  2. @Evolution13 not really groundhog day, it's horses for courses, vans that are used for light duty are fine as EVs for most councils, but not so for the trades dept where Transists, Sprinters etc are the order of the day to carry 8x4 sheets of plasterboard plywood etc along with loads of heavy tools etc. My HA has a mix of both types for exap Mp
  3. Bluetooth is A2DP/AVRCP BT6506 Hardware is Part no. 5Q00035874A H24 Software 0245 Navigation Part no. 5L0051236E 0430 ECE 2015/16 Media codec 2101.0.0.10 one of those must mean something!
  4. Please supply the jetb weight of your petrol Skoda ? Think my Scenic is 1746 kgs kerb weight. Be amazed if it is 300 kgs difference. 70 decibels is on the quietish for any tyre and is measured external in the noise tests as I understand. I have tge nice slim 205/55R19s on my Scenic. Cheapish to replace and its looking like none will need replacing in its 4 year PCP period as wear is so low. New current version of the Scenic has a minimum of 220 hp, mines 170 hp, so i hope it does wear tyres faster. Even with 67 KWh LFP battery I don't think it weights more than a few Kgs more. Which engine do you gave in your Skoda ?
  5. It's likely that the cp4 pump gave out, or that the DPF is full and needs to be replaced. To give you a price would be ridiculous, as I cannot properly diagnose your car from Germany and I have very little information about your car. Both options are expensive, but not the only possibilities.
  6. Have a nice continuation of a bri-Skoda journey!!
  7. leolito started following Changing Cars
  8. Groundhog day again. The Councils / Local Authority discussion was done several times here. Location location location. There will be councils where VANS have to do lots of miles in a day, and others that might just be a city and the miles their vehicles might not be so much. Getting BEV,s into the mix is just a case of what the Local Authority is prepared to sort out as far as economics and efficiency and meeting the Net Zero targets that they need to be meeting.
  9. Hi fellow SKODA owners. My 2012 Superb 2.0 TDi 170CR with 203K on the clock sadly let me down whilst returning from France last week. Having effortlessly carried us to the South of France we disappointingly broke down on the way home just 30 miles into our journey but 800 miles from home. After being recovered to the nearest recovery depot we duly made alternative arrangements to get home to then start the process of dealing with our breakdown cover which happens to the AA through SKODA Assist. The first surprise was to be told that our car would be repaired through the SKODA Warranty. This came as a surprise as servicing at the local SKODA dealer ended a long time ago to be replaced by me carrying out routine servicing and more involved jobs such as clutches etc to be handled by my trusted local specialist. All I had done had maintained my breakdown cover with Skoda Assist ever since they wrote to me when the car was 3 years old. Who was I to argue if someone else was going to pay. It all started to unravel when I was told that SKODA in France do not offer the reciprocal arrangement and anyway the nearest dealer in Beziers has a 3 month waiting time for repairs. To date I have not been able to get an accurate diagnosis as to what the problem is and I need to make a decision whether to get the vehicle back to the UK and repaired. To complicate matters the current market value of the car is less than the cost of repatriation. I have the option to repatriate the car myself for which I will be reimbursed up to the value of the car. Having looked at the cost of doing so I can do so without putting my own hand in my pocket. The problem is that the breakdown cover will only reimburse my out of pocket expenses for getting the car back home once I can prove the car has been repaired. All I can share here is what happened. Car was running absolutely fine, we were on the motorway sitting happily at 70mph with the cruise control on when without any indication ie. noise etc we started to slow down. My first reaction was to put my foot on the pedal but with no response. Looking at the dash the glow plug warning light was flashing. Thankfully we were going downhill and were able to free wheel into an SOS layby. Having stopped I briefly tried to start the engine but to no avail. Does anyone have any suggestions as to what could be the problem. If it's a problem that is £1500-2000k or above then the car will most likely be left in France. The car has been brilliant but is nearly 14 years old and has done 203K miles. The mileage does not put me off and since I know the car and that it has never let me down I would prefer to keep it running. Some might think I am being sentimental but to buy a 3 or 4 year old replacement that has all the same features as the one I have will cost me £30K. Any help would be appreciated.
  10. EV weight may be coming down but they are still heavy - eg your 'lightweight' French Renault Scenic is heavier than my 'heavy' German petrol Kodiaq by a margin of around 300kg. In terms of tyres - yes they are designed to be quiet inside the car - hence the absorbing foam etc... BUT... the drive-by noise rating remains largely the same for similar tyre sizes - eg both the Michelin Primacy 4 and Michelin Primacy-e in 235/50R19 size both have a noise rating of 70dB. I think you may be seeing what you want to see, as opposed to what is actually being seen?
