  2. A sad update on this issue, after being with the mechanic for over a week, having an engine flush and oil change it appears that something under the cam cover is the cause of the ticking, potentially caused by hydro locking when the injector failed. I am going to try and get a second opinion before condemning it but it is starting to look like the end of the road for my MKIII Estate.
  3. Yes, it’s normal for the MIB3 system that data is no longer stored in plain text. The "navigation unavailable" error indicates a discrepancy between the EEPROM and the eMMC. Have you tried a forced reboot? You can patch software version 0324 yourself via USB, but you will need a diagnostic tool.
  4. Today
  5. Hi there! Of course I'm here because of my 2021 Octavia's infotainment system has the same weird behavior described in this topic. On yesterday I was at Skoda Service and they updated the software version to 1989. And of course it did not get resolved. On some reddit an user posted a video where he solved this issue by unmounting and replacing the sticky link below the volume bar (@mods: can I put the link to both reddit and the video here?). Just wanted to ask if someone here knows about and tried his procedure (and, of course, if it works). Thank you all, Max
  6. Lee01 replied to meee's topic in Hellos and Goodbyes
    Welcome to Briskoda 👋
  7. meee posted a topic in Hellos and Goodbyes
    Hi there 👋 I'm from Italy and joined because of my Octavia's infotainment weird behavior... 😅 Despite this, just love the car! 😍 Cheers! Max
  8. meee joined the community
  9. Source: OBDeleven screen recording dated 17 November 2026 (75.67 s). The parameters visible on screen have been transcribed in the order in which they appear. Where a field is marked “[truncated]”, the app displays only the beginning of a multi-part value. Missing portions have not been reconstructed. Header and long coding • Saved backup name: “All control units” (original: “Wszystkie jednostki sterujące”) • Backup date: 2026-11-17, 11:18 • Odometer reading: 199735 km • Module: Multifunction Module • Long coding (60 HEX characters): 000000020100066A00003F00000000000000000000000000000000000000 Adaptation – 16 channels |Channel|HEX value | |-------|--------------------------------| |2306 |62090200 | |11543 |622D1700 | |11561 |622D2900 | |11542 |622D1601 | |11558 |622D2601 | |11583 |622D3F64 | |11584 |622D4000 | |11617 |622D61000000000000 | |11618 |622D62000000000000 | |1278 |6204FE000000 | |1276 |6204FC000000 | |1296 |62051000 | |2778 |620ADA1E1E1E32323232324B4B5050| |1297 |62051100 | |1298 |62051200 | |1187 |6204A303 | Live parameters / measured values |No.|Parameter |Reading | |--:|------------------------------------------------------------------|-----------------------------------------------------------------------------------------------------------------------| |1 |Output test status |Inactive | |2 |Basic settings status |Inactive | |3 |Security Access: number of invalid keys |0 | |4 |Terminal 30 voltage |12.1 V | |5 |Engine stopped by start-stop function |OFF | |6 |Engine started by start-stop function |OFF | |7 |Terminal 15 status via CAN bus |ON | |8 |Engine status |OFF | |9 |Number of unplanned control-module resets |Watchdog Reset: 0 | |10 |Multifunction Module Application Software Version |Version Routing FCM: 7160; Software Version AFS/MXB: 0065 | |11 |Processor utilization |Total system FCM: 24%; Software component AFS MXB: 13% | |12 |Predictive Route Data Street Class |Not available | |13 |Predictive Route Data Number Of Lanes |Not available | |14 |Predictive Route Data Speed Limit |Not available | |15 |Predictive Route Data Placename Sign |Not available | |16 |Predictive Route Data Intown Flag |Not available | |17 |Headlight levelling control state |Static | |18 |Left dynamic cornering light value |Fault | |19 |Right dynamic cornering light value |Fault | |20 |Front left suspension height sensor, learned value (zero position)|-0.01 % | |21 |Rear left suspension height sensor, learned value (zero position) |46.00 % | |22 |Driving profile selection |Specified value: 0; Actual value: 0; System status: Not available; Compatibility: Yes; Switching p… [truncated] | |23 |High beam |OFF | |24 |Reverse gear status |OFF | |25 |Turn signals |Not activated | |26 |ESP intervention |Inactive | |27 |Ambient brightness |1890 lx | |28 |Low beam |OFF | |29 |Vehicle speed |0.0 km/h | |30 |Steering angle |1.20 ° | |31 |Front body deflection |0.0 mm | |32 |Rear body deflection |-17.2 mm | |33 |Left headlight range control adjustment motor, status |No fault | |34 |Right headlight range control adjustment motor, status |No fault | |35 |Left dynamic cornering light adjustment motor, specified value |32.000000 ° | |36 |Right dynamic cornering light adjustment motor, specified value |32.000000 ° | |37 |Left dynamic cornering light adjustment motor, status |No fault | |38 |Right dynamic cornering light adjustment motor, status |No fault | |39 |Variable lighting adjustment motor, front left, status |No fault | |40 |Variable lighting adjustment motor, front right, status |No fault | |41 |Left headlight range control adjustment motor, specified value |1024.0 mm | |42 |Right headlight range control adjustment motor, specified value |1024.0 mm | |43 |Switching from left-hand to right-hand traffic |OFF | |44 |Dynamic cornering lights |OFF | |45 |Front left suspension height sensor |-0.01 % | |46 |Rear left suspension height sensor |42.40 % | |47 |Light distribution status |Not activated | |48 |Front left variable lighting, specified position |204.70 % | |49 |Front right variable lighting, specified position |204.70 % | |50 |Headlight basic settings status |No command | |51 |Static cornering lights |Left static cornering light, dimming: 0.0 %; Right static cornering light, dimming: 0.0 % | |52 |LED headlight, light distribution commands |Low beam: No command issued; High beam: No command issued; All-weather lights: … [truncated] | |53 |Actual reference segment angle |Horizontal reference segment angle, left side: -500.0 ′; Horizontal reference segment angle, right side: … [truncated] | |54 |Matrix headlight, calculated offset values |Left headlight horizontal offset: -300.0 ′; Right headlight horizontal offset: -300.0 ′; Vertical offset l… [truncated]| |55 |Drift angle |-120.0 ′ | |56 |Axle offsets |Rear axle offset: -400.0 mm; Front axle offset: -400.0 mm | |57 |Matrix high-beam function status |Inactive | Advanced identification |No.|Parameter |Reading | |--:|----------------------------------------------------|--------------------------------------------------------------------------------------------------------------------------| |1 |Number of programming attempts |Application: 0; Bootloader: 0 | |2 |Number of parameterization attempts |Dataset: 1 | |3 |Number of successful parameterization attempts |Dataset: 1 | |4 |Maximum number of possible software updates |Application: 65535; Bootloader: 65535 | |5 |Detected subsystems |Subsystem designation: Reserved; segment number: 4; subsystem present: Yes; subsystem … [truncated] | |6 |Busmaster / Subbusmaster identification |ECU ID: 4B; ECU Name: Multifunction Module; LOGICAL-LINK SHORT-NAME: Multifunction Module | |7 |Connected component identification |Identification number: 4B; subsystem name: Multifunction Module; Bus information / node address: A9 | |8 |Subsystem diagnostic classes |Systems, diagnostic class 3: Yes; Systems, diagnostic class 2/2F: Yes; Systems, diagnostic class 1: Yes; Syst… [truncated]| |9 |Service code and date of last software module update|Year: 0; Month: 1; Day: 1; Equipment number: 0; Importer number: 0; Partner number: 0; Programming status… [truncated] | |10 |Date of last coding |Year: 22; Month: 18; Day: 5 | |11 |FAZIT identification |Manufacturer plant code: SJ8-FST; Production date: 29.11.16; Manufacturer test station number: … [truncated] | |12 |Parameterization identification |Number of datasets: 16; AFS dataset: 04; MXB dataset: – | |13 |Diagnostic mode |VW diagnostic mode | |14 |VW / Audi part number |3Q0907338 | |15 |Software version |0285 | |16 |Serial number |29111610520147 | |17 |Hardware part number |3Q0907338 | |18 |Supplier software version |FFFF2706201612111700000000000000 | |19 |System designation |FCM MQB Low | |20 |Adaptation service code |Equipment number: 60933; Importer number: 3; Partner number: 12289 | |21 |Date of last adaptation |Year: 38; Month: 17; Day: 19 | |22 |ASAM / ODX file designation |EV_MultiModulContiVW48X | |23 |Parameter dataset part number |V03935248XG | |24 |Parameter dataset version |0001 | |25 |ASAM / ODX file version |001010 | |26 |Hardware version |001 | |27 |Vehicle equipment code |000000000000000000000058 | |28 |Coding service code |Equipment number: 31; Importer