langers2k
  1. A 2007 Octavia and 2019 Superb are completely different electrically as they are based on different platforms... Take a look at the adaption channels in 09 on your Superb: ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis,Driver door That seems to be the 'activation' reason for coming home so maybe see what options you have
  2. Oh - your using a mac... That will mess things up as OSX add extra files which stop the SD card working. If possible, use a PC otherwise I think you'll need to use a program like CleanMyDrive on the SD card after extracting. Top level directory should just have a directory called maps and no other files.
  3. You're using Columbus instructions on your Amundsen. Try following these instructions instead. You can use the file you've already downloaded
  4. No component protection for the climate panel on a mk3... It'll might need coding and basic settings etc running after fitting though.
  5. Pretty sure it's part of the ECU output... Whoever did the tune should have updated the maximum output from the ECU at the same time. It's not a feature of the cluster to choose the power...
  6. Please install the latest English VCDS version from here: https://www.ross-tech.com/vcds/download/current.php It can be installed at the same time as the Czech version you currently have. Then post a full autoscan and an adaption map from 09. The picture you've taken will not help
  7. I wonder if that's an OBDeleven vs VCDS thing? AFAIK, 76 was for older modules (circa 2009??) and 10 is for more modern ones. Example VCDS scan with the same module as you have on address 10: https://forums.ross-tech.com/index.php?threads/16113/#post-144479
  8. U101300 is a fault code and isn't specific to a particular module. It typically means whichever module is displaying the code hasn't been coded. I can't think of any obvious reason for this to occur during a parking sensor bracket replacement. Park assist does use data from the ABS module to determine direction and other a few other things. Still, that doesn't confirm which module has flagged the code up 🤔
  9. Maybe start by posting an full autoscan and an adaptation map from 09...
  10. No mk3 or mk3.5 had wireless AA or wireless car play. The radio hardware doesn't support it... Your only option is an aftermarket dongle 👍
  11. Pretty sure that's normally on the B-pillar, probably on the passenger side. You'll need to open the front passenger door to find it. Should be similar to this: Where the towing weight would be the second number minus the first. So in the example above, 3460kg - 1960kg to give 1500kg max towing weight.
  12. Just to point out, cars like the Yeti don't have a strong concept of date/time so it's normally pretty safe to ignore that and rely on the milage instead. I also wouldn't expect a dealer to be bothered to clear codes during a service either As above, I'd save a scan (feel free to post it) and then clear all the DTC's to see which, if any, come back.
  13. The Golf probably has slightly more damping/sound deadening so any noise/vibration may be less noticeable.
  14. Welcome. You need to find out your gearbox code as that'll then give some pointers Looking at the workshop manuals I've got: - some have filler holes - some go via the reverse light switch - some have a special filler hole which require an adaptor
  15. You'll need to add the headlight range control module, level sensors to the suspension and extra wiring to fit them. Along with headlight washers if you haven't got them... After that it's coding and alignment.
  16. I'd guess at a failing joint inside the instrument cluster It was common on some older Octavias...
  17. Surely you mean it's set up for RHD which would be normal in the UK...? Left hand traffic, right hand drive
  18. I expect you need the seat controller updating by a dealer. Technical product information Transaction No.: 2049942/3 Storing seat memory positions not working Release date: 07-Feb-2019 Customer statement: • Storing driver’s seat or front passenger’s seat positions into memory is not working. Service centre findings: • Entries „no basic setting“ concerning seat adjusting motors are stored in the event memory of the seat control unit. Measure • Online update of the memory seat control unit SW using the diagnostic tool ODIS via the measure code. • If the fault „Data set invalid“ is logged, check the SW version. It has always to be the latest SW version, i.e. SW 22 or 24. • In the case of the version SW 22 or 24 with the fault entry „Data set invalid“, carry out only the parametrization of the memory seat control unit using the software configuration (SWK).
  19. I'd suggest googling for: vcds "address: 8c" As that will at least give you an idea of what Ross-tech believe the module would be. In this instance: - Address 8C: HV Battery (J840) - Address BD: Hi Volt. Batt. Charg. (J966)
  20. VAG have a feature where the wiper park position will move slightly. The idea is the wiper rubber will last longer as it's not always on the same position. Certainly doesn't look massively out of place to me...
  21. You'll need to upgrade your CAN gateway firmware to get the that working. I had similar issues on a MY18 Octavia - few details in this thread: https://www.briskoda.net/forums/topic/479137-infotainment-lighting-query/ Short version, flashing the gateway from SW:4326 to SW:4344 solved it. After flashing it will need parameterising with a new dataset... No issues with component protection As you have SW:5323, you would need to find a suitable 5xxx firmware version, probably from a MY19 or newer car and dataset to fix it 👍
  22. TPI 2049459/14 (05-Oct-2021) covers the MIB2 update. Customer statement: Customer may complain about one of the following phenomena: • ABT display failures (black screen). • MIB switching off, restarting – with a connected mobile device with the IOS operating system. • MIB without sound, or sound cannot be controlled, voice control malfunction. • MIB sporadically switching off or gets frozen while calculating route or while navigating. • MIB does not allow the lower menu bar to be automatically hidden in the navigation mode. • MIB does not allow the activated additional information window to be closed. • Virtual Škoda Surround not working. • Radio is playing when customer comes to the locked vehicle. • Deactivating auxiliary heater pre-selections. • Changing time indicator. • The hands-free function is not available; displayed is the indication „Phone not available“ and Bluetooth does not work. Workshop findings: • The customer statement can be reproduced. Technical background Faulty SW MIB Standard (Amundsen, Bolero) in vehicles manufactured in the period from CW 22/2016 to CW 45/2020. Production change Modified MIB control unit Generation II with new SW version introduced since CW 45/2019 Measure • If the customer complains about one of the above symptoms, perform the update of SW MIB Standard (Amundsen, Bolero) to the new SW version. • Updating procedure of the MIB control unit using the application SD Creator – see Service Information No. 2034053. • To download the SW 369 (to be applied to vehicles manufactured in CW 22/2016 – 22/2017), enter Part No. 5FM.IB2.STD.369 in the application SD Creator • To download the SW 480 (to be applied to vehicles manufactured in CW 23/2017 - 45/2020) enter Part No. 5FM.IB2.STD.480 in the application SD Creator Important notes: If the following instructions are not observed, the updating process may be stopped and the navigation unit blocked. Warranty costs will not be accepted in such a case. • The respective flashing data can be used only for vehicles manufactured in the periods mentioned (SW 369 for CW 22/2016 - 22/2017, SW 480 for CW 23/2017 - 45/2020). You should contact a dealer for the update... If you'd like to update it yourself, add your system details to this following thread and hopefully someone will provide the update to 0369 for you:
  23. @enisz - it'll probably work on a MY18... No idea how you do backup/restore with OBDeleven but as long as you make a note of the coding/adaption channel values before you make changes, you can set them back to the original values 👍 On a MY18, you should be able to get custom colours for each driving mode but you may have issues with individual mode. When coded properly and individual selected, my car would keep flipping between two colours - namely the one I last choose in manual and the one set in the adaptions. You can workaround this by tweaking the config so individual mode has a preset colour rather than trying to use the last set one. I was able to fix this properly by updating my CAN gateway firmware to 4344 - not possible with OBDeleven/VCDS. Everything now works correctly as it would in a MY19 car Few more details in this thread:
