  2. As mentioned previously on my Octavia it only needed the top hat seal although it came with an o ring as well. The top hat seal pushes firmly onto pipe and almost clicks into place. Its very easy to knock it off when trying to fit pipe into master. Just watch where it goes if it comes off. Took me a while to find it again. Hopefully will cure problem. Alasdair
  3. If you were to unplug the LIN connector from the alternator while engine is idling on driveway, that ought to trigger the charging system warning light, I would think?
  4. Why not, you can always return it to how it was if it fails. Just keep your old EEPROM dump on hand 😉
  5. The gloss black on my Mk 3 Octavia has gone dull, i’ve tried various polishes, with no real success. Anyone any ideas as to what to use to shine it again? Thanks
  6. Baxlin started following B pillar gloss black
  7. Once the work is complete. Switch on the ignition. Clear any existing faults, otherwise it will not be possible to exit the brake pad replacement mode.
  8. Whereabouts are you based?
  9. Probably wouldn't cause your issue with the alternator indicator light - but very likely to affect correct battery charging.
  10. Have you unplugged the connector of the pressure switch to examine inside it for oil leakage?
  11. Da hilft nur eine Knarre.. verlängerung.. evtl. Kreuzgelenk... Viel Kraft und ein Hammer. Die Scheibe sollte vorher locker geschlagen werden. Viel Kraftaufwand und Sehr Gutes Werkzeug (14er)
  12. Hi Superb 2.0 2014. CFGB. Noticed oil dilution just before engine proper exploded. Best guess is one faulty injector that let go and hydrolocked, but not sure. Had engine replaced. Inside what was left of existing engine was excellent, still crosshatched and crank bearings good Have replaced engine, 4 new injectors, had dpf cleaned. Still getting rapid oil dilution. Cant see anything untoward in VCDS Any experience of this anyone? Ta
  13. Intermittent oil pressure problem 2012 Fabia 1.2 12 engine. Random oil pressure light problem it seems to randomly come on, although more when going around a roundabout not sure if the relative though I get 3 beeps with 3 flashes, followed by 12 flashes, no beeping. The engine is high mileage, but no crank-type noises on start-up or when the pressure light is on. Tomorrow I plan to isolate the swich nd fit a temporary auxiliary buzzer. Anyone got any ideas? The oil level is just a shade above max; the oil is Drive-Tec 5 30, which I have used for the last few years with no problem
  14. Thank you very much for your help and advice! I've already ordered the parts from AUTODOC, and they're currently on their way. Once I've installed everything and tested the car, I'll come back and share some feedback on the repair and let you know if the problem has been solved.
  15. No it wasn’t. Its exactly same spec but different make. Would that affect the battery light?
  16. Yes. All went fine with caliper. It’s the carrier bolts that defeated me. If I were just changing pads I would have been fine. I need to change the rotor too and this cannot be removed unless one first removes the carrier. Two very tight bolts in very awkward position.
  17. Today
  18. Do you think it could be possible for a 2023 VW T-Cross with MEN2_EU_VWGPx_P2080L? The dealer wouldn't activate it for me. Currently an aftermarket radio is on the way but I would send it back if I get it running.
  19. Have a look in the display settings for a screensaver option, that will kick in after a short time of no activity. No idea if it has one but ye olde Karoq does.
  20. Rbz5416 started following Média display
  21. Karossuz joined the community
  22. about £288 including VAT fitted by local Skoda garage. I did think plastic fatigue after 8 years between freezing cold which it was this morning and a hot engine for hours end on a motorway which we did this summer going to Brittany and Paris. A lot of money for one small clip. A large convoluted part, as shown in the picture, but way more complicated than simple jubilee type clips and simple hoses and loads of space in the engine bay back in the day on minis and Morris Minors, MGBs etc where you could easily get at everything (perhaps not so down the back of a mini engine). So was it good value for money - well no not compared to back in the day.
  23. Have you wound the pistons back with a ODB tool ?
  24. Does anyone have a technique or tool suggestion for removing the rear brake pad carrier bolts on Octavia mark 4 1.5Tsi. I work on my drive with a trolley jack and axle stands. I have a breaker bar but I don't have clearance anywhere. Thanks for reading.
  25. Navigate to settings > system information
  26. Dear Sir, I am aware of this setting, but I am looking for a way to achieve a complete blackout. In another Skoda of mine, which is equipped with an MK2 Android 2DIN head unit, this feature can be activated by tapping an icon on the display. The screen goes completely dark—as if it were turned off—while the media continues to play in the background. With the setting you suggested, the instrument cluster also goes dark.🫠
  27. Sydwin joined the community
  28. Msybe I will add just tjus - it depends on size og the puncture. In my case it was indeed very small. Now I cannot even find it. Neverhless, one cannot ignore such incident and should contact tyre service shop.
  29. Arsal joined the community
  30. Was the new battery coded to the car after fitting? Thanks. AG Falco