number: 770; Partner number: 73216 | |29 |Parameterization service code |Equipment number: 31; Importer number: 770; Partner number: 73216 | |30 |Parameterization date |Year: 22; Month: 18; Day: 5 | |31 |Short system designation |J745 | |32 |Software module versions |Application: 0285; Bootloader: 0106 | |33 |AUTOSAR Standard Applikationssoftwareidentification |Unknown; Software manufacturer ID: IAV GmbH; Major version number: 2; Minor version num… [truncated] | |34 |Flash update data security |Hash value: Not available; Key unlocking mechanism: Not available; Key: No; Key typ… [truncated] | |35 |Programming status |Programmable: Programmable; Program structure: Program available | |36 |EEPROM data consistency |Fault during last dataset download: No fault; Data consistency: Valid EEPR… [truncated] | Notes • “Static” is the control module’s reported status at the time of the recording, not a confirmed adaptation or coding value. In the recording, both engine status and low-beam status are OFF. • The difference between the rear sensor’s learned zero-position value (46.00%) and its current reading (42.40%) reflects two separate values shown in the recording. • The “Fault” indications for the two dynamic cornering light values should be checked against DTCs; the other adjustment motor status readings indicate “No fault”. • Date fields are reproduced exactly as raw values displayed by the application, even when they do not form a valid calendar date.
  10. pelle64 joined the community
  11. Oldchap joined the community
  12. MIB3 Preh – VCRN Showing 1234 on All FECs – What Could Be the Cause? Hi everyone, I have a 2023 Skoda Superb Scout with a Preh MIB3 infotainment unit, and I’m trying to understand an issue with its FEC/SWaP information. Here are my infotainment details: Part number: 3V0035832P Hardware: H22 Software version: 0324 Release version: MOI3_RW_SKMQB_P32400P Navigation database: 22.6 The factory navigation is currently unavailable. When I press the NAV button, the system displays “Function not available”. While checking the FEC/SWaP menu, I noticed something unusual. When I open the details of any installed FEC, the VCRN field always displays 1234. This happens with every installed FEC, not just one particular code. The important thing is that I have never modified, patched, or attempted to activate anything on this infotainment unit. As far as I know, the system is completely untouched. My questions are: Why would the VCRN display 1234 on every installed FEC? Is this a known issue with Preh MIB3 units? Could this be caused by a factory configuration problem, a software issue, or corrupted EEPROM/eMMC data? Is there a way to retrieve the actual VCRN without using VCDS or ODIS? Could this issue be related to the unavailable factory navigation? Has anyone experienced the same issue, particularly with a Preh MIB3 unit running software version 0324? I’d appreciate any technical advice or suggestions. I would prefer to understand the root cause before attempting any software modifications or activation procedures. Thanks in advance!
  13. Hi MMX23 Welcome I could in theory just about match your P.S. with my PHEV MkiV but I’m PaSt it now. The short range electric with petrol for range angst will do me now hopefully even if hybrid complexity at 80k miles (2022 Jan reg) (matches you there too!) has downsides maintenance wise.
  14. Hortiguy started following Hi to all
  15. Thanks for the reply , is there no way of getting to the bottom pipe from the top if I remove air intake pipes ? Can't jack my car up where I live , ive just got a 19mm connector because everywhere I looked online it said I needed a 19mm but on the plastic connector it says 18 with that circle print next to it . Was that 20mm a really tight fit ? Also mine isn't loosing coolant but got soot in the tank and bubbles in the tank with engine running was yours doing that ? And as it stopped
  16. simonsuffolk joined the community
  17. Hello Another (hope not big) problem. Superb 2021 2.0 tdi 147kw 4x4 Dsg7 I have wierd noise from my car somewhere front i guess. When i drive from 70 to 90 kmh and release throttle there come some nois from somewhere (uuuuuuu) not so laud. There is no differenc if car stay in gear or go in coasting (neutral) the sound is there! But imediatly when i pres just a little throttle the sound is gone. What could this be?