  11. Following on from my earlier post, one of my colleagues has exactly the same car as mine, he has no issues with the brakes on his and the front wheels on his car collect quite a bit of brake dust, mine dont, despite some ‘spirited’ driving. I can only assume that like all manufacturers Skoda have more than one supplier of brake components including pads, and the compounds are probably not the same, which would explain the differing driving experiences that seem to be prevalent amongst owners. If it were my own car i would be changing the pads, probably to Brembo, to see what difference it makes.
  12. Two companies I have been most associated with are Ceva and DPD and Ceva are looking to bring the Windrose trucks to the UK and I presume the frightening increasing in diesel costs and strong desire to go to lower carbon footprint the Ceva UK fleet is predominately running on HVO rather than diesel. Can be a little more than diesel and is erratic pricing. Hope to see the Windrose EV HGVs on the road soon but I am sure they will want to test in cooler weather but Windrose has already done much of this and truck has 800v architecture and charging is very good in the chargers are there which is something Uk government working on with Gridserve and others to hit the 2040 deadline of all trucks being electric..... https://www.gridserve.com/electric-freightway/ https://www.cevalogistics.com/en/news-and-media/newsroom/press-release/ceva-uk-investment-low-emission-fleet DPD also breaking out from EV delivery vans not just being mainly cities..... DPD UK is expanding its electric van fleet with 341 new Mercedes-Benz eSprinters, taking the parcel carrier’s total number of electric vehicles to more than 4,000. The first vans are due to enter service in September, with the full batch scheduled to be operational by the end of October. They will be deployed both within the M25 and at locations elsewhere in the UK, ahead of the company’s peak Christmas delivery period. DPD said the new vehicles will allow it to extend the use of larger electric vans beyond the inner-city areas where much of its EV fleet has so far been concentrated. According to the company, its electric vehicles currently operate across more than 7,300 UK postcodes. In 2025, DPD delivered more than 85 million parcels using electric vehicles, including a predominantly diesel-free final-mile operation within London’s North and South Circular roads. Olly Craughan, head of sustainability at DPD UK, said larger panel vans remain central to the company’s final-mile operation. "The eSprinters can carry the same payload as the equivalent 3.5t diesel while the new battery technology and improved range mean more of our depots can start deploying larger EVs further afield,” he said". DPD pushes electric vans beyond city centres with hundred...DPD pushes electric vans beyond city centres with hundreds-strong order
  13. Today
  14. Can't pm, sorry i'm too new, could you message me?
  15. Still available, pm if interested.
  16. @commievid how's the alu subframe? Its starting to fall on my radar so want to get some proper feedback.
  17. As i mentioned above, I think it is a matter of model, or specific piece, as, referring to my selection model, ventilation is pretty active...I personally use 2nd scale throughout summer, here in Greece, where it is enough to keep body dry and cool...3rd scale is too much, activated only in harsh conditions...1st scale is pretty mediocre though....maybe the nature of the material...I don t know if vrs is real leather , or it is leatherette partially, or completely....e.g. selection seats are leather in the middle where body sits and touches, where there is leatherette, at the rest of the seat....
  18. Was that MK1 or Mk2, perhaps it's a MK2 thing?
  19. My experience with a previous Kodiaq L&K was quite different. The vented seats on that car when turned to max got cold very quickly, so quickly that it didn't take long for me to turn them down, even on very hot summer days. Given the weather most months in the UK vented seats are not exactly a must have.
  20. Hi. I have Skoda Scala 2020. I bought geniune rear camera for my car from skoda-parts. There is a fitting instructions in my order. I have a question for connectivitiy cables. I connected cable in blue socket thats ok. But now how i will other cables apply which socket because fitting instructions shows BCM to apply other cables or do i need canbus cable like i add attachment? Because there is no canbus cable in my parcel. I find BCM location and i know C socket. Please anyone tell me which one canbus pin cables? Or send me picture or like that. Thank you.
  21. Think I have settled on Goodyear EfficientGrip Performance 2 205/55 R17 V (95), the variant that has an A rating for both fuel efficiency and wet braking. I've got my local Tyre fitter, who is 2 minutes away, to do all four tyres for £500, which doesn't seem bad. Here's a link for the specific tyre: https://www.blackcircles.com/brands/goodyear/efficientgrip-performance-2/205-55-r17-v-95?tyre=48109058
  22. This, and as somebody who this summer took delivery of a brand new Kodiaq after test driving a multitude of other manufacturers (a special mention to Kia who make it infuriating, with the settings buried behind 4x menus!), the ADAS systems on Skoda aren't anywhere near as intrusive as other brands. 2x (or 3x if you want lane assist off also) quick presses of a button on the steering wheel and it's off. No rooting around menus. We have it easy.
  23. You need 308, not 306. 308 supports almost all previous versions as you can see here Pretty sure you can get it from mibsolution as well but if not I have a mega link with a version here. once you go to 308 you can springboard straight o v332 which is the latest version widely available. We're on the cusp of v334 coming out but that hasn't been uploaded anywhere I can see
  24. Hi Mate New here too Have Octavia Mk iV estate Pretty useful size wise for my range of tools
