- Need towing advice for a Skoda superb 2014 diesel
Stonekeeper started following Need towing advice for a Skoda superb 2014 diesel
Octavia Mk3 Combi – C-pillar trim won't clip back in (rear side airbags)
Hi everyone, I'm hoping someone here who has worked on the interior trim of an Octavia Mk3 Combi can help me out. I have a 2018 Skoda Octavia Mk3 (5E) Combi/Estate, equipped with the optional rear side airbags in the leather-covered bolsters next to the rear seats. While installing an aftermarket reversing camera and routing the wiring through the car, I accidentally dislodged the right C-pillar trim. I've spent quite some time trying to refit it, but I can't get it to sit properly. The main problems are: - The rear section of the C-pillar won't clip properly into the upper right luggage-compartment trim. - The lower front corner, where the C-pillar meets the plastic wheel-arch trim and leather-covered side-airbag bolster, isn't sitting correctly. - I've tried repositioning the trim, but there doesn't seem to be enough clearance to align the locating tabs and clips properly. I've purchased the official Skoda workshop manual (General Body Repairs, Interior – Octavia III, Edition 08.2018). According to the manual, the complete factory removal procedure involves removing the lower wheel-arch trim, which on vehicles equipped with rear side airbags requires removing the airbag assembly. I'd really like to avoid removing the leather-covered airbag bolster, especially after reading about other owners struggling to refit its upper retaining hook. My plan is to: 1. Remove the right D-pillar trim. 2. Release the fasteners securing the right luggage-compartment side panel. 3. Pull the boot-side panel away just enough to gain access, without removing it completely. 4. Fold the rear seat backrest down to gain more working room. 5. Carefully realign and refit the C-pillar, leaving the leather airbag bolster untouched. My questions are: - Has anyone successfully refitted the C-pillar on an Octavia Mk3 Combi using this approach? - Can the right luggage-compartment side trim be loosened enough without removing the leather-covered rear side-airbag bolster? - How exactly should the lower front corner of the C-pillar fit against the wheel-arch trim? Does it slide behind it, overlap it, or engage with a separate clip? - Is there a particular order for engaging the C-pillar's locating guides and clips during reassembly? I've attached photos showing the gaps at both ends of the C-pillar. Any advice, detailed photos or experience from someone who has done this job would be hugely appreciated. I'd like to get everything back together properly without breaking more clips or disturbing the airbag assembly. Thanks in advance!
LebSkoda joined the community
Hi there as the tittle states I have a Skoda superb 2014 diesel and I'm looking to get a caravan which is a avan ray 2004 with a weight of around 1460kg. I understand it's well within its tow weight, but my concern is the tow ball weight from what I have googled the 2014 Skoda superb has a tow ball weight of 70-80kg and the caravan would have about a 150 kg weight I'm just wondering is it safe to do so with the car? Do I have change any suspension or anything? I have read another post of people easily towing this size and more with this car but the post was from 13 years ago so I thought I would just ask here for help and sorry about the lack of knowledge as I'm very much a novice. Thanks in advance
tylerjs started following Need towing advice for a Skoda superb 2014 diesel
tylerjs started following Skoda Superb Mk2 (2008-2015)
Front Wishbone nuts just spinning
Hello, I am in the middle of replacing the front suspension on my Fabia mk2 Greenline. I have got most of the bits off that I need to, just got to the front left wishbone bolts. They were really tight to get off. 2 of them have sheared completely & the third one just spins. I can feel the bolt is not spinning, but the nut turns & never moves. I have given them a good clean, incase there was some rust stopping it. I then tried to the drivers side & all 3 of these just spin too, not really tight. I am guessing that I am going to need to cut them off, or is there some trick to this? Any help would be gratefully accepted. Thanks, Matt
Mattridd started following Front Wishbone nuts just spinning
This is worthless now. I sold my Mk3 Estate ~18month ago. This torch is not proposed in my Kodiaq Mk1.
