Columbus Map Update 2024 (MIB1/2 HIGH)
-> next 2024-2025
   cross compatible on:
Skoda Columbus (Mib2H),
Seat Navi Plus (Mib2H),
VW Discover Pro (Mib2H),
Audi MMI Navigation Plus (Mib2H)
 one month ago
On 13/10/2023 at 21:39, BooBoo124 said:
Got some more links
Here
On 15/10/2023 at 12:55, BooBoo124 said:
Update to 2024 was successful It took 25mins via USB
now also can be dowloaded from Škoda server
BUT, zip archive is broken
On 14/11/2023 at 17:54, jenda69 said:
I got errors when unpacking:
Data error : Mib1\NavDB\BalticStates_eu\0\default\BalticStates_Map3D.psf
CRC failed : Mib1\NavDB\CzechRepublic_eu\0\default\CzechRepublic_ADAS.psf
Data error : Mib1\NavDB\France_eu\0\default\FranceNorthEast_Map3D.psf
CRC failed : Mib1\NavDB\Germany_eu\0\default\GermanyEast_Map3D_TIN.psf
Data error : Mib1\NavDB\Germany_eu\0\default\GermanyWest_Map3D.psf
CRC failed : Mib1\NavDB\Italy_eu\0\default\ItalyNorth_ADAS.psf
Data error : Mib1\NavDB\Portugal_eu\0\default\Portugal_Basic.psf
Data error : Mib1\NavDB\Russia_eu\0\default\Models\Russia5_0.cff
Data error : Mib1\NavDB\Russia_eu\0\default\Russia3_Map3D_TIN.psf
Data error : Mib2\NavDB\Poland_eu\0\default\Poland_AdvancedMap2D.psf
CRC failed : Mib2\NavDB\SpainSouth_eu\0\default\SpainSouth_AdvancedMap2D.psf
CRC failed : Mib2\SpeechResVDE\EU_Latvia\0\default\Latvia.iso
CRC failed : Mib2\SpeechResVDE\EU_Switzerland\0\default\Switzerland.iso
etc
# ECE 2024    26.2 GB
Version:    V03.959.820.ML 350 ECE 2024
DevVersion:    P350_N60S5MIBH3_EU_NT_Q1.23
   VW portal:      https://vw-maps-cdn.lighthouselabs.eu/vw-maps/P350_N60S5MIBH3_EU.7z
   VW portal:    https://navigation-maps.volkswagen.com/vw-maps/P350_N60S5MIBH3_EU.7z
Files inside:    2023.03.31
Downloadable:    2023.11.27
Published:    2023.--.--
 Škoda portal:   https://infotainment-cdn.skoda-auto.com/base/maps/HIGH12_P350_EU_202345.zip
Downloadable:    2023.11.13    17 broken files in archive
Downloadable:    2023.11.21     2(other) broken files in archive
Downloadable:    2023.11.30     fixed
Published:    2023.11.2?
# ECE 2024    14.1 GB
Mega.nz(copy from Audi portal)
       https://mega.nz/file/D7gRnTQS#bs1ghZILdz3-DOJ2Vafc9aePn_l9SDbRTJ8jyPslBO4
Files inside:    2023.10.05
Downloadable:    2023.10.13
# Rest of World 2024       25.3 Gb
Version:    V03.959.820.MN 0353 ROW 2024
DevVersion:     P353_N60S5MIBH3_ROW_NT_Q1.23
   VW portal:       https://vw-maps-cdn.lighthouselabs.eu/vw-maps/P353_N60S5MIBH3_ROW.7z
   VW portal:     https://navigation-maps.volkswagen.com/vw-maps/P353_N60S5MIBH3_ROW.7z
Files inside:    2023.05.19
 Škoda portal:   http://infotainment-cdn.skoda-auto.com/base/maps/HIGH12_P353_ROW_202345.zip
Downloadable:    2023.11.14
  ======= coverage =======
# EU
Albania*, Andorra, Austria, Belarus*, Belgium, Bosnia and Herzegovina*, Bulgaria*, Croatia, Cyprus*, Czech Republic, Denmark, Estonia*, Finland, France, Germany, Gibraltar, Great Britain, Greece, Hungary, Iceland, Ireland, Italy, Kosovo*, Latvia*, Liechtenstein, Lithuania*, Luxembourg, Malta, Moldova*, Monaco, Montenegro*, Netherlands, Northern Macedonia*, Norway, Poland, Portugal, Romania*, Russia*, San Marino, Serbia*, Slovakia, Slovenia*, Spain, Sweden, Switzerland, Turkey*, Ukraine*, Vatican City
* partially
# ROW
Argentina*, Australia, Bahrain, Botswana*, Brazil*, Brunei*, Chile*, Indonesia*, Israel, Jordan, Kuwait, Lesotho*, Malaysia, Mexico*, Mozambique*, Namibia*, New Zealand, Oman, Philippines*, Qatar, Reunion*, Saudi Arabia, Singapore, South Africa, Swaziland*, Thailand*, Turkey*, United Arab Emirates
* partially
======= instruction =======
1. download 7z/zip archive from direct link
2. extract content to SD Card or USB
3. insert memory device into slot of Columbus
4. start of update usually is offered automatically, manually can be found under Navi-> Settings
!!! note for MAC users
On 29/07/2018 at 20:55, ZaphodB said:
Macs are a bit more problematic as they put some 'hidden' files on the card which confuses the head unit
-> https://www.briskoda.net/forums/topic/452002-direct-download-links-for-ece-20182019-maps/page/2/?tab=comments#comment-5095042
couple of potential questions are answered in previous posts:
Columbus Maps 2023/2024
Columbus Maps 2023
Columbus Maps 2022/2023
Columbus Maps 2022
Columbus Maps 2021/2022
Columbus Maps 2021
Columbus Maps 2020/2021
Columbus Maps 2020
monthly POI's collection files downloading from X-o-m-k-a's blog
Edited by MartiniB
+VW's links
  • Replies 142
  • Views 49.3k
  • It's the VW link   VW portal:      https://vw-maps-cdn.lighthouselabs.eu/vw-maps/P350_N60S5MIBH3_EU.7z   That's proven to be fine for November 2023 (ECE 2024) aka the "lighthouse l
  • Can confirm this update is borked as I had the exact same failure at 2% on my Kodiaq  I went further and tried to force the update through the service menu which ended up losing all the maps. I recove
  • Update:   Worked fine and now EU version 2024/2025 in my Columbus of 2020 Kodiaq.
