Past hour
Top mount
Only had my superb a few weeks. Yesterday it started making a horrendous twang. I suspected a spring , turns out the o/s top mount has left the chat. So I wanted to ask, is it a pretty straightforward DIY job. And what's a decent replacement brand to use. Its a 2016 superb estate L&K 4x4 2.0tdi 190. Many thanks
Octavia 2.0tdi engine swap - DTTA in DSUS car?
Hi. If you have any issues with insurance at all for a change of engine then please feel free to drop me a line. Regards, Dan.
DAN@ADRIAN FLUX started following Octavia 2.0tdi engine swap - DTTA in DSUS car?
Suspect engine oil leak
No.
scan
Thanks. I've inserted the new file into your opening post. I'll tidy this thread up later.
scan
yes evdash_autoscan_20261114_0542.txt
Hi Pete. Found this on the Rapid Guides on here, Is this what you are meaning ? 1.2TSI Crankcase Breather Hose One Way Valve Replacement Guide (by Mintyfresh)
- Infotainment Firmware update MK3 2018/19
Dashcam Switched Power
Nothing the dealer can do about it. That is how the dash cameras automatically switch on and off is by detecting the actual voltage being fed to it. If it drops below a certain point, the camera switches off. When the car starter kicks in, there is a large drop in voltage everywhere in the car at the same time, so it is just as likely to do the same even if it is plugged into the power socket. At least with the camera wired up so it wakes up when the ignition is switched on, it removes the chance of you forgetting to plug it in, leaving you without any video protection in the event of an accident. If the voltage gets to a critical point when it is plugged into the 12V socket, the camera switches itself off to prevent it from draining your battery even lower. So wiring it in will prevent it being forgotten to be plugged in when driving and also prevent it from being forgotten to be unplugged when you aren't driving the car. For the small cost of an OBDII scanner tool, you can ensure that you can never forget to switch off the stop/start by tweaking the point in which it cuts in, all the way to disabling it completely, and also alter the way other things operate, and also enable some options that aren't operational unless you have a range topper car model.
SimonDinsdale started following Ambient air temp sensor on the wonk
Hello all, long time lurker, 1st time poster. I'm having trouble with the (external) ambient air temp sensor. When I start the car in the morning (2010 CFGB TDI 4x4 estate) the sensor works fine, when I return to the car initially the sensor works and then it starts shutting down ---- on the MFD and then occasionally reads 58C then ticks down to the the actual outside temp and then shuts down. I have a Carly scanner and I get fault codes for the circuit being too low, too high, with the addition of 'sensor for outside temp, resistance too small" at the instrument cluster. I also get a faults for the air quality sensor, and the glow plug controller/relay and wonder if they're all connected? Also I get error messages on MFD for various bulbs being out I.e DRL, side lights etc but, no fault codes stored so wonder if this is also connected? So far I've replaced the external air temp sensor with a OEM part from DSD, replaced the plug and 100mm of the cable. I'm wondering where the sensor draws power and that perhaps there's something wrong with the wire in, I've chased it back to where the two cable meet with the rest of the loom that serves the engine bay and goes through the firewall seemly to the instrument cluster. I'm all out of ideas part from unwrapping the loom to see if there's a break in the cables or whipping out the clocks to see if there's an issue behind them. I'm hoping that someone has experienced the above and can help me solve this conundrum because it's causing mayhem with the HVAC system
Adiwez joined the community
Hi Pete. I will definitely give that test a go to see if it is possibly the fault you have described re. the breather diaphragm. Thanks for the heads up on that. Will keep you posted. Hi Alistair. Yes, that is the problem, tracing the source of the leak. I am sure I have pretty well eliminated steering (electronic) and brake fluid as there is no drop in the reservoir level. I am going to look into what Breezy Pete has suggested above and see where we go from there.
Today
If it’s the same as the 24 model go into gateway and type battery in to the search and tick it. You’ll then get a list of the battery parameters.
Timotej started following Infotainment Firmware update MK3 2018/19
Skoda Superb Combi 3V539Z suspencion
For the Superb MK3 4x4 with increased ride height and without DCC (electronic damping control), one option for shock absorbers is Bilstein B6 from the VW Passat B8 Alltrack. The VW Passat B8 Alltrack has increased ride height and four wheel drive. One owner who went with this option said that the damping is similar to standard. If true, then this option could be a way to get very good quality shock absorbers for increased ride height but without the sports damping (which you may not want) that you might associate with Bilstein B6/B8 shock absorbers. Bilstein B6 and Bilstein B8 have a mono-tube design which is better than the standard twin-tube design. Mono-tube is more expensive to manufacturer than twin-tube, hence most shock absorbers aren't mono-tube including Bilstein B4. The below Bilstein B6 front shock absorber is sold to replace only a small number of OEM part numbers and the cars listed against it all appear to be increased ride height, so I suspect it is made especially for increased ride height cars. The below Bilstein B6 rear shock absorber is sold to replace a long list of OEM part numbers, so I suspect it is made for both standard ride height cars and increased ride height cars. Bilstein B6 35-273806 front shock absorber (without DCC) (VW Passat B8 Alltrack) https://www.autodoc.co.uk/bilstein/9612727 Bilstein B6 24-267137 rear shock absorber (without DCC) (VW Passat B8 Alltrack) https://www.autodoc.co.uk/bilstein/9350571
- Dashcam Switched Power
L&K Front Fog light Bulb access?
Do your leds dim? Think most just turn off
- Skoda Superb Combi 3V539Z suspencion
scan
@Zachy64 can you remove your VIN from the file please and I'll unhide your post. Admin.
12V low, can I charge it up with a charger?
Thank you.
I turned I turned off my stop/start by raising the threshold of the voltage at which point it comes into play. The car now behaves as if is not fitted with the system. The minute amount of fuel it uses is way cheaper than the cost of replacing the battery, starter motor and alternator, which work harder with the system activated, and the camera switches off and on all the time. This is a better solution I think, especially if you drive in a town or city a lot as it exposes you to a higher risk of not video evidence at times of increased risk.
Penguinpete joined the community
scan
Please provide an evaluation. Thank you. evdash_autoscan_20261114_0542 (1).txt
Karoq useless Satnav
What about a multi waypoint route through small towns and villages. How do you plot that ? Do you guess which brown blob is the village you want. If Google Waze and others can do it why not Skoda. Smarty.
Yeti 5L: byte 18 changed, need BCM light config (VCP) - halogen
Thank you, that’s very clear and reassuring! My rear lights are halogen (P21W bulbs). Does anyone here have VAGHelper and could check the Skoda Yeti 2014 halogen scheme (halogen headlights, front fogs, halogen rear lights)? A screenshot of the outputs or the .bcm1 file would help me a lot. Thanks!
As far as I know, if byte 18 was 00 then no byte 18 value is correct for that vehicle. Some might be close enough that everything seems to work but there will be a difference that an engineer in VAG thought was important. Byte 18 mostly deals with lighting channels that aren't the headlights or front fog lights. As long as the example you find from VAGhelper has the same rear lights (halogen or LED) then I think you have a very good chance.
Zachy64 joined the community
Neil.R started following Bluetooth/Phone problem.
I’m at the tearing my hair out stage with a problem using my iPhone SE via Bluetooth, if I dial a landline (home for instance) then it says “there was a problem” on the info screen & doesn't connect it also says “this contact is not on WhatsApp” but if I dial a contact via a mobile No it connects. I’ve tried everything that search engines can come up with to no avail, & it’s far to cold to sit in the car unpairing & pairing Bluetooth 😀😀 TIA))
