Strange warning lights
When my car did this it was due to water condensation in the car and was cleared by drying out the interior. Yours looks more like the condensation may have been there for some time and has corroded a connection, possibly the connections to the cluster.
Mulfuncion of servo steering wheel, ABS, Traction control, TPMS, parking senzors (maybe more :) )
Hello! I'm talking about Skoda Octavia mk3, 2014, CKFC engine, 4x4 (not scout). First coldish morning after summer I had small problem with starting up the engine. It wasn't cranking to start up, but it took 2-3 seconds more than usually. Slight after engine was running few warning lights turned on; servo steering wheel, ABS, Traction control, TPMS, parking senors, hill hold (there isn't warning for that for that, but it doesn't work). Engine works OK, no check engine light, no vibrations, no extra noise. Of course I thought about bad battery. Later on I started engine again, same thing. I changed battery and re-calibrate BMS, same. Meanwhile i checked all fuses. All of them are OK. Maybe corrosion on GND? Anyone with same experiences? How did you solve them? Any other idea? I appreciate for all the answers!
MikeTheThinker started following Front nearside wing replacement Superbb 2017
Square Reflector Bulb Covers - inside rear light clusters (Superb Mk3 sportline)
Hello. I'm looking to replace the light on a superb 2017, mk3, sportline, TSI 4x4. Child 1 reversed into it and cracked it. (Passenger side / UK) The current version has part numbers: 3V9.945.207/ 3v9.945.207.A/ 3V9.945.711/ 3V9.945.711. B./ Inside the currently fitted version, are some square bulb reflectors. (see image) which hide the bulbs from direct view and appear to be clipped inside the rear cluster. I've just got a replacement from ebay, identical part number as above, but without these bulb covers clipped inside. Q1. Have i got the wrong light cluster ? Q2. Can I swap them over and add them to replacement cluster ? If so, how do I open up the rear light cluster ? There are a few hex-screws on the back of the light cluster... Any help and advice - hugely appreciated.
- Front nearside wing replacement Superbb 2017
the truth about electric cars
@Evolution13, just maybe they should have thought a bit more seriously about letting most of the UK, production jobs leave these shores for China years ago in the pursuit of even greater profits. By allowing that to happen they just handed the vice grip that a foreign power could if they so wished, use against us.
sub123 joined the community
MCollings started following Front nearside wing replacement Superbb 2017
MCollings joined the community
TYres - any comments on wear patterns?
In my experience, even running the tyres at 'Eco' pressures does not result in a 'harsh ride' on either the Octavia or Fabia - on 16" wheels.
Warrior193 started following TYres - any comments on wear patterns?
Software update groundhog day
Yes, that's it, many thanks. I guess it's a wait and see game now.
Gowna joined the community
Considering a Sportline
Hi @dan245 I had a Octavia vRS CR DSG for 13 years. Loved the car and covered 139k mostly trouble free miles in it. April '25 I changed it for a '23 (73 plate) Karoq 2.0 tsi Sport line. I also tow a caravan with both. What I liked about the Octavia: Looks good 😊 Fuel consumption. Solo 50+, towing 30 Boot size Comfortable seats How does the Karoq compare: It's a mid sized SUV, personally I prefer the look of the Octavia hatch Fuel consumption whilst not as good solo it's only 1 or 2 mpg less when towing. The cheaper unleaded offsets this. The boot on the Karoq is easier to load (I have a spare wheel so a false floor) but it is smaller than the Octavia. Seats are more comfortable than the Octavia The ride I find is similar between the two although I don't have DCC. Even with the 45 profile tyres it's ok. As for towing, it's so much better. I had a tow trust detachable tow bar fitted along with the dedicated electrics by a local mobile fitter. Works as it should. Just check the vin to make sure it can be coded. Agree about the matrix headlights. Never been flashed but try not to think about replacing. Hope this helps
Wheels and Tyres
Evolution13 started following Wheels and Tyres
It’s a slippery slope. Then when you’ve exhausted the cheap parts you move on to more expensive projects! I’m fast heading towards the only thing left to do is order an eibach pro kit and lower it! Then I’ll have to convince the Mrs she needs things for her kodiaq!
