  2. Does anyone have a technique or tool suggestion for removing the rear brake pad carrier bolts on Octavia mark 4 1.5Tsi. I work on my drive with a trolley jack and axle stands. I have a breaker bar but I don't have clearance anywhere. Thanks for reading.
  3. Navigate to settings > system information
  4. Dear Sir, I am aware of this setting, but I am looking for a way to achieve a complete blackout. In another Skoda of mine, which is equipped with an MK2 Android 2DIN head unit, this feature can be activated by tapping an icon on the display. The screen goes completely dark—as if it were turned off—while the media continues to play in the background. With the setting you suggested, the instrument cluster also goes dark.🫠
  5. Sydwin joined the community
  6. Msybe I will add just tjus - it depends on size og the puncture. In my case it was indeed very small. Now I cannot even find it. Neverhless, one cannot ignore such incident and should contact tyre service shop.
  7. Arsal joined the community
  8. Was the new battery coded to the car after fitting? Thanks. AG Falco
  9. NO. You still need to plug the hole in the tread. Otherwise water gets in the tyre structure and rots the metal strands inside. Eventually the tyre become weak and will break up. Some people notice this as a vibration when moving slowly as the tyre develops a bulge at the weak point. A hole in the tread to the carcass is also an MOT fail for this reason. ( In the UK ) HTH. Thanks. AG Falco
  10. Today
  11. Hi, May be this post will help you: I didn't read it, but the pics let me think it could be very similar to your problem. Hope this helps.
  12. Fixing/bastardising something is way better than buying a new part. Half a lifetime ago I had a Nissan Bluebird with a near dead engine. While awaiting delivery of a long block, I re-tapped all the shagged threads on the camshaft to keep it running. Reckon I had the only Bluebird in the UK with a camshaft held on by 1/2" BSW bolts 😁 Keep up the good work 👍 G
  13. Khaledfawzy joined the community
  14. Long crank or reluctant restarts when engine up to temperature can often be due to failing crankshaft or camshaft position sensors - have you had the vehicle scanned for recorded DTCs?
  15. Nimrod2 replied to Nimrod2's topic in Škoda Kamiq
    Thank you. This is what I am hoping. I have asked for the VIN number so I can check it out. I know Skoda is reliable but just don't want to start with old parts of that makes sense. I am hoping the Kamiq will serve me well. I have had my current Skoda for 12 years so fingers crossed for this new one too. Then the next one will hopefully be a higher up SUV. I will be honest I preferred the look of the Honda HRV but wasn't overly impressed with the drive. Seemed to struggle with power on the acceleration and was noisy whereas the Kamiq was nippy even with it being 1.0.
  16. mac11irl replied to Nimrod2's topic in Škoda Kamiq
    this is the most likely explanation.
  17. tonashi joined the community
  18. PhiltheGreek joined the community
  19. Kenny R replied to Nimrod2's topic in Škoda Kamiq
    You really need to clear it up with the supplying dealer on what you are exactly getting. It could just be that it is referring to it being a 2024 on model, 2024 being when the Kamiq got a facelift, and it hasn’t changed since.
  20. MrsM joined the community
  21. Since the oil change to 5W 30W chain noise seems to be eliminated. I had plugs and the factory fitted leads replaced. Start up when hot is almost instant and cold start is with less revolutions of the engine. Idle when hot or cold is so smooth and quiet. So happy bunny.
  22. gthr joined the community
  23. ZacDaMan72 changed their profile photo
  24. Has anyone here replaced their Canton subwoofer with one from ARS24? The factory sub is a 6.5" dual voice coil 2x8Ω with 200W total - I'm not sure how bad it'll be to run the ROCK-8 D4 (2x4Ω, 200W total). 2x8Ω: https://www.ars24.com/option-rock-8-d8-subwoofer-im-reserverad-fuer-2-x-8-ohm-werks-subwoofer 2x4Ω: https://www.ars24.com/option-rock-8-d4-subwoofer-im-reserverad-auch-beats 2x2Ω: https://www.ars24.com/option-rock-8-d2-subwoofer-im-reserverad-fuer-beats I'm looking at these ones because they fit in the spare wheel quite nicely and use the factory plug so is fully plug & play.
  25. Nimrod2 started following Model help
  26. Nimrod2 posted a topic in Škoda Kamiq
    Can someone please help. I have purchased a car and only after being given the quote and paying the deposit and then receiving more paperwork did it show I am actually getting a 2024 model. Can someone please advise the difference in the 2024 model, 2026 model and 2027 model. I am concerned the car will have been sat somewhere for potentially 2 years. I was expecting the current year. Shouldn't I have been told if it isn't the current model? It is the Skoda Kamiq 1.0 Tsi automatic SE L edition
  27. Nimrod2 joined the community
  28. Yesterday
  29. @pab567 Request for MSTD_EU_SK_P6230 MU0490 Firmware. Thanks in advance !
  30. P S. in the interim I think I will switch start/stop off. I understand there's a button to switch off the system when setting off on a journey. No more rush hour embarrassment with a green light in front of me, hazard lights flashing and an angry queue behind me!
  31. mjasmin joined the community
  32. Thanks for your reply, useful to know it can be done by oneself, however I'm not too car DIY competent (cars have changed too much during my lifetime) so I might be better having the battery fitted and coded at a service agency. I'll get some prices fitted and coded and x chk cost of just getting a battery and the device you recommend, if it's quite different I might try updating my knowledge! Thanks again.
  33. best way is to top up canister with diesel before putting lid back on, you'll never get any problems with airlocks
  34. Been tightening up on car security, days of nobody steals skoda's are long gone, they steal everything and anything nowadays. Got a disklok, and moved the obd connector to a hidden place with one of these, it leaves a dummy obd in the original place and if scumbag plugs into it, it appears to work but no coding can be done. thinking about fitting a hidden kill switch as well
  35. If it's a front wheel drive Superb MK2 estate with standard ride height (ie. not lowered ride height or increased ride height), then fitting slightly stiffer rear springs such as two up in the hierarchy should solve the soft rear end problem when the car is loaded. As mentioned in my previous post the upgraded rear springs have OEM part number 3C0511115AF.
  36. Fairly sure its Torx, we tried Spline and Torx and torx got a much better grip, and all the tensioners for this engine have been torx, i think its just really stripped
