. I tried x5 times taking key out and using spare I had with me, adjusted steering wheel height and tapped it in case of ignition barrel fault. Previous time was 2 weeks ago for wife. She rattled gear stick and then it started. Of course the gearbox mechanism is inches from starter. I had previously duct taped that red trigger wire as it felt insecure, loose. I had to cut duct tape carefully and cable was still attached to started flat terminal pin. Only after checking trigger wire and tapping starter did car start on next try. I cleaned all earth points afterwards With neg on battery disconnected and they weren't too bad. The positive wire that is braided and part of solenoid on starter was a bit green. The Bosch starter has a different starter sound to the valeo. I don't like it but if the car starts... I've tried starting x4 times and it hasn't failed to start. The starter is attached with X2 18mm bolts with X2 13mm nuts for earth or for a bracket. Also another 13mm for live big current connector. I'll see how it goes over next week, if it fails to start then it will be ignition barrel which is a job I've not done. The cruise control has broke and brought up a code a few months ago, it was never good on setting speed since I bought the car.
JAK joined the community
You can use a bowl of hot water as an alternative for softening the plastic if Mrs A won't part with her hairdryer. Soak the brush for a few seconds in the water to warm it. Once the plastic is warmed by either method, apply firm but even pressure to bend it. You should be able to feel it moving - it's a bit like very thick toffee - and also when it starts to cool and stiffen, and becomes brittle again. You may need two or three goes to get each of the bends fully formed. I'm looking forward to seeing some photos of the finished product 😄
ropie joined the community
amirul91 started following Skoda Octavia Mk2 (2004 - 2013)
Nottslan Yes. my car was new with 5 miles on the clock.
- OEM+ android auto options
New car
Apologies for the late reply. Glow plugs: in order to stop them seizing and being difficult to remove (rounded heads, seizing, snapping), I suggest replacing them every 7 years. If the head rounds, I suggest leaving it in place and not trying to extract it; the engine will start OK on the remaining glow plugs, but obviously more might fail. They are not expensive and easy to remove if not stubborn/seized. Injectors: new OEM injectors are good for about 120 - 130K miles. Reconditioned ones last about 20K miles. When one injector fails, the rest also fail within about 10 - 15K miles. Genuine, new OEM injectors are expensive. Other forum members may have different views on the above.
cbzbfailure joined the community
7heob joined the community
200ps Diesel vs 190ps Petrol - Superb mk3 facelift post 2021
Hello, I got myself a 200ps tdi at the beginning of this year and so far I don't regret it one bit, but then again I haven't tried the 280 or 190 tsi-s. It replaced my previous 150ps tsi Octavia which I also loved, but this car had most of the bells and whistles I'd dreamed of and more power than the previous so not going to tempt myself with the tsi-s for quite a while. In regards to driving, it's my first automatic diesel and to me the throttle response on the regular "D" profile felt a bit sluggish, since I don't like to drive in "Sport" mode all the time like some people suggest. I got around that by reading the forum and doing a suggested adaptation to change the throttle response profile from "Incremental" to "Direct" and for me at least that improved the feel quite a bit. I don't know the difference in 0-60 for the 200ps tdi and 190ps tsi but I can say that you'll certainly feel the difference in power from your current 150ps, I certainly did and it hasn't left me wanting, I've had no problems passing other cars even when fully loaded. When doing research before committing to my car I found a reddit thread when googling, you'll find it with the name "VW EA288 2.0 TDI things to know before buying" and that gave me some good hints on what to check. Go take both the 200 and 190 for a stroll and who knows, maybe you'll favour one more than the other, making this an easy choice for you Best of luck on your car search!
M4keSh1ft started following 200ps Diesel vs 190ps Petrol - Superb mk3 facelift post 2021
Noob!
- Coilovers suggestions?
Hello Evolution13! Thank you for the reply! I did not know there was a search for this forum and I thank you for the guidance for what sections to look into. Kind regards, Boifreson.marbrifox joined the community- Advice on/Experience with engine replacement 2.0 TDi
No worries. I sourced it from http://www.vangilsautomotive.nl/ via https://www.proxyparts.com Searched for the engine by engine code. Did the work with a friend of mine, so a big savings.- OEM+ android auto options
- Cleaning Veritate wheels
Monday's little purchase from Tesco. Every little helps! Just need to ask Mrs A for access to her beloved hairdryer, set heat to max and try my hand at the adaptation! - Coilovers suggestions?
