  2. Thanks - I do 15k miles per year, and my company give me the bare minimum expenses wise (13p/mile for my 1.5 hybrid), so a 2 litre tsi isn't suitable. Wish it was, but......
  3. May be work looking at Second Gears - www.secondgears.co.uk
  4. If village data is missing from the map then no firmware update will help.
  5. I have a 2025 kodiak it went in for a repair as water was leaking in through the light bar. its leaking again and booked in . Anyone else have any problems with water ingressing through the tail gate ( no pun intended)
  6. samdylan1 started following tail gate leak
  7. Today
  8. I was told from the garage when they did the sensor that the dual fly mass and rear main oil seal (where the reluctor ring is I believe?) looked fine. So I think it’s unlikely it is that. I’ll try having a look at the relay. Is there any chance that it could be that the ECU is causing the issues?
  9. It's the official way & doesn't damage anything. 😉
  10. Elhaliy joined the community
  11. I'm experiencing the same issue. Did you end up finding a solution?
  12. trupus joined the community
  13. I got a decent price for my folks fabia. Even the insurance guy was surprised at how much. He did say that they seem to hold there value. £18500 I suppose isnt too bad but wish they would pay you for the inconvience of looking for another one plus all the hassle. We got a courtesy car when my folks was damaged but when it was written off we had to give it back in 3 days so had to find another quickly. Hope you find something as nice. Did spot this on here a few days ago https://www.autotrader.co.uk/car-details/202610146991152?utm_source=share&utm_medium=ios-app Alasdair
  14. that's because using the key blade forces the cover off damaging the catch. Using a screwdriver actually releases the catch properly and so doesnt damage it
  15. robirobi joined the community
  16. Indeed, i had an A6 written off with less damage. I fear the damage on mine is structural - wheel to wheel at even 20mph can be catastrophic. Both shocks would need replacing as well, I guess, a Vega 19" - what are they new - £1k? All adds up. I've been given £18500 as the value, and i have GAP, so not too out of pocket.
  17. Cost of repairing cars these days is mad. Had similar with my folks fabia. Damage wasnt that bad mainly front wing and drivers door etc and no structural but got written off. Had another with a volvo 940 that someone reversed into rear door and panel. Again they wanted to right it off or give me a so called cash adjustment ?? I dug my heals in and pointed out that it was repairable. I had just spent £700 on it and as I wasn't even in car at the time so wanted it repaired. Surpisingly the asessor agreed and they repaired damage plus gave me a courtesy car. Chances are someone will buy it and fix it. Alasdair
  18. I was trying to get to the road in which I'm stood to take the image, note the position of my offside front wheel in relation to the kerb - I couldn't get any further over to the left in my approach. The guy in the van was heading towards me and just pulled straight into me. The insurance has said it's a write off and I couldn't take the salvage anyway - I need my car for work and don't have the time or energy to fix it.
  19. No need for screwdrivers, which is probably as well given you're unlikely to have one in your pocket if the battery suddenly fails. Release the emergency key & withdraw just enough until the black plastic clears the case. Then with the fob in your left hand, gripped between thumb & knuckle of the forefinger (thumb under the key to brace), grip the key by the plastic part in the same way. Then exert a snapping motion upwards on the key & the blade will pop the cover off. As I said originally, harder the first time but easier thereafter.
  20. What on earth happened? Are you sure that it is written off
  21. Is the control unit still responding via diagnostics? If not, buy an OEM part.
  22. I have just loaded the 26/27 version and still no villages. Does anyone know if this can be fixed with a firmware update to the Amundsen unit?
  23. AliExpress kit ad many other users bought
  24. Might be dirt/debris on reluctor ring so the sensor isnt picking it up properly or perhaps a bad relay in engine bay. On my old octavia it was I think marked 109/458 (cant remember but it fed ECU and engine sensors)
  25. @Cqrmine here's the post https://www.briskoda.net/forums/topic/436650-kessy-key-fob-battery-change/ go down to about the 4th post and it shows a picture of the inside of the key and the small tab that you are trying to free with the screwdriver
  26. after a while, vibrations made me have headaches, so i modified insert, i was browsing internet and many people did similar, i cut out some elementr to increase motion from zero motion with full insert, it is not drivable. this is another level, no more vibrations on start and 2 cilinder mode, but holds well on speeding and sporty driving..
  27. I looked at pages 23 and 24 and they don't work for me.
  28. They charge for changing the battery???? Of all the robbing *****