  18. Seba800 started following Strange sound
  19. zazazac changed their profile photo
  20. Hello everyone! Been using this forum as a visual guide for a while for diagnosing issues on a Fabia but finally having to make an account to ask for some tips/help on fitting the rear door handle. I have the backing bracket for the handle and a new handle bought off of ebay (not OEM, just some chinese plastic fantastic replacement). Turns out the problem was deeper than just the handle, hence why I am here. I'm not overly experienced in car repair (just an armchair hobbyist waiting on passing my driving test). The rear part of the handle backing bracket is just free floating. I have the front part attached with the T20 screw but I cannot figure out how the rear is meant to be secured? When I took the broken handle off there was no rubber gasket which I think I'm meant to have (although I have had no luck finding online, if anybody knows where, please tell me!). So, does anybody know how this all properly goes together? I haven't been able to find anything online after a couple hours trying to figure it out over the past weeks when I have had time. I know I am missing the end cap (the one that came with the aftermarket handle was broken right out of the box, unfortunately) but surely the end cap alone isn't what secures this? Additionally, what is the function of the T20 adjustment screw on the handle backing bracket? Either way I twist it it seems to make no difference. Is something missing internally here? There's nothing rolling around in the inside of the door either. I took a video too, so if that would be helpful to anybody, please let me know and I can put it up somewhere. Many thanks in advance, any help at all is massively appreciated as I desperately want to tidy up this poor Fabia.
  21. zazazac joined the community
  22. Bought a demo Kodiak PHEV at a very good price but to be quite honest we may not have thought though all the implications of our hasty decision. I have been buying a lot of things for the car in preparation of our first holiday away in it to the relatively sparsely populated Western region of the state. The car, (like many EV and PHEV) does not have a spare tyre, just goo and an electric pump. This is simply not good enough, so I have bought a spare tyre and jack online for peace mind when remote travelling on dirt roads. The car only came with a Type 2 cable, so I have made my first Amazon purchase (yeah, I know, my first!) of a 15 amp home charger for about 75 pounds as an interim measure until I sort out something from our three-phase electrical supply. To truly 'Australianise' the car, I fitted mudguards from Skoda today and masked the front grills with flyscreen in case we encounter locust swarms which have been reported in the interior due to the unusually wet weather they had last winter. So far, our very limited experience of driving the car has been a very pleasant experience although my wife is somewhat intimidated by her perception of it being much larger than our mk3 Octavia. In actual fact it is less than a hand length longer and a hand width wider, but I understand why she feels the way she does. We loaded a couple apps on our phone and went up the coast to the nearest scenic (8km away) 22kw AC public charger to test them. Spent $1.50 on 6kw of our best local electricity and $16 on two lattes and three doughnuts, which were not the best. Next experience will be to test a quick charger since the car accepts 50 kwh on DC. Obviously, the electricity will cost more, but we shouldn't have time to buy coffee and cakes so cheaper overall .
  23. According to obd11 my battery resistance reached 6.0 milliohm today. It seems to hover between 5.2-5.8 lately. I found a screenshot from December 24 and resistance was 4.2 milliohm. According to my battery-aging performance/charging reading it’s down to 64%/65%
  24. https://www.briskoda.net/forums/topic/419731-auto-folding-wing-mirrors/
  25. Press the remote lock button twice I think to get them to fold in. Is your mirror adjustment button set to have them fold in as well?
