And 2 Warning LED each Side ^^
Karoq VCDS coding
Hi! I tried but nothing; any other suggestions?
laaroussikhammar joined the community
- [GUIDE] Activated Android Auto + Apple CarPlay on MIB2 Technisat for €0 (No dealer, no paid codes)
You’re more than welcome to for your car. This is my project to pass the time as my hobby on my car. If it works great. If not then I haven’t wasted a lot of money. It’s a nice to have. All of it is reversible.
In that case, I'd rather have OEM control units than the AliExpress knock-offs
Today I started the blind spot detection project. Trying out a basic AliExpress kit for £50 rather than OEM for £500. Bumper is a pain to remove thanks to two awkwardly angled torx screws under the wheel arch which requires the car jacked up to access. First problem after that was that the OEM radar brackets I bought from eBay to make mounting the radars easier didn’t fit. Turns out I had bought hatchback ones rather than estate so they didn’t fit! A bit of fettling and the brackets that came with the kit were made to fit, mounted onto one of the studs that holds the plastic trim on. All set to the correct angle. Cables routed into the car through a couple of grommets. Bumper back on and that’s the first stage done.
First Service Cost
Or you can go "All in" With an All-in Plan you can relax in the knowledge that you'll get two services, two MOTs, two years' Roadside Assistance, plus a free Warranty (when it's over 3yo)worth £626** for £959.76 Valid for vehicles with a 2.0L engine or less and under 100,000 miles at activation. Excludes electric vehicles and vehicles with an existing Service Plan. Vehicles that have been out of a warranty (that has been provided by Skoda UK or Skoda Financial Services) for more than 30 days will have a no-claim period of 30 days at the start of their All-in Plan. Volkswagen Group provides the All-in Warranty free of charge following purchase of an All-in Plan. The All-in Warranty does not cover any vehicle already covered under any other guarantee, insurance, warranty and/or gesture of goodwill. All-in Plan validity is dependent on required payments received. Škoda Financial Services.
Octavia IV Combi 2.0 TDI — 129 Hz droning above 125 km/h, temperature-dependent
@ilkosl thanks, this is exactly the kind of detailed reply I was hoping for — really helpful. First, answers to your questions: Roof bars — I only removed the crossbars; the longitudinal rails are factory-fitted and still on. Good point about the end caps, I'll tape those. Panoramic roof — no. Tow bar — yes, factory tow bar, but it was retracted during all my tests. Wheels — 16", never changed (205/60 R16). Grille shutter — I had a good look and I don't think I have one. I can't see any shutter mechanism or actuator behind the lower grille, just the radiator/intercooler directly. I'll confirm via VIN/PR codes through my dealer, but visually it doesn't look like I have active shutters. If that holds, the shutter can't be our common cause, since I get the drone without it. Dealer — yes, they drove it with me. The mechanic just said "it's the tyres" by ear, nothing measured. So I swapped the complete wheel set (summer → winter) myself — drone unchanged, same 129 Hz. No TPI/bulletin result was ever mentioned. I've since sent them a written report with the frequency analysis and asked them to escalate to Škoda and check for other reported cases. Two things seem to line up across the affected cars, and I'd like to narrow them down: DSG — mine is DSG (DQ381). Is everyone with the drone on DSG? Engine power — mine is 110 kW (150 PS). Can those of you with the drone confirm your output? @Gogich thanks — your 85 kW manual with no drone is a really useful data point. If it turns out everyone affected is 110 kW + DSG + Combi and the manual/lower-power cars are clear, that's a very specific pattern to take to Škoda. The higher-output DSG version has more to cool up front (gearbox oil cooler, higher heat load), which could change the airflow/thermal picture at speed on hot days — and would fit the temperature dependence without needing the shutter theory. Mine measures a fixed 129 Hz — if anyone can record and FFT theirs, let's see if we all land on the same frequency. Please do try the recording if you can; two or three independent measurements at 129 Hz in different countries would be very hard for Škoda to dismiss.
First Service Cost
New Rear Side Passenger Door - advice on where to get one?
New: Dealer or Skoda-parts.com (for around € 1100) Used: Scrap yard
How to find OEM part numbers of front wheel bearings for my Fabia 2
Some one might correct me, but if you don't already know, it tends to be the heads of the backing plate covers that get bonded with rust to the backing plates, once that bond is broken you should find that the threads are clean and the screws can be unscrewed by hand. Stupidly I considered that the same situation should/would be the same when taking the disc dust covers off my 2011 Audi S4 - not so, some design clown made sure that one screw hole was open at the back so I snapped one screw head off - I only did that on one side! Edit:- ah yes, the one that is tricky to get a tool onto - I had properly established what the correct size/version of bit was to fit onto the easier ones, then using the correct 1/4" bit, got that fitted into the cleaned out recess in that screw head, then wedged/jammed it down in there by driving maybe 2 small screwdrivers between the lower face of the hub and the top of the 1/4" hex bit - then used a small adjustable spanner to turn the 1/4" hex bit - that worked for the tricky one on each side.
First Service Cost
Stonekeeper started following First Service Cost
One of the screws isn't possible to get 'square onto' with bearing/hub in place, so a bugger to do anything with once corrosion has taken its toll on the head.
Thanks for the part numbers. You're right about back plates as mine have definitely seen better days. I was hoping to remove them to give me more access to the speed sensors but the screws were really badly corroded in and I was short on time as my wife needed the car. I'm going to order a pair of plates up and will probably end up drilling the screws out and retapping the threads.
bagoly joined the community
Ghost speed limits
Thanks again @Coral-C . I am looking forward to that feature for the pan-euro trips. It takes me time to learn the features of a car and for it to become part of my unconscious competence. It's at this point when I tend to enjoy the car most. The new car, excitement stage is great but frustrating at one and the same time. Unbelievably, I am still finding features in our Mercedes SLC200 which we have owned since 2017. AI helps tease these hidden features out from the car! Best wishes.
Ghost speed limits
Yes, lane following works and I leave it on. It's not full self-steering - you get about 30 seconds before it tells you to take over steering and automatically disengages. But I do find it useful for those busy moments in dense traffic when you could easily get distracted and drift out of lane. I believe you can have it in stick-shaker mode, where the wheel just vibrates if you are going to leave the lane, but I have it in full lane-following mode. In both cases, there's no intervention if you are indicating to change lane (unless it detects a car in the blind spot). There are mixed reports about it. Some like it, some switch it off. It's more aggressive and twitchy than the old Mk3 but I've seen similar reports from other brands' newer cars. On some urban roads, the wheel will jerk a little from time to time for no apparent reason. And it's not entirely happy if you adjust position within a lane to avoid a pothole or manhole cover. But on motorways and trunk roads, it is very good indeed. Overall, I prefer to leave it on - even around town for normal driving. It's not quite as smooth as the old Mk3's system, but it's perfectly adequate. I think you will find it useful, especially on your long trans-Europe runs.
First Service Cost
Evolution13, thanks for your very detailed response - I will shop around for a better and more appropriate service.
Karoq VCDS coding
Many thanks. I'll try this weekend.
Ghost speed limits
Thank you @Coral-C , much appreciated. That's very clear and seems to represent the sensible middle ground of technology serving the driver, rather than the other way around. One additional question, if I may: are you able to retain the lane centre function so that you don't need to constantly microcorrect the car as the motorway curves slightly etc? Or do you switch this off? I am kind of hoping this is a useful aid as it's not one I have had before on the Velar.
Ghost speed limits
Very much Skoda's fault for allowing the parent company to provide them with some total guff IT while VW & Audi has the crap sorted out much sooner. All to do with VW Group taking Software Development in-house.
Denis78 joined the community
Karoq gearbox doesn't creep?
You can drive spirited or like a driving god and have no jerkiness. but here the subject is just moving off in D or S. For some S suits as the rpm is sitting higher at idle. For crawling in traffic S can sometimes be the option to use as engine / dsg dependent it might not hunt between 1st and 2nd with a bit of pickup in speed from moving off to stopping again.
Skoda Yéti (2015 Manufacture Date) Infotainment Latest Firmware
I've spotted a thread on Facebook that pointed me towards using a Patch/Firmware (MST2_EU_SK_PQ_P0255T 5FPQSW255) update, found on MIB-helper, for the issue regarding the 00:00 (06:28 intermittently displayed) time display (when MFD time displays normally) for the MIB (standard) Bolero/Amundsen Infotainment system (relating to my 2015 plate Yeti). I can confirm this has fixed the problem (I suspect any later Firmware version will do the same but ver. P0253T is the latest official version on the MIB-helper page).
