Aircon pressure switch O ring seal
Yes, you need the right type of o-ring. No, you shouldn't lose any significant amount of refrigerant when changing the seal/sensor, there's a valve under it that closes as it is removed. PAG oil for lube. If it's the original pressure sensor it could easily be leaking through itself, rather than at the o-ring seal, I suspect.
PHEV service intervals
The all weathers start life with more tread depth.
Hi. Tbe o rings are special rubber so they don't rot. If there is still pressure in the system it will need recovering first. Illegal to deliberately release to the atmosphere. To oil the O ring use the appropriate LAG oil for the system. Going to need a garage with AC equipment. Good luck
Robin started following Aircon pressure switch O ring seal
Mattridd joined the community
My fronts were measured at 4mm and rears at 5 mm, which is more than I expect, but they are Goodyear all-weather, so I suspect a bit of a softer compound. But Mrs says the big difference is the car never aquaplanes when it rains very heavily, which both of our Golfs (Mk7.5 and Mk8) on Bridgestones did. So I'll probably replace them like for like next summer when we get to 20,000 miles or 2.5mm whichever comes first; annoying but I do absolutely love the car and it is heavy, so like the higher road tax, it's an accepted cost of ownership. Your tyre wear, however, does sound concerning, assuming you check pressure regularly and drive it like a Tourer rather than with gusto? Had Pirellis on some of my former warm/hot hatches (XR3, Mini Cooper S) and, as I recall, they did wear more than expected, perhaps more sticky and hence softer, as a performance brand?
- Bootloop media player
Booming noise from rear on full lock Karoq 2.0tsi 4x4
Ok. Looks like they've just done an oil change and not cleaned the strainer / filter which needs the pump removing. The latter is not part of thier normal service routine but needs doing and some dealers do it some don't. I'd ask if them whatbtheybdidnre the internal pump strainer / filter when they changed the oil and if they didn't do it either ask them to or take it elsewhere. Also double check with them that they know where the Haldex drain plugs etc are just in case they've drained the diff instead as they are easy to confuse if your not familiar with the car.
What's the increase in BHP with the new dipstick? 😉
I had a new Scala 1.5 dsg Monte Carlo from 2021 before trading it in for a SEL Karoq in 2025. Had seven Skodas since 2004 and the Scala was my favorite by a country mile, comfortable,economical,spacious and a great looking car. Icant think of anything I didnt like about it, probably get another when I change next time.
minsy started following Considering purchasing a used low mileage Monte Carlo 1.5Tsi DSG
Exhaust drone ( 2950~3350 Rpm ) during highway use... ?
Have been on a 15000 Km ( 9400 Miles ) summer trip with the car. Have discovered a very annoying and clear exhaust drone in a narrow rev range ( 2950~3350 Rpm. ) The car has a 100% stock Skoda OEM exhaust system. 🤔 Anyone else here at Briskoda who has or had similar exhaust drone on their Octavia-II FL 1.8 TSI / 2.0 TSI equipped car ? 🤔 .
2stroke started following Exhaust drone ( 2950~3350 Rpm ) during highway use... ?
I have a leak at the pressure sensor I believe it must be the O ring seal. My question is, are the O ring seals special as they are VERY expensive for an O ring, can I fit an ordinary EPDM O ring. Am I right in thinking the pressure sensor can be removed without losing any remaining gas? Also what sort of lube do I use on the O ring when installing it?
Fuel Gauge Sender is kaput- Does anyone have a part number?
I filled the tank and managed to get 58 litres in on the first click. So if the 4x4 tank holds 65 litres, that means the trip computer and fuel gauge is definitely still over reading by some margin. I had the RHS pump out the other day but when I saw the extra pipework disappearing off to the 2nd off take I admitted defeat and put it all back without any further tinkering. I have a service coming up so I might just get the readers replaced at the same time….
Refuelling time. I couldn’t remember if I reset the trip when I last filled up, but the car was showing 160 miles left in the tank, and the refuelling quantity was showing 35 litres.
Fabia Mk4 130.
Thats cool but not good when your order specified contis in January on the car spec .
DJC123 joined the community
2017 Yeti value ?
Many thanks! I just replied to you. Good luck / "bonne chance" 🙏
'Sleep package' rear headrests
They look good. I had the boot and rear quarter windows tinted earlier this week, on top of the existing factory tint. I would have have considered those but not heard of them before.
