- Super Estate Tailgate Problems
Kamiq seat question.
Adding Security to vRS Wagon, due 1 September
I do have another angle that I'd like to give on this (and it comes from personal experience). If a car thief is determined enough to want your car, then the best way to secure your car is to secure your house. Put all the kill switches, immobilser devices, faraday boxes/pouches you like, if they are determined enough to want the car they'll try and get in for the key, and beat any immobilser code out of you. Before the vRS I had a Cupra Atec VZ1. After about a month with it two masked guys tried to break into the house for the keys. We have anti-snap locks fitted to our house and they gave up as soon as they realised they couldn't snap the cylinders off. About 20 minutes later a Golf R Estate was stolen from only a few hundred metres away from a house without anti-snap locks. They were in and out within seconds. If you have a vehicle with KESSY like we do, the best security for your car is security for your house.
Cheers for the reply, Kenny. I did some digging and looked at the owners manual and I think I found the answer since posting.... This is from the 2026/3 manual - it's also in the 2026/8 manual. I'm guessing the 'Tilt adjustment' option adjusts the seat base angle?
New Superb wipers leaving a hazy/milky film after rain – anyone else?
In Romania, for the Superb Sedan\Liftback, you can choose the rear wiper for an extra cost, so it's not included by default.
Don’t think I’ve ever seen electric seat option on the Kamiq.
NorbertD joined the community
1.5 TSI MPG: Octane vs additives (>4,000 miles longitudinal road test)
I bought the additive https://www.mannol.de/products/additives/ester-additives/mannol-benzin-ester-additive and I add it as it says 0.1% to 95 gasoline, it's a very weak mixture, I wonder if it has any effect in such a small percentage. I was thinking of increasing it to at least 0.2%, shouldn't it be a problem?
Many thanks for your reply. I have ordered a pair of the compatible Bosch ones from Amazon. I’ll keep them in reserve and see how the OEM ones perform to start with. I don’t think my new model actually has a rear wiper at all, from what I can see of the spec, which is a shame, as it helps visibility in very wet motorway driving. On the plus side, it does tend to give the dog a bit of a jump scare if travelling in the boot on the old one, as it makes a racket when it first wipes the rear screen🫣.
mike33 started following Skoda Kodiaq MK1 (2017-2023)
Solved-> Overheating problem Skoda Superb (year 2018)
What's your oil temperature getting to at say 220-230km/h after 3-5 minutes of driving now that the shutters are removed? My numbers (Mk3 Octavia CUNA TDI 184bhp) are about 107degC - 109degC at 200km/h, about 115degC - 117degC at 215km/h in ca 20degC environment, and I got to 125deg C on one occasion driving at 230km/h before I started watching oil temperature... I try not to exceed 115degC, even though the engine can take more, the oil pump is belt driven ( and the belt is in the hot oil).
EPC warning light and limp mode
Well that was quick and painless, thankfully! 👍 It turned out that, when the Turbo Actuator arm was replaced a couple of years ago (before I got the car) the housing hadn't been put back quite right, so it was rubbing on the arm and it had caused enough friction to register as a fault. A couple of minutes with a screwdriver and pliers and it was moving freely again Whilst having my own OBD reader might have told me the problem, I wouldn't have known where to look, so that's £60 well spent.
mike33 joined the community
OBD2 reader
I've used a Carista reader for years, its been pretty good and definitely saved a few £££. I pay for the subscription version and would say I get good value out of it each year and will continue with it.
TasMan started following OBD2 reader
- Oil Change
MIB 3 SW update
Hello I have a Fabia 4 with MIB 3, OE 3V0.035.816.L, but with the old SW 0306. Carplay, or rather the phone, is often disconnected. A known thing on old SW. I would like to put the latest possible SW there. I would probably flash it via ODIS rather than via USB. Has anyone encountered a situation where the flash did not go through and the unit was gone? Is there then any possibility of restoring the unit, for example on the table? It's my car and the system is not exactly cheap. Thanks!
eMvoc started following MIB 3 SW update
Melco joined the community
- Solved-> Overheating problem Skoda Superb (year 2018)
Warrior193 started following Solved-> Overheating problem Skoda Superb (year 2018)
- Direct Firmware Download needed for Bolero in Octavia III
Is it possible and thinkable for you to contact me via dm or email <Removed> There are some units in PL for sell. Maybe we can discuss options and I have questions (read- I need help) with CP obviously. Email removed Only send this information via the PM (Private Messaging) function to trusted members. If the PM function is not yet available to you, tagging the member and asking them to start a conversation will work. Briskoda admin.
DGW started following Solved-> Overheating problem Skoda Superb (year 2018)
Pudnig joined the community
Callumholt joined the community
caroline73 started following Skoda Superb Mk2 (2008-2015)
Something is killing my battery - where should I look?
looks like a standard EFB rather an EFB+ EFB+ models generally provide higher amp-hour capacity and slightly stronger cold-cranking amps (CCA) than baseline EFB tiers from the same brand family.
- Yesterday
Door Umbrella
Thanks for the comments, sorry for the delay in replying but we have been away for a few days. We decided to take the Fabia as it doesn't get alot of use and longer runs - I really enjoyed driving the car which as you say is my wifes. Bit disappointed that it didn’t come with an umbrella given that it was quite expensive with all the extras. I should have checked when we first got the car but hey-ho!
Dpf help
Possibly a blockage in one of the smaller pipes. Sadly if a couple of longer runs don’t resolve it you may need someone who is an expert in DPF’s most garages and dealerships don’t really have a clue Take a look here, he is good https://youtube.com/@orileysautos?si=yawAXYQ-RRBloGeD Don;t get the idea a quick delete will resolve it. Most likely it won’t
Dpf help
I started digging deeper into the issue and noticed that the measured soot mass is increasing twice as fast as the calculated soot mass. That’s where the problem lies: either one of the sensors is malfunctioning, or they need calibration.
- help.. octavia
jimcwestie joined the community
cooling fan unit advice
BlueWagon Thanks for the response...... I thought so too. There's always that old adage...'If it's not broken, don't fix it'. I've ordered one controller for £32 odd on ebay....... I will fit it when it arrives and report back. Thx again, BlueWagon for your response. Regards Tom
