exterior lighting showing on info screen
ATE Ceramic Front Brake Pads - Skoda and Other VAG
- Rust around fuel filler door
It is ridiculous. The rust has only just started. It hasn't been serviced by Skoda for the last few years but even if it had they wouldn't have spotted the rust nearly a year before it appeared.- Skoda tow bar for vRS Combo
If it has trailer prep then the wiring to the control module & to the switch is already present- Kamiq seat question.
No in Germany. Well, we were ordering but decided against the Kamiq and picked up an Ateca yesterday. No idea why the electric seat option isn't available in the UK 🤷 Cheers for the reply though, appreciated 👍- Rust around fuel filler door
Up till 2012 or so with Service Books there was 2 pages after the service page with a car diagram and you put where any damage was on the vehicle. Poor repair or no repair. Then it went to being done on a palm top device. This carry on with a Free Car Wash after a service. It should be done before a service and that person should be trained to spot damage not cause it, or the tech then has a clean car to check. Outside and under when on the ramp. Body inspections are like road tests at a service. False pretences / fraud by main dealers that charge a premium and the Manufacturers / importers conspiring in the deception- Proactive Passenger Protection alarm
Hey john. Thanks for that very comprehensive update. I was towing myself at the weekend and the passenger protective system fired off many times, which, apart from being potentially dangerous, really ****ed me off. If I was offered a skoda retractable towbar I would get it done in a moment. In fact I'm going to chance my arm with skoda and see how I get on. But for you....happy towing.- Which Octavia Scout would you choose?
Sadly even with a brand new car which has supposedly had a PDI done by a trained person it is important to check levels at hand over then when home or next day to compare. Also tyre pressures because if they are set poorly or never set then that gives an idea of the dudes / dudettes being hopeless and not giving a damn.- Front park assist retrofit help required!
If the other module doesn’t work then it may well be cheaper to buy one and get you to connect than get a garage to code it! I will consider it. Although I’m not sure there’s any other retrofits I will do that will need it.- Front park assist retrofit help required!
You make a Lot by the car , buy a vnci Red- Which Octavia Scout would you choose?
Here's hoping there was enough oil left in the sump to avoid any damage to the engine by the time you arrived home!- Button panel adding functions
I have been looking at this too and I don’t think you can just add the extra buttons. If you look on the back of the buttons you will see 10 pins (two rows of 5). On my car (a mk 3 scout) it looked like the wires on the car side are not there. Not sure where the other side of the wires would end up the ECU maybe, maybe wiring diagram would help.Tea4Me started following Button panel adding functions- Front park assist retrofit help required!
Some progress made. I thought while I wait for the new module come I would do some fault finding on the sensors. Luckily I started fault finding at the plug end. Starting by checking pinout. It would seem my eyes are not very good at distinguishing between 10 and 18 and I’d managed to pin one side of the plug backwards. Repinned it and now just the dataset faults remain. Hopefully the swapping if module corrects this.- Rust around fuel filler door
The Skoda response really is just bull**** - it's clearly a corrosion issue and has absolutely nothing to do with whether mechanical parts were serviced or not... We've had Skoda's for 25 years now and I don't recall them EVER doing a bodywork inspection as part of servicing.- Unexpected Consequences
Is your 2025 Octavia is a facelift model? I’d assume so, else it’d be one of the last of the pre-fl models. What is your query about traffic and road closures? Mine has done that from day 1; really quite helpful. Maybe a function of your user permissions - something to do with location 🤷♂️ On my pre-fl car there is a setting to save the PIN in the infotainment system; yes, reduces security a bit but massively reduces the faff! I leave my climate control on Auto, with temps set at 21C +/-1; the car retains that setting. IIRC, that syncs to the Škoda servers ‘cos on the rare occasion my wife drives it as her user and sets different temperatures it sets back to my preference when my user is selected.SteveTheElder started following Unexpected Consequences- Today
Yes but no I didn't check under the bonnet before I drove away. Should I need to? It was the seal with the oil fitter that hadn't seated correctly. All sorted now, fingers crossed. Nope, I refer you to my other to save typing them out again.- Which Octavia Scout would you choose?
Nope. If it had appeared, I'd have dipped the clutch and killed the engine. All sorted. When the garage changed the oil fitter, the seal hadn't seated properly. Were they just careless?- Rust around fuel filler door
Skoda , Seat and VW UK and Germany, Spain and Czechia know a fundamental design and manufacturing fault and the corrosion comes from behind the metal and owner sees and behind the paint. So the have had 17 years to be sure Dealership employees check while doing body inspections. Issue a TPI /TSB. What ever some desk jockey says about not being corrosion is just the usual P!$$ take from their Customer Services / Warranty contractors.- the truth about electric cars
Blimey that Alpine is ugly! Too much 'addenda' at the front and the wheels are awful! All in my opinion of course...- Coasting
on previous 2016 Mk3 TSI 220ps DQ250 FWD i coasting by default were present only in E on current 2023 Mk3.FL TSI 280ps DQ381 AWD it were also in D, had to code it out -> https://www.briskoda.net/forums/topic/516414-vcds-options-on-superb-iiifl/- Kamiq service/warranty question
Our Kamiq was a bit late for its second service as the dealers leadtime was bonkers. Dealer assured us it'd be fine (famous last words). However if the car was on longlife servicing then it could go 2yrs between services (18500 miles) so I don't see why it should be problem. I suppose, as the first service is basically just an oil change and the second is a more extended inspection, then they might say the inspection is overdue.- Octavia WRC 100 Edition No 73/100 Reluctantly FOR SALE
Hello vRS WRC fans. I want to buy a new white carpet. Is it still possible to buy a new one in England? What is the part number? I have 65/100. Thank you very muchRichardos started following Octavia WRC 100 Edition No 73/100 Reluctantly FOR SALE- Trip mileage
There is three trips. Since refuel. Since start (which seems more like a "today" trip and then long term. The long term can be reset by the driver. I wondered the same thing myself when I set off for holiday a couple of weeks ago.FOSTER91 started following Trip mileage- WRC 66/100 and 88/100
Hello vRS WRC fans. I want to buy a new white center carpet. Do you know the part number? Is it still available in England? I own a 65/100. Thank you very much.Richardos started following WRC 66/100 and 88/100- Mk1 Octavia WRC Limited Edition No 73 of 100 for sale
Hi, please, I need new white carpet. What is the part number? Is it still available in England? I have the number 65/100 - Rust around fuel filler door
