  2. DavidMTB joined the community
  3. You really need to find out where the coolant is leaking from, you can't just blame the reservoir for leaking unless you already can see that it is. Maybe include your engine type/code.
  4. Compression test next, just to establish that pistons/cylinders are okay.
  5. I had exactly the same problem as you when I bought my 2023 Superb 2 years ago. The dealer where I bought it (Sinclairs of Swasea) couldnt fix it and it had to be referred to Skoda Support, who came up with a solution, but it had to go back to the dealer. As we were selling our house and searching for a replacement in Lincoln at the time and we were then living in Brecon, which was nearly 50 miles away, we deferred it until we moved to Lincoln, where it was resolved by Hortons. You will probably need to take it to the dealer. Mine was done under the manufacturer's 3 year warranty, so I assume you'll be able to get them to fix it under the warranty you had with your car? One thing they couldn't fix is when I use a pin location on the map, it shows the address, then England, Deutschland. Also, traffication shows the traffic laws for Germany in this country. The dealer says a software update should fix this when Skoda issue one, but I'm sure I'll have to live with this until I sell the car. I'm not that bothered about it, but a relatively new car should have everything working correctly. When we went abroad in April and May, pin locations and traffic laws came up correctly in other countries as far afield as Lithuania with the traffication notifications working correctly.
  6. As far as I'm aware, the Skoda connect data is connected to you, and not the vehicle. If you weren't to reset your infotainment before you sold it, and the buyer didn't either when they bought it, then they'd probably benefit from it.
  7. @Day40 How did the injector replacement go?
  8. If you subscribe to the traffication app, you receive alerts to both fixed and mobile speed cameras. Well I do in the UK anyway
  9. scotthugh3s started following Route Data
  10. I'm On my second mk3 in last 6 years. Not found any problems other than the odd battery and sensor issues. Buying a used motor , same things need to be checked. ie, make sure it's been regularly serviced etc. I've been very happy with my 1.5 tsi SE L dsg estates. Good luck.
  11. Does the alloy-block EA211 use cast iron liners?
  12. I made a mistake in my reply - I think Google maps does show fixed speed camera locations. Apologies.
  13. Are there any major things I should be looking out for?
  14. Is that a 1.5 tsi phev? They are on variable oil servicing. Vorsprung Dutch Technik. But if you run one mostly on electric would you leave the same oil in from the factory for 2 years?
  15. Today
  16. Thanks Lee, I was thinking more for future reference regarding the route data. It proved very useful on a previous KIA when I received a parking summons when I wasn't even in the car park. I'm aware something can be retrieved from Google Maps, but this only says where your phone has been not your vehicle
  17. Volkswagen Golf 8 models come set to a flexible (Long Life) service regime by default straight from the factory, I would thought that Octavia / A3 / Leon would be the same?
  18. Hi Numskull, I would like to buy the Brake Pads. How can I pay and get them. I live in South Manchester. Keith
  19. Location location location. Long queuing is not necessary if you are visiting charging hubs with plenty ultra rapid chargers and these are not very busy sites. Towing is an issue as far as charging unless it is the type of charging hubs designed to allow vehicles to charge while still hitched up to what ever and not requiring unhitching and re-hitching. I expect the range with a horse box and horse at the Max Gross weight allowed will be greatly reduced. Could it even be half the range.
  20. never drive engine with any noise. stop at moment. try to find missing part. easiest thru spark plug hole. if valves are not damaged, it will go. if cilinder wall is damaged, its old school cast iron cilinder wall liners which can be machined. no new engine needed.
  21. miro_zs@ joined the community
  22. This can happen if you replace the boot lights with cheapo Chinese LED’s. I know, I’ve done it but I live with it on the basis that I can actually see inside the boot in the dark!
  23. Thanks. Will have a look at this tomorrow. If I can get through there I’ll return the conduit!
  24. hmmm, that i don't know sorry. i do remember reading (back then) that it's "best practice" to stick with the pairs, i.e. 15 with 16; and 17 with 18. however, who knows, perhaps they might work if u interchanged them, i.e. paired 18 with 15.
  25. depends on your driving habits, if you live in colder areas with lot of short starts and stops, short trips, even 0w20 can be ok. i switched to 0w30, 30000 kms is no-go, 15000kms is maximum, i change oil once a year on about 8000-10000 kms, i dont drive much, but my drives are 90% short trips, about 10 kms rush hours. filters are cheap, i take Mann oil filter, Febi, Bluechem or Valeo air and pollen filter for about 8€ each, changing once a year. also aware that on your gearbox service probably has never been done.
  26. At this time, I won’t… My current Kodiaq Mk1 makes an excellent job! 😁 I was only asking myself how long I would need for a 10-80% charge along a holiday trip. 28mn isn’t that long on its own, but if most of the car have such values, it means long queueing to have the battery charged. My holiday trips are all over 500km with 90% motorway. The shortest is around 450km but requires a roof box which shortens the range and makes a battery charge mandatory anyway. Additionally, I may have to tow a horse van 2 or 3 times a year over 300km. I guess battery charge will be necessary in this case too…
  27. Got it, thanks! By the way, do you know if both headlight units should be the same generation? (015-016 or 017-018, in part numbers). Found a good deal for a 015 left unit and a 018 right unit and Im curious if they would work ok.