That's Mib2 high only on the Mega link. Works fine.
i did compare archives -
in Audi were 11 extra files
in Škoda were 369 extra
but files, which are present in both, have identical content with just different Date Time
Sounds good.
I'm assuming the file is unzipping fine now since you did the comparison.... eh no just checked.
Edited by Tell
interesting, that 11 Audi files just partly covers damaged in Škoda's zip, which were skipped during extracting
\Mib1\metainfo2.txt presents only in Škoda's zip
\Mib2\metainfo2.txt contains huge list of diffs
Reckon best not to use the Skoda ones at this time since you can't till they sort the issue out the zip issue and the Skoda mib3 on the other thread seems to have people having issues with it. That needs more people to look at it to see whether they are just head unit difficulties or a duff file. Feels like Skodas QA on map files has gone a bit off.
added VW's links to head post,
content isn't checked yet due extremely slow download
On 26/11/2023 at 18:51, Tell said:
They have fixed the un zip error now on the Skoda link
Opening up without an unzip error now
got one CRC err at 82% unpacking,
but broken file \Mib2\NavDB\FranceNorthWest_eu\0\default\FranceNorthWest_AdvancedMap2D.psf is ok in previous archive
Edited by MartiniB
Unzipped without errors here using 7zip
https://www.7-zip.org/download.html
Windows 64 bit.
The built-in Windows 11 7 unzip function turned into a disaster, said it was going to take a day. Reverted to trusty 7zip which you are supposed to use based on VW recommendations.
MartiniB I think you once had a transmission error that caused you difficulties in the past 🙄.
Here's my unscientific quick and dirty comparison between the Skoda and VW files:
Unzipped the file size is the same which suggests it's the same file. You then have to workout the SLA1 check....
I did do the SHA256 check on the groups of files, and they are different 🙄. Basically the byte size is identical but the contents are different between Skoda and VW.
What I get on the VW one using the 7zip CRC check.
Scholars of this process you use
It's like a constructed finger print of the files.... they are different. Probably Skoda has yet to fix the issue ?.
Interesting page on the German Skoda board,,, failing at 82% on the Skoda file is common... pull out and push the SD card back in :). I'd stick to the VW link.
The fun.
Edited by Tell
Interesting the mibsolution.one board I noted yesterday had a code fragment to fix the Columbus download. Didn't mention it just not to cause confusion. So someone has the fix which they copy back into the Columbus download.
Best to use the first VW link on the top. Waiting for the first puff of smoke to say the VW link works. I'm sticking with the Audi 350 copy not re-running the import. Motto get in early with updates where the knowledge of what works is known. Those that delay find the knowledge gone later 🤣.
Hi I've just updated my Columbus mib 2.5 with your link above the VW lighthouse labs one ,
SanDisk SD card 64gb formatted to ex fat , 4096 bytes , extracted with 7zip . Extracted without errors and updated in the car without issue . I had failed with the Skoda update last week , I got the errors everyone else got but this one worked perfectly . Thanks to everyone for your excellent info 👌
& thanks to MartiniB's hard work. He doesn't have a mib2 high now (don't reckon) whilst I was sticking with the Audi release of 350 not wanting to mess up what I had. It was tricky with the German Skoda board to work out who was using what.
Sorted now. 👌
Can I ask, what does this update do? Is it just maps that are being updated? I mostly use AndroidAuto for maps.
Only maps.
It's the VW link
That's proven to be fine for November 2023 (ECE 2024) aka the "lighthouse link". The Skoda one has had issues and was withdrawn from the webpage wrapper to it’s link to 350 back to 330. German Skoda community hacking that Skoda 350 file around to make good but the VW link above is fine.
Map files are interchangeable between VAG brands so you use the first one that works.... why I've got my Seat mib2 high running on the Audi release from 6 weeks ago 🤣.
Edited by Tell
Thank you for this fantastic info, you've saved my sanity again.
Thanks for the link. Ive downloaded and unzipped the file.
Mine is an mib2 setup. Do i need to copy the mib1 folder to perform the update? Thanks.
You do. Everything on the zipped file is dragged and dropped onto the SD / USB. Attached is the VW pdf guidance. Although the directory is labelled mib1 it takes files from there as well for mib2. Its a question that comes up from time to time. Just the way files are stored but you need the whole lot over.
Discover_Pro_November_2020_EN.pdf
Thanks very much Tell 👍
  • ColinD pinned this topic
Thanks @MartiniB, maps uploaded today but had to use a 64gb card for the first time