One of the biggest disadvantages in the Sportline is the ridiculous 40 profile tyres fitted to the 19" wheels. The wheels are also 8J rather than the 7J in the rest of the range, so the standard 215 tyres give little protection to the rims over potholes & when parking. I have a SEL Edition that came with 18/50 & I dropped those to 17/55. You're already aware of the issues with the sunroof & while the dancing headlights sound great, it's something else to go wrong as the car ages. We're already seeing instances of LED indicator failures requiring a whole headlight replacement at over £1k. If boot space is a premium requirement, maybe look at an SEL with Varioflex seats. They can be flipped forward or removed completely. Skoda dropped them as standard but I can't remember when. Whatever you go for, buying from an authorised dealer seems essential for the warranty, as does extending it as soon as it expires. Door locks, shock absorbers, electric boot struts & software issues all seem common.
Rbz5416 started following Considering a Sportline
Wheels and Tyres
Doubt the difference bewteen 94 and 91 would make any real difference but the increased side wall will help. 205/55/16 against 225/45/17 side wall difference is about 3/4" more. I run 205/55/16 on my mk2. Mid range GT radial FE2 94V and its not bad plus good tyres in dry and wet. Son has 15" GT radial all season on his fabia and again good tyre in dry and wet Alasdair
Alasdair1 started following Wheels and Tyres
- 0.5-second audio dropouts with Android Auto, Apple CarPlay, Bluetooth…
Had different but similar warnings on my mk2 58plate 1.9tdi. Foglight symbol on bright with lights even if the fogs were off. Also quite a few dim lights. EML just showing,DPF just showing and a few that came and went all dim etc. I dont have DPF so I removed cluster and cleaned terminals etc and replaced and cured the phantom lights. Reckon it had come loose or was making a bad connection.Remember to disconnect battery before removing and replacing. Alasdair
The UK Government with the loudest voice (Sir Ian) AKA Sir Iain Duncan Smith is so very worried about China that they got their nickers in a twist about China and France building the new Nuclear in the UK. This government is so concerned over security and China that they do not want a Company fabricating wind turbines in a Yard in Scotland. No issues with how many Oil licences that a Chinese business has for oil and gas extraction in the North Sea because the is in partnership with Sir Jim Ratcliffe's company. (China National Offshore Oil Corporation / CNOOC) No issue with how many ports / terminals Chinese companies own (3), or business,s or allowing a huge Embassy to be built in London. This is a very very strange state of affairs in the UK. So wind turbines could spy on shipping. China has satellites............. & Oil fields and structures in the UK,s North Sea. & already many Chinese built wind turbines.
VRS-Rich joined the community
- Yesterday
Don't, just ordered a reversing camera 😆
Kimmo81 joined the community
Looking for EA888.4+DQ381 Tune Feedback
Alright, final update! A few weeks in with the Revo Stage 1 tune and what an improvement it’s been. For my application, Revo is no longer making a high/low torque map. It’s just one file with switchable maps for 95/97/99 octane. The mid range torque is impressive and coupled with the TVS DSG tune, driveability has improved drastically compared to what the car was like stock. They complement other perfectly. Fuel consumption has stayed about the same (although there’s a bit more temptation to get a little heavier footed), and temps are still spot on both in the city and on long drives. As expected, my issue has now become wheel spin all the way through first and second gear, sometimes to the start of third, so better and wider tires are in sight. Overtaking and getting up to speed have never been easier. Overall, if you’re been looking for just a little bit more of everything from your EA888.4/DQ381 combo without making any sacrifices, I can highly recommend it. As always, make sure to stay on top of your maintenance and run the correct fuel map.
Multiple Faults?
Hi, Has your issue been resolved, if so what was causing the fault. Thank You
2016 02 23
"Top up washer fluid" reminds me of a friend I co-piloted for, while she was learning to drive. She had to do several basic tasks, and asked me to see if she had done them correctly. When it came to filling the washer fluid -- it was FULL !!! I mean, with a meniscus. She couldn't understand why I was laughing so much. 🤣
Photography Thread
- Bootloop media player
Hi, Looks similar to this thread : Or this one : Unfortunately, no Skoda solution yet.
Still the same updates. 😑 Will wait for another version 🤞update and hope it fixes this...
This evenings task was to get out the cardboard spray booth again. This time painting parking sensors for the front sensor retrofit project. I used the punch for the bumper to cut holes in a small cardboard box and taped them in place as an easier way of masking up the sensors. The loom has also arrived but is missing the 18 pin plug and is for LHD so some wires also need extending.
