Adblu reducdant sensor
Search for adblue delete. Not sure where in the country you are but this was the first hit on google. Not a recommendation. Skoda AdBlue Delete | NOx Delete | SCR Delete | LeicesterSkoda Adblue Removal Specialist in Leicester. We offer custom Adblue / NOx / SCR Delete Services for Skoda Octavia, Fabia, Yeti, Rapid and others. P20EE, P20E8 When I bought mine it had already been done.
- Radio change incompatibility
Codes 00883 and 00668 Octavia 2007
00883 is I think is an ignition switch problem. it could be the switch behind the barrel that has failed. Read that there is part of the switch that senses when key is in ignition that is prone to failing. It could also be loose bad connection at switch. Check the fuses near battery for corrosion/loosness as well. Alasdair
Alasdair1 started following Codes 00883 and 00668 Octavia 2007
Thanks for the tip but how do I go about doing that?
Final Drive Service?
I guess I'll let the experts work it out when I take it to them thanks for all the advice.
Hi all: Is anyone able to do a VAG Service history report for me please (Skoda Superb 3)?
PM'ed to you. Thanks. AG Falco
Code it out and worry no more
Binx1310 started following Adblu reducdant sensor
- Rapid 1.2 TSI Broken valve / hose
PCV valve/assembly
That's what should happen with a healthy system. (Apart from the lumpy idle).
8755 Software Update - Skoda Fabia 2019 Carplay Issue
Hi @Tdawber I have a 2019 Skoda Fabia with MEN2_EU_SKGPx_P7381L / software 8740 and the CarPlay audio crackling issue. Could you please start a private conversation with me so I can provide my Gmail address for the 8755 files? Thank you.
Wimmel101 started following 8755 Software Update - Skoda Fabia 2019 Carplay Issue
PCV valve/assembly
It might be the PCV, hard to say on modern engines.
Aldfort started following PCV valve/assembly
Wimmel101 joined the community
- Elroq: Who else has ordered?
eneskisacik joined the community
- What does this symbol mean
Karoq Instrument Panel & Servicing Generally
E13. Thanks, according to last year's Skoda Dealer check list, the air filter was replaced at 6 years - but clearly the new garage must have thought it needed doing again. Maybe it gets dusty at the edge of the East End of London. The spark plugs have been renewed once, 3 years ago I recall and due again next year (when car will be 8yrs old). My garage man wonders if this will be necessary - in his experience - in view of my limited 7,000miles per year, with at least half being long distance, but he said it's up to me, so if you and others think they should be changed, I'll insist. R193. thanks - yes Maxidot, I remember now. Will have a go at changing via the scroll bar.
JD52 started following SmartBox no longer recognised.
I've checked the Skoda parts listing that I use/trust and, for a 2020MY Octavia, if the car is 5E - L - 000 001 > then VAQ fluid is specified as being G 060 175 A2 If the car is NX - L - 000 001 > then VAQ fluid is specified as being G 065 175 A2. I'm not a Skoda Octavia owner is the model designation doesn't mean much to me - but it will do to you.
After some 18 months of use, my wireless Android Auto link has died. It wuld connect automatically to the my phone in my pocket. See attached vid for what happens now. https://bigjohnd.org.uk/Octavia1/Video/SmartBox.mp4 My phone connects to the SmartBox but the car doesn't connect to the Smartbox. The car will not read my phone when it is conected directly to the USB port either. Smatlink/Android Auto/CarPlay all seem fine on my OBDII I am suspecting the Amundsen or USB port itself. Any suggestions where to look next
The two Haldex fluids that I have ended up with, are VW Group G 060 175 A2 and VW Group G 65 175 A2. I was buying fluid online for a 2019 SEAT Leon Cupra VAQ, SEAT listed G 60 175 A2 - but my seller sent out G 65 175 A2, now I think that he assumed that the "G 65" version superceeded the earlier "G 60" version as it turned out that VW quote the "G 65" version for similar aged VW Golf when it has a VAQ. In the end I got a refund and bought the "correct for that car" version. Checking on many sites I found nothing to confirm that, but, I discovered that the Febi offering does claim to meet with both these VW Group Haldex fluids - so how important that is I can't say, for my money, I'd prefer to buy the version that is listed for "that" model of car.
Photography Thread
Funnily enough, I wondered about using an extreme ND filter to see the eclipse, but luckily remembered it didn't have any UV protection, so it would still have been potentially dangerous. I was surprised to see a chap on the BBC website saying he damaged his eyes in the last eclipse, looking at the sun through a welder's mask. I would have thought this would have been sufficient, but I've since read they aren't usually filtered enough. Something to do with a rating of 12 or above being needed (I assume this is pretty dark?)
Cheers, I'll give the Phirm a call then and that's 5 minutes from me pretty much. Not sure about the fluid you listed after I that 'm afraid.
Silencing the loud spoken traffic congestion warnings
I'd have thought this would be similar to sat nav directions or phone calls, in that the volume can be adjusted during announcement (or call) by using the volume dial on the steering wheel. After a year of ownership (used car purchase), i've not had any traffication announcements, maybe they were turned off by previous owner.
GerryL started following Silencing the loud spoken traffic congestion warnings
- Rim protection 18" Gemini vrs alloys
Definitely try The Phirm - they're by Blackwater station. I spoke with them and VAS Motion when deciding where to go for my big service a year or two ago. The Phirm are a TVS dealer, but I can't actually remember why I went with them in the end - I think I just liked their answers better. Either way, I've spent a fair bit of money with them, doing stuff like my DSG, VAQ and major service, as well as LCAs, CV boots, new battery, minor service and other stuff. I plan to see them for some new brakes soon, too. @travs had his intercooler and suspension done there, and had similarly good experiences. Do you know what these are? I've only ever seen the standard VAG Haldex service kit from Febi (silver bottle with white and red labelling) or the VW one in the silver bottle.
Just to clarify, Haldex is a Borg Warner product, VAQ is a "clutch for a shaft" using Haldex bits. The VAG branded fluid seems to vary from VW Group to marque, though some of the aftermarket brands use a common fluid - but there again, VW Group don't "make" these fluids. I deferred to using what, in my case, SEAT quoted in their parts listing. It could be that these VAQ parts manufacture has been licensed out to 2 different suppliers covering different VW Group brands, and they use acceptable but different materials or processes - and so VW Group quotes 2 different fluids for different marques.
Glowplug prices - having a laugh
Stonekeeper started following Glowplug prices - having a laugh
I have just enquired about a glowplug for number 3 - you know the one that costs the earth. I have seen branded plugs for €140 each but not always in stock. I checked with my local Eurocarparts and they quoted me €275!! I thought I better ask Skoda maindealer as that seemed crazy and after 5 minutes on the phone (mostly holding) I was offered one off the shelf for €175+vat - €215. When has a main dealer not been the most expensive for parts?