Liam91x started following VRS Estate 4X4 Tyre Recommendations
Just wondering what people are using in the UK weather as I’m not far off having to change the tyres.
tylerjs joined the community
jazzyjeff started following Skoda Octavia Mk3 (2013 - 2020)
Yea indeed, didn’t think about it, mind you they didn’t seem to be well looked after already
You’ll be ok, they’re fitted to VW so you won’t have to worry your dealer
- Fabia Sleeper
- Activating SmartLink on Swing 3
Tyre recommendations
@Alasdair1 The specification of the tyre fitted to the 16"-diameter wheels of Skoda Fabias Mk4 cars is 195/55 R16 91 V XL with the 91 Load Index figure indicating that the tyre has been tested as being capable of carrying a per-tyre load of 615kg. The V Speed Rating indicates the tyre is suitable for a car with a maximum speed capability not exceeding 240km/h (149mph). And XL indicates Extra Load (ie. reinforced construction). Assuming you plan to fit replacement tyres with that specification, there is plenty of choice at a wide range of prices. Each different tyre should carry a label having the data explained here https://www.rac.co.uk/drive/advice/tyres/what-do-your-tyre-labels-mean/ (The Noise Rating relates to the noise the tyre produced when the vehicle is being drive, but it's reasonable to assume that, if a tyre produces a lot of 'external' noise, that noise will find a way into a car's interior.) However, although the tyre label is helpful and independent testing and car ownership comments can confirm the accuracy of the label, the 'softness' of a 195/55 R16 tyre and its ability to absorb the bumps on poor-quality road surfaces will depend directly on the pressure that the tyre is inflated to. The Skoda recommended pressure for Fabia Mk4 tyres is 2.5 bar (36.26psi). This is on the high side for a car of the Fabia type and undoubtedly will result in a firm/harsh ride, particularly on rough roads. This has been discussed here a couple of times in the past, but, for a genuinely 'softer' ride, the only realistic option is to use a tyre-pressure well below the 2.5bar recommendation - say 2.1bar (30.46psi).
Hello
Morning all member - just rejoining the platform West End Garage Skoda Edinburgh | Stirling | Dunfermline
West_End_Skoda started following Hello
West_End_Skoda joined the community
Infotainment model?
Yep - annoyingly with the maps there is absolutely no feedback loop to tell you it’s running, it’s progress or it’s finished. You either have to check the maps date on the software page or notice an out of date map is updated to be correct.
UNiT555 joined the community
Superb 2021 noise
Could be the dogbone bush is worn or perhaps an engine/gearbox mount. Reckon as its related to accelerator being pressed and lifted it must be engine torque related. If its a metalic clack Worth checking the subframe bolts as well. Alasdair
Octavia VRS Mk4 - real life MPG
Thanks manimal69 - that's quite a respectable mpg figure for that power of car on a good long journey- no doubt short / stop - start journeys will knock that down a good bit but it seems like Skodas stated Average mpg figure isn't that far off the mark. ( very unusual for a manufacturer )
Loss Of Power - 2016 Skoda Rapid Spaceback 1.6 TDI 115
Worth logging it before you buy anything else. On the 85kW 1.6 TDI the torque is meant to be there from 1500 rpm (Skoda quote 250 Nm from 1500 to 3000), so a car that feels fine in 1st and 2nd but runs out of puff in 3rd to 5th is usually one that can't hold full boost under real load. In the low gears the revs climb so quickly the engine is never loaded long enough to show it. With VCDS or similar, do a logged pull in 3rd from about 1500 to 3500 rpm at full throttle and record: 1. Boost specified vs actual (on newer VCDS versions these are in Advanced Measuring Values rather than the old group 011). If actual lags well behind specified, a couple of hundred mbar or more, you're looking at a boost leak or sticky turbo vanes. Check every intercooler hose and joint for oil and splits, especially the lower ones, as a small split often only opens up under boost. 2. Air mass specified vs actual. A lazy MAF can do exactly this with no warning light. 3. DPF soot load and differential pressure. At 125k a part blocked DPF will hold the car back more the longer you drive, and that "something holding it back" feeling with higher fuel use fits. The EGR cleaner helping is a clue in itself, as it points at the air side rather than injectors or the clutch. The judder at 1500 in 3rd under load can also be the dual mass flywheel, so if the logs come back clean it's worth getting that looked at. If you post the log up on here people can tell you a lot from it.