Radio harnesses
The two black wires are the speaker connections... Probably old 2 pin DIN connectors from memory and the beige one will be permanent live, ignition switched live and earth. If you have access to a multimeter simply probe the three contacts on the white connector to work out which is which and wire up accordingly. Your new radio may have an ISO connector where all power wires are in a single black socket and speakers in a brown one, or all in one large black one, but you should be able to get a plug with wire tails already fitted. Like this https://www.ebay.co.uk/itm/266294103226?campid=5339147365&mkcid=1&mkevt=1&mkrid=710-53481-19255-0&toolid=20006&customid=EAIaIQobChMI77-sp43_lQMV8pRQBh2QrgSjEAQYAyABEgIekPD_BwE&loc_interest_ms=&loc_physical_ms=9046365&adtype=pla&gad_source=1&gad_campaignid=23835726846&gclid=EAIaIQobChMI77-sp43_lQMV8pRQBh2QrgSjEAQYAyABEgIekPD_BwE The internet will tell you which connection on the plug is for what (speakers, live, earth etc.) so simply splice your existing wiring into the tails on the new plug.
Fabia Mk4 130.
^^^ Manufactured by Hankook, or Factory owned by Hankook.
Windscreen cracking
For me, the ADAS wasn’t an issue, the team at the windscreen depot did everything in just over two hours. And yes, my original screen was also scratched to hell!
Fabia Mk4 130.
Just noticed i have Laufenn tyres all round on the stock wheels , obviously changed the contis down to these at skoda , 1st time I noticed ,
Thanks. BTW, how are your tyres wearing? My front Pirellis are under 2mm at 13,500 miles.
Itsrelfy started following Booming noise from rear on full lock Karoq 2.0tsi 4x4
Hi all. Had a quick search of the forum and can't see anything related. We are getting an odd sort of booming noise when pulling away with lock on from the rear of our 2020 karoq 2.0tsi 4x4. It's done it since we bought it last year on just over 40,000 miles. The selling dealership, group 1 Skoda Maidstone said they would service the haldex system as part of the sale and I have an email with the work stating it's been carried out. I assume this noise would be coming from the haldex as I've never heard it in any other car, this is the first car we have owned with such a system. I've read it could be binding. Does anyone else get this noise, or has anyone had this noise and had it investigated? I wouldn't say it's got any worse over the time we've owned the car. Thanks. Adrian.
They’re very effective. Drove down to in-laws with the kiddies and with the rear screen from @Tankdave and these, it was like being in a blacked-out limo in the back. 5 days from Order to Door from Australia is decent too.
BloodWorm started following CR170 Hard to start after replaced fuel tank.
Feeling frustrated. Following on from previous post. 2014 Superb Elegance TDi CR170 Back story. Ran over something in the road, punched a hole in the fuel tank. Mechanic replaced the tank with one I sourced from a breaker that included pump, gauge sender etc. Car was then hard to start. Mech thought maybe low fuel, so put half a tank in. Following day, it started but cranked for ages before it started. Drove fine for a while then gave me limp mode, flashing glow plug light etc. Code comes back as P008700 - fuel rail/system pressure too low. Checked getting fuel out of tank pump, and at filter housing (and was full to top), HPFP and rail but I have no idea if any of those are ‘in spec’. Fuel filter had 15,000km (9000 miles) on it so well within factory intervals but changed it anyways just in case but noted this time the housing was nearly empty. No sign of HPFP metal pieces. Still very hard to start if sitting for more than a minute but runs ok til you give it some stick - brings on limp mode about 4.5k rpm. Im usually pretty sedate driver, but tow a trailer fairly regularly so gave it some death to make sure it’s ok which its clearly not. Question is - could the tank pump be causing my issues? I have the old tank with pump, so can change it but I don’t know if it’s my problem. Otherwise it goes back to the mechanic on Monday. TIA
vanko joined the community
Ains changed their profile photo
Flat Battery in Key Fob - Warning
Update: I saw a low battery key warning on the screen last week... which kicked in my "change all the batteries now paranoia"! All 4 (3 keys and immobiliser fob) were swapped for new Duracell CR2032s, which I did annually on both previous VW Golfs, and it was also just before service, so another minor cost avoided. I tend to buy a pack of 10 from Amazon so I have them on hand, and ... they have a longer lifespan than their annual use.
