You just can't help and move the goal post again. It is about planning fuel up's now?
So your post on cost was pointless? Your point about 5min fuel up in the previous post no longer relevant?
As mentioned, during everyday driving, EV are more convenient and actually less time spent, don't even need to think about fuelling up.
For longer journey, rest stop naturally happen and simply plug in when resting. Planning not required if in-car sat-nav software is good enough.
For day trips where total driving is around 4 hours in total on motorway, or 6 hours around here with a bit of local traffic at either end, EV doesn't need any planning or preparation. Whereas with ICE, as you've previously said, need to check and possibly fuel the day before, taking 10minutes minimum even if the fuel station is literally next door to your house (get dressed, start, drive around, 5min fuel up, drive back, change into comfy cloths. Ok, may be 6 minutes if you go out in public in your PJ )
I have plugged in the Leaf in my PJ before. Leaf BMS records how many charger connect/disconnects. It is also very poorly connected in terms of app control or Home Assistant integration. So when wife told me she want 100% next day for driving to shopping centre, I had to go and plug it in. 11pm in a Close, 5 seconds, no one saw 🤠
In other news, my Powerwall was meant to be installed today, installer sick, had to reschedule to 18th. 😞
New phone coming today though, I'll be using the new 80% charge limiter and see if it makes any difference.
My current iPhone 12 mini that has seen battery use around 140% every day is still reporting 83% health at 4 years old. Conservative estimate with 120% battery use each day puts it at over 1750 total battery cycles so far.
Modern batteries really do last and can take a beating.
Meanwhile, my Tesla vehicle BMS says it has recorded 94x discharge cycles (I run sentry mode all the time when not at home). I'm confident it can last more than 1000x cycles. Extrapolate from current mileage means ~200k miles zero worries and zero service requirement on the whole powertrain.