  26. I know I've seen it somewhere, but no matter what search term I put into the forum, the answer eludes me. I can fold (as usual) the mirrors using the switch inside the drivers door of my Yeti, but the remote doesn't do it. Can someone please point me to the post that dealt with this issue? Thanks
  27. If you can access the heater matrix hose connections in the firewall and disconnect the hoses you can: Like Alasdair said flush with a garden hose Blow compressed air in the "input"-connection and catch the outcoming fluid from the "output"-connection, careful dont blow too hard, it will make a mess Tape a long clear hose that you can feed in to the heater matrix to a wet vacuum cleaners nozzle and vacuum the coolant off from inside the matrix
  28. Not Change Hardware, Only wire Setup
  29. Update on my Approved Used Octavia vRS – VAQ service, outstanding maintenance and Start/Stop Just wanted to give everyone an update and thank those who have offered advice so far. I've continued corresponding with the sales manager at Škoda North Wales regarding the servicing that appears to have been outstanding when I purchased the car under the Approved Used programme. Following several emails, they've now offered to reimburse the £199 cost of the VAQ front differential oil service as a gesture of goodwill, which I've accepted. However, they're still declining to cover the spark plugs (£140) and engine air filter (£55). I've gone through the independent Pro Tyre service invoices individually. Interestingly, there's a section for air-filter replacement on the paperwork, but it hasn't been ticked on any of the invoices. I also can't find any mention of the spark plugs having been replaced. The dealership maintains that its technicians considered the previous service documentation, Škoda's internal systems and the condition of the components when deciding what work was required. I've asked them to explain exactly what evidence they relied upon, particularly given that item 115 on the Approved Used inspection checklist was marked R (Requires Further Attention). This is the item stating that all serviceable items due within six months have been completed and the service history brought up to date. I'm still waiting for a response to those questions. Regarding the Start/Stop issue: The sales manager explained that the N/A recorded against the Start/Stop check on the inspection report was a technician's error and that it should have been marked as checked. Apparently, no relevant faults were recorded. However, the system still isn't operating as expected. I've now booked the car into Škoda Worthing for Tuesday 24 November for a Start/Stop investigation and battery health check. I'm also planning to have the VAQ service completed at the same appointment, subject to confirming the reimbursement arrangements with North Wales. For now, I've decided to hold off on the spark plugs and air filter while the discussion continues. I may ultimately get my trusted independent mechanic to do those jobs if the dealership won't contribute. I'm also considering raising the matter formally with Škoda UK, mainly because I'd like clarification of what the Approved Used preparation standards actually require, rather than simply arguing over the remaining £195. I'll update the thread once I've heard back from the dealership and have the results of the Start/Stop investigation. Thanks again to everyone who's contributed. The advice has been really helpful.
  30. Bought a new Kamiq from Rain worth Skoda this year, brilliant dealership and recommend them.
  31. Hi everyone, I could not find any topic covering this specific diagnosis so here is my first real post here! Looking for some real-world feedback before I order a replacement part for my 2019 Octavia vRS 245 (2.0 TSI 245hp, 129,000 km / ~80k miles, DKTB engine code). The issue: Once the car is fully up to operating temperature, there is a constant, fairly high-pitched whistling noise coming clearly from the rear (under the back seat / fuel tank area). Aside from the noise, the car runs great: no warning lights, no misfires, and it starts right up both cold and warm. What I've checked so far: A mechanic listened to the noise and agrees it's likely the low-pressure fuel pump (LPFP) inside the tank. I ran a few checks with OBDeleven showing the pump is working hard constantly (~70% duty cycle at idle, 85-90% under load), while everything else on the engine side (fuel rail pressure, fuel trims, EVAP purge valve) looks completely healthy. The underside of the fuel tank feels completely cool to the touch. Before I go ahead and swap in a new Bosch fuel pump unit, has anyone else experienced this exact symptom on their vRS (or a Golf GTI / Leon Cupra from the same generation)? Did replacing the pump permanently fix the whistling, or is there anything else around the tank worth checking (tank breather/ventilation, fuel pump control module, etc.)? Thanks in advance for any insights! Cheers, AD
  32. MMX23 posted a topic in Hellos and Goodbyes
    Hi to all ! I'm the new owner of a 2019 Skoda Octavia vRS, 2.0TSI DKTB engine with 130'000km. I might post or participate in topics in relation to this car for any mechanical insight and help or regarding modifications and upgrades. I hope that I'll be able to share my experience and be helpful in any way. See you around !
  33. MMX23 joined the community
  34. I do notice the on/off when cornering lights come on at low speed is all or nothing and its noticeable, but I can't say that it bothers me per se. I prefer the white light on/off over the yellow light dimming. Down to personal preference.
  35. piotr1_1 joined the community
  36. ScrapMyCarUk joined the community
