Radio replacement options.
I'm aware Chinese units are not the best but tbh I don't want to pay Skoda prices to have it fixed and also don't really want to pay 300 quid for a repair to my unit, or even finding someone who will repair it for less and maybe still have issues down the line. I just want to be able to listen to music again with out distortion and I'm not likely to be keeping the car that much longer anyway.
- Columbus Map Update 2026-2027 (MIB2 HIGH)
Electronic boot struts
Do you have any pictures of the installation? That would be very helpful to me. Did you simply unplug the old ones and install the new ones?
Why nobody mention new P470 maps? https://navigation-maps.volkswagen.com/vw-maps/Update_25_26/P470_N60S5MIBH3_EU.7z DBInfo.txt: PartNumber1="V03959803AC" PartNumber2="V03959828PT" PartNumber3="V03959828QB" PartNumber4="V03959822PE" PartNumber7="V03959817LC" PartNumber5="V03959804QS" ApplicationSoftwareVersionNumber="0470" SystemName="ECE 2027 " Variant="ECE" ReleaseName="2027" DevVersion="P470_N60S5MIBH3_EU_NT_Q1.26"content.pkg: "FSC": "02300040,09300002,08300002,07300040,06300040,03300040"Working in Audi:
mrfix started following Columbus Map Update 2026-2027 (MIB2 HIGH)
0v3rl0rd joined the community
BlueDun started following What are they?
What are they?
Can anyone tell me what the two short metal pipes (with S bends in) coming out from the rear of the engine tray are please?
Towing experiences with Octavia
I suspect AI is no more sure what the Auto Box service regime is from Skoda / VW than the Main Dealers Service desk staff are.
How to: Travel Assist and Heated Steering Wheel Retrofit
My most recent tow for long distances in the UK was a Shetland 5.4 metre outboard cruiser on a single-axle tilter - never put on a weighbridge but wet weight was almost certainly a 'bit' over the unbraked limit! Boat was used for cross-channel cruises and long-coastal around Southern England, so usually carried fuel for around 70-100 miles. Tow vehicles with that boat were 2.0L Volvo 360, then a 2.2L Vauxhall - both N.A and with lower HP/Torque than the Octavia, hardly felt the weight with either.
Octavia9099 started following SashaGrace
Should I Choose an Octavia?
Bought a 2020 Octavia MK4 in October 2024. Until May 2025, I had almost no problem. Very comfortable car, nice driving experience. But with the arrival of hot weather, the infotainment started switching itself on and off even when the car was locked, and that made my battery go flat. To this day, still no definitive solution, just endless updates. So my solution was to unplug the fuse each time I leave the car for longer than a few hours. Also, problem with the volume that kept turning up; very annoying. I live in Belgium and the dealership wasn't willing to replace the unit (will be done on September 11th) and didn't take into consideration the endless videos I took of this problem, until they saw it themselves. Maybe you won't have my problems, really rooting for you, because it is a beautiful, spacious, really the car of my dreams when it came off the production line back in 2020. But my next car won't definitely be anything produced by Volkswagen given the ignorance I witnessed. Have a great day, friend
mihai23 started following Should I Choose an Octavia?
Bought the ones on the link below. Was a voucher off them last week. Att photo of the damaged wires below. Probably an easy fix but don’t have any soldering equipment, or skill! https://ebay.io/m/mo0nOh
So the OEM ones I ordered never came through off eBay so just bought some generic ones from There. About £45 for one. Very easy job to swap old one out and this one in. Did panic that I hadn’t disconnected the battery first in case it messed with the programming but think as one still connected it was fine. Now works like a charm. Inspecting the old one you can see at least 2 of the wires had snapped due to the play in that junction. In hindsight probably could have connected them again but felt they would be weak still. If you pull back the rubber grommet attaching ti the metal Body you should see if any issues on these wires
Mine have just decided to stop opening and just bleep at me instead. Any ideas what might be the issue? Were working fine yesterday..
keajra joined the community
Fuel Tank Cap Replacement Seal
I was in my local Skoda dealership to collect a new Lambda connectors mounting bracket as I broke a tang on my wife’s 2015 VW Polo 1.2TSI while replacing the post cat probe - so I just opened my wallet and bought a new filler cap seal. The parts guy said that this seal does not move quickly - the one that I bought had been waiting to get bought for about a year!
My first Skoda
Hi Dave and welcome, it would be interesting to hear your comparisons between the two when you have had it a while.
minsy started following My first Skoda
Felicia PickUp speedometer drive
The links were to search the matter deeper. You already have the parts code to look in e-shops even for used parts,best of luck. 😉
Roof Bars/Rails on a MK1 Fabia Classic Estate!!!