It should work on any MEN2 unit. In my experience it only didn't worked on VW Polo 2021. At first it was odd that 2021 car have MIB2 (MEN2) unit at all... On this topic you can find different situations people had, I cannot be sure about those situations as they could be caused by many factors, possible not bx patch itself.
Kodiaq steering wheel vibration
Hello, i don’t think that’s the solution. It can’t be so sensitive. I guess that after changing my front silentblocks for new ones vibration is slightly back. Car is more stable but vibrate sometimes. I found better solution - drive 140+ and there is no vibration at all
Octavia Mk3 (5E) Facelift Heated Seats Retrofit – What Parts Am I Missing?
Hi everyone, I'm planning to retrofit heated seats into my Škoda Octavia Mk3 (5E) and would appreciate some advice from people who have already completed this retrofit. So far, I have purchased the following parts: - 5E0 820 047 N – Climatronic control panel. - KUFATEC 43340 – Heated seat retrofit wiring harness. I'm planning to install a different set of seats with factory heating elements. Before starting the installation, I'd like to make sure I have everything I need. Could anyone who has done this retrofit let me know: 1. What additional wiring, connectors or adapters might be required? 2. Do I need any additional wiring between the seats, BCM and fuse box? 3. Is my existing BCM compatible, or might it need to be replaced? 4. Does the retrofit require any additional modules or relays? 5. Is any coding or adaptation required using VCDS or OBDeleven? 6. Is the KUFATEC 43340 kit sufficient, or are there other parts I should purchase? I'd really like to get everything working as close to OEM as possible, including control through the Climatronic panel. Any advice, part numbers, wiring diagrams or links to previous retrofit guides would be greatly appreciated. Thanks in advance for your help!
Dongle for code reading & coding
So with obd eleven you don’t have to get credits? What’s the advantage over vcds, that it can be done from your phone rather than laptop? I found most of the coding items on the vcds thread on the forum are one click things on carscanner. I’ve had to use long coding very little. The list would be handy to have though thanks.
I have an OBDeleven with Pro Lifetime subscription. Tis great for lots of things, including Long Coding and Adaptation changes. I never use One-Click Apps. I've made so so many changes, bout 6 yrs ago I made a 15-pg PDF of various code changes that work on the mk3 pre-facelift. It's OBDeleven and VCDS ready. Happy to share it if u want. There is also a "Tried and Tested Codings" page on this forum somewhere.
gobbledegook1 joined the community
Reversing light
I use my rear fogs when needed, gives you more light as you reverse.
I use carscanner app and this dongle https://amzn.eu/d/02erD0i9 It’s £36 for the dongle and £8 for the pro version of the app. No subscriptions. It does all the basic reading and clearing of codes, live data etc. It has the majority of the “tweaks” you would want to make pre programmed as selections. This includes service things like opening the rear brake calipers and coding battery etc. As per this list: https://www.carscanner.info/coding-mqb/ You can also do long coding but it doesn’t have the same helpers such as a tool like VCDS but most of the time I need to do it I’ve asked people on the forum and found what I’ve needed to do. There are a few things it can’t do like some adaptations and dataset coding but often you would need VCP or ODIS for that sort of thing anyway. It also has a CarPlay app where you can make dashboards from any data source so you can monitor things like transmission temperature etc. I have found that for the price it’s unbeatable and does nearly everything that a mid level DIYer would want to. The ultimate tool would be VCDS but that is around £225 but can do everything you need except dealer level online coding things like component protection. https://m.gendan.co.uk/product_VCV23.html?gad_source=1&gad_campaignid=2009361245&gclid=CjwKCAjwo5bXBhAEEiwAkgpgXDjr7VRHYIiufMXCWsIb8mS_SSSj7lprJkcTEbAkCM7cPZszbZEBnBoC96kQAvD_BwE
