  2. neitherjohn38 joined the community
  3. Is the VCRN code displayed correct? Am I in the correct module?
  4. Between p200200 error and p0401 "Exhaust gas recirculation flow insufficient" it's looking like I need a new EGR cooler and low pressure valve My indy mechanic is fine with me supplying parts to fit - but I'm wondering how to ensure I deffo get the right part. Autodoc gives this selection for my CUNA, 184HP MY16 Scout, but I'm wondering if there is a way to make absolutely sure I order the right part via VIN https://www.autodoc.co.uk/car-parts/cooler-egr-13337/skoda/octavia/octavia-combi-5e5/59679-2-0-tdi-rs?fromSearch=1 I think I'd be erring towards this Mahle part - in fairness - based mostly on vibes rather than any kinda expertise! https://www.autodoc.co.uk/mahle-original/15289375 I'm also a bit unsure as to if I need gasket set from somewhere and if so, I've struggled to find those parts! I's welcome any anvice folks Cheers! Jono
  5. Hi, I've recently had an almost identical experience with my 2016 TDi: Air con stopped blowing cold suddenly, went to a garage in Bristol (BS3 Motors) that found the Air Quality Sensor fault code, regassed, said there were no obvious leaks then suggested replacing the sensor for about £220 including 90 mins labour. I ordered a cheap Chinese part online and fitted it myself with no tools apart from a small screwdriver in less than 10 mins. This threw up various error codes, so got a German made Hella part instead (Skoda-Parts.com were helpful and only charged the difference in price without asking for the dodgy part to be returned - you might say they shouldn't have stocked the Chinese part, but to be fair I think I knew I was taking a bit of a risk buying it!) All the error codes are now resolved, but although the fan is working away, the air is, alas, still not conditioned! I left BS3 Motors a not very complementary review. Although I think it was completely fair, and quite moderately worded, I don't suppose they would welcome me back, even if I trusted them - which of course I don't. Any suggestions of: a) anything I might be able to check myself as an incompetent DIYer? b) any garage in or around Bristol that knows what the are doing with air con?
  6. some shops still offer kit E10-79-012-04-22 (F11-85-042-03-FA + F11-79-008-01-HA) for AWD Superbs Mk3 -> https://www.eibachshop.co.uk/products/eibach-pro-kit-lowering-springs-e10-79-012-04-22 when i order for my previous FWD, i was sure it's from AWD, because that were the goal, avoid huge lowering as with FWD springs the main question is, how springs with the same number can be that different? p.s. have you try rotate spring around its axle?
  7. Might be a wiring/connector issue to the throttle body. It may be that when new the pins make decent contact but if plug on wiring loom end is loose/coroded/worn pins over time may be breaking contact and causing problem. The p242c is either the EGT sensor iss failing or perhaps broken wires. Alasdair
  8. Might be the disk shield thats touching slighty. Mine are fairly rusty and weak and can sometimes make contact or your pads have an audible wear indicator thats touching disk. Check the thickness of pads inner and outer. Alasdair
  9. Today
  10. The car has updated, despite being in a concrete garage during the process, it informed me of the item being updated, job done, or so I thought until I started driving off up came that familiar message again, yes it wanted to do another update, I was driving so I didnt press update, neither did I press 'later', info was not available while driving, did the shopping but the update message has not, as yet, reappeared
  11. @Cairus thank you very much, will try that
  12. xdfxde joined the community
  13. I’ve ordered the edition with relax package. I need the lease ASAP for tax reasons so took a gamble. Don’t know when it’s coming, will feedback!
  14. Hi Admir, I've just joined too. Good luck, I've got a 2023 Karog S line diesel. What are you driving? Sam
  15. I've bought the same Eibach pro kit and my rear spring is hitting the rear droplink aswell without any load! It's doing my head in. as mines is an estate do i go for F11-15-007-04-HA or F11-85-016-10-HA? Not sure i coudl return the kit now as its been installed for 6 months! lol.
  16. Firemansamc joined the community
  17. The Leon needed a little TLC; it wasn't running smoothly anymore, especially at idle. So, I pulled out the spark plugs and coils to check the combustion pattern... It turned out cylinder 2 looked like it had been wet at some point. I installed four new NGK plugs and coils, and now it runs silky smooth again.
  18. So, the passenger side is installed. Mirror lowering is active. For the driver's side, I have a genuine Skoda glass available for €60 including shipping. But I’m going to see if I can get hold of a complete mirror assembly instead. The plan is to get everything finished this year.
  19. Lee01 replied to Lee01's topic in Motoring News
    https://www.skoda-storyboard.com/en/emobility/even-opening-the-door-is-an-experience-says-the-designer-of-the-peaq-suv/ Škoda StoryboardŠkoda Epiq Will Win You Over in Just a Few Seconds - Škod...Compact, smart, confident and stylish. The new all-electric Škoda Epiq offers a host of features that will quickly win you over. Get to know it in the video.
  20. @Nipa Does switching on the Fog light as you reverse into your drive help any? As to fogged windows & mirrors, time to get your glass well cleaned, FoG X, Rain X , or Clear Vue etc on the glass and Damp traps in the car. Cut down on the danger anyplace not just reversing into your drive. Maybe clean the glass before driving or reversing. PS putting some Solar lighting in your drive might be 'Simply Clever'.