From memory on my folks old mk1 estate there were captive nuts under rubber trim. Problem may be getting second hand rails. Couple breaking on ebay. https://www.ebay.co.uk/itm/226402866561?fits=Car+Make%3ASkoda%7CPlat_Gen%3AMK+I%7CModel%3AFabia&_skw=skoda+fabia+mk1+estate+breaking&itmmeta=01M22N4AYK6BF9TZ5QQFGWVBS2&hash=item34b6a99581:g:m5AAAOSwoktnDzfF&itmprp=enc%3AAQALAAABAGfYFPkwiKCW4ZNSs2u11xDjEtQFMEhSDtgDDQhh%2FR%2BKn7twjgzNQl35XX%2FAXNZZTOBwJNrhjpi%2FFI%2F1%2BpIz%2FOEUM6fRBj2OKLAzlhNOQxqJD4GhH2VnbHuz78IRFlO8Q1rmjug7JPg%2BhHFtq15ym89Yoiku%2Bzd5PnWazUpbhyK7Wqu6KbA3w4QZFw289RhSfxp2iUAD7K8nQw8N6sWvDKnBfneRr7XlMH%2B4%2Fu0yQQBviHqQGccz8Yry0vx3bY%2FsKIsPbEV7RojU0IxMb%2FZ4XQ%2FmOm4dawS3iA0XKsNqKOF2%2FBbCfPO%2Buh0SjNJubdNjItE1J4Ds2tPsIEYH%2FdPbNuY%3D%7Ctkp%3ABk9SR8SvkdWQaA https://www.ebay.co.uk/itm/256686877910?_skw=skoda+fabia+mk1+estate+breaking&itmmeta=01M22N4AYKV8DN80FXPK91VZ56&hash=item3bc3baecd6:g:CgAAAOSwT5dnGQTv&itmprp=enc%3AAQALAAABAGfYFPkwiKCW4ZNSs2u11xDgMrnePzINnqFd0NCA2u2Ojg9jTP5EjLUrr525QMq8azqsZKU16zpOQobx2rM1%2FXtSGm%2BS9FUDtF2SaAMF34WdlZb5VBfoL1xVgrvxMcorEWj9Rr%2BU7fSOx7wUkRbTUUNTwhO7j5ErCh%2FTzmB%2F9Zl2JlfSqgf77T%2FTFaHkS7NkN%2FjmD2e0pelo2KiN2eyS2OjrpkyFd%2BNxdDraS5UxYJKqZfKSEx0x94L3Pkx2Be0ThKVdZhskE%2BVOU8rcpw1X1YbmR7WsSa9v50EToXGxsfHbb8kN%2FyT1ZPlOJH3Ud%2FX1qs%2BmaNIf2opXTTUpemFw%2BUY%3D%7Ctkp%3ABk9SR8avkdWQaA Alasdair
Alasdair1 started following Roof Bars/Rails on a MK1 Fabia Classic Estate!!!
Sychev joined the community
Rear light bulbs
The rear lights of Skoda Fabia Mk4 cars can be 'all LEDs' or be a mix of LEDS and conventional bulbs. This 2023 forum enquiry was about the latter type. https://www.briskoda.net/forums/topic/513749-rear-light-bulbs-for-mk4-fabia/#comment-5760144 and (for right-hand-drive models) the 'mix' is as shown below, with the outer light-units having bulbs, while LEDs are used in the two number-plate light-units and (on the right side of the hatch) in the fog=light/reversing-light unit. The light-unit on the left side of the hatch is a dummy and has no LEDs in it. Left-hand-drive models will have a LED fog=light/reversing-light unit on the left side of the hatch and the light-unit on the right side of the hatch will be a dummy. with no LEDs in it. The bulb-changing guidance in the Fabia Owner's Manual is fairly good and the types of bulb involved are shown in the image below Gaining access to the bulbs should be straightforward. Pull off the black plastic cover that's next to the light-unit; remove the two T25-head retaining screws; pull the light-unit straight backwards. There's a small plastic ball (purple ringed on the image) that engages with a small plastic socket in the bodywork and a small amount of force may be needed to get the ball to disengage. The Manual suggests that the light-unit be disconnected, but that should not be necessary just to change a bulb. I found that removing the P21W (brake light) and WY16W (indicator light) bulb-holders was easy, but removing the W5W (tail light) bulb-holder was fiddly. The P21W and W5W bulbs were OSRAM-marked and I assume that the amber WY16W bulb. was also an OSRAM product.
- no live maps
For basic functions they are ok but : random crashes horrible phone call quality => so AA or carplay unusable by voice as the unit does not understand anything USB wire has to be split and rewired as it is wired for the power of the MK2 no more car diagnostics so so steering wheel controls Hit or miss drive mode showing on the screen (depends on the brand => EBILAEN shows it) I tried 3 of theme before upgrading to MIB2. If you can live the flaws, they are ok but if the mentionned is important, stay away
williamming005 joined the community
Suspension upgrade installed
Cheers for the update and sorry to see all the parts are failing because of it but yours was the testament that was defying everyone else’s (and giving me hope I wouldn’t have to **** around returning mine). Gone with @JR RS ’s suggestion although Delphi were out of stock so KYB variants on their way.
My first car! Skoda Fabia Mk2 SE 12v (CGPA Engine, 2014) keep it in good condition or save the money?
Before dabbing paint on rust spots, dab 'Rust Converter' on them and let it act / react.
MikeTheThinker started following Roof Bars/Rails on a MK1 Fabia Classic Estate!!!
no live maps
If you mean the infotainment screen then yes.
sussamb started following no live maps
- Optimal place for a subwoofer amp remote wire location
mine is a 2025 2.0TDI DSG estate and I pull a Mayland Mariner with alot of water trapped in the floor! You have a"slushbox" which is great for edging forwards (compared with my DSG which has to engage a clutch each time it edges forwards in traffic), but heat buildup on long inclines would be your issue. I am sure the basic "OBDeleven 3" would give you your gearbox temperature, but you'd need to test it beforehand on the same hills to know whats normal, and find out the temp thresholds for your model of gearbox. The max temp is to do with the max temp the transmission oil can handle. I think on some slushboxes the final drive (top gear) is a locked up gear and this is the one you want engaged as much as possible on the motorway to reduce hydraulic heat buildup (ie. gives it the chance to cool down after an incline). Bear in mind that the "towing prep" at the factory is the installation of the "J345 Trailer Control Module" (in the case of my car). This changes software mappings in the engine/gearbox and the car can reverse without it thinking it is about to hit a trailer...
