  2. Which simply highlights the idiocy of Skoda's approach.
  3. NottsIan replied to McDuff's topic in Skoda Karoq
    The coasting function is slightly different on later models. On my 74 plate it only operates when in 'Eco' mode, on my earlier 71 plate it operated in 'Normal' & 'Eco'
  4. NottsIan started following DSG in Traffic
  5. Just dropped you a DM 👍
  6. Came across an old post from 2020 with BBY engine codes P1553 and P1504 with same symptoms as yours. Sorry cant seem to post link but he had done a major overhaul on engine and it started and ran then got the codes with EPC,ASR Idle all over the place and no response from throttle. Eventually they did the following and it cured it. It was solved by resetting the ECU to factory defaults by writing value 00 to channel 00 in the engine control module. A bit above my zone but might work Alasdair
  7. McDuff replied to McDuff's topic in Skoda Karoq
    I've noticed it coasting at times. Going downhill engine braking disappears when it happens 😲
  8. Cheers. I grew up there and lots and lots of family in Macduff and Banff. Anther thing about DSG,s is if there is 'Coasting Function' and if enabled or used.
  9. McDuff replied to McDuff's topic in Skoda Karoq
    Do you happen to be in Macduff No, but I do go there on occasion 🙂
  10. Today
  11. Difference is a DQ200 7 speed twin dry clutch from a 6 or 7 speed wet clutch DSG. Wet clutch can slip some, a dry clutch should not be slipping. They should and do drive slightly different. @McDuff Do you happen to be in Macduff?
  12. Thanks for that info pab567. I didn't know how to bring up that service menu. Do you know if any of those codes relate to the phone function? And being temporarily rejected, does that mean they need to be enabled in a s/w load?
  13. That fault sounds to me like an issue with the SD port - is the updated SD card you tried a branded Skoda one?
  14. thank you for replying , the car is going back to the auto electrician next week so hopefully he can get to the bottom of what's going on with my lights at least for the meantime .
  15. I have the CTEK charger too, ran a recond programme on my battery a couple of times and a few good, long runs later and it's (almost) as good as new. I don't leave mine on a trickle or anything but if I'm ever plugging in an OBD device then I hook it up. Best money I ever spent
  16. McDuff replied to McDuff's topic in Skoda Karoq
    Thanks for the replies guys. I'm reassured that it works as I thought. Cheers 🍻
  17. shalkku joined the community
  18. Hi @Madrunner , I'm based in France and looking for a replacement LHD Yeti (specifically a 1.2 TSI 110 PS petrol / manual). Is it worth having a conversation? I can't message you privately with my contact info as I don't have the required 'credits' but maybe you do..?
  19. Sorry to laugh, but every tme I come back to this topic is to have a laugh at the "get rid of 'em trees" 😄
  20. Strange indeed, but I think you need again a good look and diagnostic at the charging system, alternator (how much is pulling out and wether the rectifier - that the word in English? - is working), also do not discount that even the battery you replaced was ruined by the failing alternator during the time between replacement of both. It would be also worth checking if the BMS - Battery Management System - in the car is working properly (but for this you need to have a diagnostics like VCDS or OBD11), and wether the proper type battery and size was correctly installed and coded in the system. Do not exclude anything, unfortunately. Do not rule out anything, at least at this stage. Once more knowledgeable on the problem, is easier to take measures ...
  21. Rbz5416 replied to McDuff's topic in Skoda Karoq
    @McDuff If your car has ACC & it's enabled, it will drive itself in traffic.
  22. Rbz5416 started following DSG in Traffic
  23. Correct - I’ve not found the clutches to slip when crawling in traffic at idle rpm. I drive many manual cars, vans minibuses and they will all crawl on the level in first gear totally feet off the clutch and throttle. The DSG is no different. My last DSG VW did 108,000 miles and the was as good as the day I bought it new.
  24. azax87 joined the community
  25. I'll message you later (this evening) to ask privately for VIN.
  26. Yesterday
  27. Agree with @scotthugh3s, check your 12v battery. It's so often the cause of many electrical gremlins, even if the voltage is only slightly down it will start playing up. I keep mine connected to a CTEK smart charger if the car is to be left standing for longer than two days at a time. It's eliminated any such electrickery.
  28. No I checked it
  29. paulozzy joined the community
  30. huweriksson joined the community
  31. It's manually retractable as far as I can see, like the OEM towbar, not electric.
  32. I'd be inclined to send it back. That's even worse than the skinny 18".
  33. Just wondering, my dpf light still coming on seem be every 170 miles, drive it in 4th for 15-20 mins, it goes out then. Anyone ever try a dpf cleaner, to put into tank? Or do they even work? Thanks
