  2. The gloss black on my Mk 3 Octavia has gone dull, i’ve tried various polishes, with no real success. Anyone any ideas as to what to use to shine it again? Thanks
  3. Baxlin started following B pillar gloss black
  4. Once the work is complete. Switch on the ignition. Clear any existing faults, otherwise it will not be possible to exit the brake pad replacement mode.
  5. Whereabouts are you based?
  6. Probably wouldn't cause your issue with the alternator indicator light - but very likely to affect correct battery charging.
  7. Have you unplugged the connector of the pressure switch to examine inside it for oil leakage?
  8. Da hilft nur eine Knarre.. verlängerung.. evtl. Kreuzgelenk... Viel Kraft und ein Hammer. Die Scheibe sollte vorher locker geschlagen werden. Viel Kraftaufwand und Sehr Gutes Werkzeug (14er)
  9. Hi Superb 2.0 2014. CFGB. Noticed oil dilution just before engine proper exploded. Best guess is one faulty injector that let go and hydrolocked, but not sure. Had engine replaced. Inside what was left of existing engine was excellent, still crosshatched and crank bearings good Have replaced engine, 4 new injectors, had dpf cleaned. Still getting rapid oil dilution. Cant see anything untoward in VCDS Any experience of this anyone? Ta
  10. Intermittent oil pressure problem 2012 Fabia 1.2 12 engine. Random oil pressure light problem it seems to randomly come on, although more when going around a roundabout not sure if the relative though I get 3 beeps with 3 flashes, followed by 12 flashes, no beeping. The engine is high mileage, but no crank-type noises on start-up or when the pressure light is on. Tomorrow I plan to isolate the swich nd fit a temporary auxiliary buzzer. Anyone got any ideas? The oil level is just a shade above max; the oil is Drive-Tec 5 30, which I have used for the last few years with no problem
  11. Thank you very much for your help and advice! I've already ordered the parts from AUTODOC, and they're currently on their way. Once I've installed everything and tested the car, I'll come back and share some feedback on the repair and let you know if the problem has been solved.
  12. No it wasn’t. Its exactly same spec but different make. Would that affect the battery light?
  13. Yes. All went fine with caliper. It’s the carrier bolts that defeated me. If I were just changing pads I would have been fine. I need to change the rotor too and this cannot be removed unless one first removes the carrier. Two very tight bolts in very awkward position.
  14. Have a look in the display settings for a screensaver option, that will kick in after a short time of no activity. No idea if it has one but ye olde Karoq does.
  15. Rbz5416 started following Média display
  16. Karossuz joined the community
  17. about £288 including VAT fitted by local Skoda garage. I did think plastic fatigue after 8 years between freezing cold which it was this morning and a hot engine for hours end on a motorway which we did this summer going to Brittany and Paris. A lot of money for one small clip. A large convoluted part, as shown in the picture, but way more complicated than simple jubilee type clips and simple hoses and loads of space in the engine bay back in the day on minis and Morris Minors, MGBs etc where you could easily get at everything (perhaps not so down the back of a mini engine). So was it good value for money - well no not compared to back in the day.
  18. Have you wound the pistons back with a ODB tool ?
  19. Today
  20. Does anyone have a technique or tool suggestion for removing the rear brake pad carrier bolts on Octavia mark 4 1.5Tsi. I work on my drive with a trolley jack and axle stands. I have a breaker bar but I don't have clearance anywhere. Thanks for reading.
  21. Navigate to settings > system information
  22. Dear Sir, I am aware of this setting, but I am looking for a way to achieve a complete blackout. In another Skoda of mine, which is equipped with an MK2 Android 2DIN head unit, this feature can be activated by tapping an icon on the display. The screen goes completely dark—as if it were turned off—while the media continues to play in the background. With the setting you suggested, the instrument cluster also goes dark.🫠
  23. Sydwin joined the community
  24. Msybe I will add just tjus - it depends on size og the puncture. In my case it was indeed very small. Now I cannot even find it. Neverhless, one cannot ignore such incident and should contact tyre service shop.
  25. Arsal joined the community
  26. Was the new battery coded to the car after fitting? Thanks. AG Falco
  27. NO. You still need to plug the hole in the tread. Otherwise water gets in the tyre structure and rots the metal strands inside. Eventually the tyre become weak and will break up. Some people notice this as a vibration when moving slowly as the tyre develops a bulge at the weak point. A hole in the tread to the carcass is also an MOT fail for this reason. ( In the UK ) HTH. Thanks. AG Falco
  28. Hi, May be this post will help you: I didn't read it, but the pics let me think it could be very similar to your problem. Hope this helps.
  29. Fixing/bastardising something is way better than buying a new part. Half a lifetime ago I had a Nissan Bluebird with a near dead engine. While awaiting delivery of a long block, I re-tapped all the shagged threads on the camshaft to keep it running. Reckon I had the only Bluebird in the UK with a camshaft held on by 1/2" BSW bolts 😁 Keep up the good work 👍 G
  30. Khaledfawzy joined the community
  31. Long crank or reluctant restarts when engine up to temperature can often be due to failing crankshaft or camshaft position sensors - have you had the vehicle scanned for recorded DTCs?
  32. Nimrod2 replied to Nimrod2's topic in Škoda Kamiq
    Thank you. This is what I am hoping. I have asked for the VIN number so I can check it out. I know Skoda is reliable but just don't want to start with old parts of that makes sense. I am hoping the Kamiq will serve me well. I have had my current Skoda for 12 years so fingers crossed for this new one too. Then the next one will hopefully be a higher up SUV. I will be honest I preferred the look of the Honda HRV but wasn't overly impressed with the drive. Seemed to struggle with power on the acceleration and was noisy whereas the Kamiq was nippy even with it being 1.0.