  21. He found that the grinding noise was coming from the front part of that ''skirt'', every time i was in reverse in an uhill it was touching the pulley producing that horrible noise. Some hammer work from him (yes i know it's cruel but...) and things went back to normal. If a fellow Skodian faces the same problem in the past, now knows where to look.
  22. In my posting above perhaps I should have made it clearer that the light-units I arrowed as being LEDs did not have LED BULBS in them when I said: LEDs are used in the two number-plate light-units and (on the right side of the hatch) in the fog=light/reversing-light unit. The light-unit on the left side of the hatch is a dummy and has no LEDs in it. Left-hand-drive models will have a LED fog=light/reversing-light unit on the left side of the hatch and the light-unit on the right side of the hatch will be a dummy. with no LEDs in it. On the car's 'hatch', only one of the fog-light/reversing-light units is operative (the right unit of RHD cars or the left unit of LHD cars). The fog-light and reversing-light outputs come from small individual LEDs. (There are four separate LEDs in the reversing light-unit and these are visible if you shine a torch into the underside of the reversing-light's reflector). The units are 'sealed' and neither the fog-light nor the reversing -light can be upgraded by fitting higher-output LED bulbs. I agree that the reversing-light's output is poor and I'd like a reversing-light on both sides of the hatch - but that's the way it is. LED bulbs could be fitted in the outer rear light-units, but this would be illegal in the UK. It's also near certain that replacing any of the 3 halogen bulbs in each light-unit with a LED-bulb equivalent would trigger a dashboard 'light failure' warning. I've thought about replacing the boot-light W5W halogen bulb with a LED equivalent (as I did with my Hyundai i20) as the boot-light gets pretty hot, but I probably shan't bother. For spare rear-light bulbs, I managed to obtain a pair of OSRAM "ULTRA LIFE" W5W and P21W bulbs reasonably cheaply, but finding a good quality inexpensive WY16W bulb has proved trickier and I'll probably opt for a Halfords bulb if I'm passing one of their branches.
  23. Before the summer holidays, I had asked the mechanic to inspect the car from under (suspension, rubber boots, potential coolant or oil leaks, etc.). He did so, and (as I’ve mentioned in another thread) he found a loose lower coolant hose and replaced it. I took the car and drove about 200 kilometers to my holiday destination, but one morning, while reversing to pull out of my parking spot, I heard a hair-raising noise (grrrzzzt). I was surprised because I couldn't immediately pinpoint exactly where underneath the vehicle the sound was coming from, and unfortunately, the situation worsened day by day. The steeper the incline when i reversed, the louder the noise became, whereas on flat ground, there was no sound at all ! Unfortunately, there was no repair shop there, so when I returned the next day, i took the car to another mechanic,he put it on the lift, and we both went underneath to see what was going on. The noise was coming from the front right side of the engine,in english may call it ''cover'' but in every day Greek the mechanics call it ''skirt" or ''protective skirt". The photos are lousy because i was sin a hurry but you can get an idea.
  24. Coverage will be delivered as a collaboration between BBC Scotland Cymru Wales & Northern Ireland. There will be coverage of the New Rally Scotland in 2027. http://rallyscotland.org
  25. philbes replied to Gayrisafi's topic in Skoda Karoq
    The seat won't go low enough to restrict my visibility. My legs are nowhere near straight. I see many drivers (mainly woman) seating so low that they can only just see over the steering wheel. Look at drivers driving towards you and with some you won't see below their nose.
  26. Many thanks both. I too wondered if this may be the case, so I deleted my phone's bluetooth connection but it still wouldn't connect. As a further insight, I found that the phone's bluetooth is v5.2; so it still may be, despite the head unit quoting that it will support v4.1 and above, related to the version of bluetooth in the MP3 player.
  27. FrancesBSchulz joined the community
  28. Just to update, although it appears that I'm the only one affected. Skoda's next position was that they'd identified the issue with the map data & that it would be fixed in the next map update. Map update came & went with no fix. They then decided they could only fix it by supplying a secret solution to a dealer. Wouldn't disclose what the fix comprised of & wouldn't commit to covering the cost under warranty. Collected the car Wednesday after the ball ache of getting to/from the dealer by public transport. Dealer said they'd applied a service bulletin fix & updated "numerous modules". The end result of which is...absolutely no change. The only positive is that Skoda covered the cost,
  29. Soll joined the community
  30. If the battery is new and good was it coded when fitted? It does sound like a voltage drop so if battery is reading 12.5-12.8v and doesn't drop too low while cranking it may be a bad earth. Check the main one from battery to chassis first and also check starter connections/earth. Not sure if you have had it scanned for codes but maybe VCDS might ping something up the garage has missed. Alasdair
  31. Well something of note has been downloaded to our 24 Reg SEL - one of my major gripes has been the brief ‘on screen’ warnings, one bong and no more than 2 seconds on screen - I had to be quick to see what the fuss was about - last night however I was treated to three bongs and five seconds or so on screen - sufficient time to actually read what was up, turned out to be the all too common ‘drive in the centre of the road’ warning…….
