UK Public Charger Network & price increases as they are announced. Please post here as you become aware of any changes in the costs.
Eon Next EV tariffs Next Drive or Next Drive smart are showing Offpeak back to 7 hours midnight to 7am for those going on these tariffs. It had been 7 hours and then reduced to 6 hours.
Skoda Octavia mK III INFOTAINMENT system keeps switching on and off
Thanks for your reply. Is it the fuse that’s under the glove box, behind the panel above the passenger footwell? I have had a problem with the electrics on the towbar not working on 13 pin, but fine if I put a 7 pin adapter in. An auto electrician had the loom out trying to sort that problem but couldn’t. It may be a loose connection there. I will check that out and post back with the result. Cheers Skiprat.
Karoq diesel engine oil 4x4 - recommendations / manufacturers?
@Ooopnorth You asked best oil, pitty you never said 'Topping up'. If 0w 20 FS IV was used at the last Oil & Filter service then you should really top up with that. Not that a little different spec of oil will make a difference, just a diesel engine after all. At next service 0w 30 FS III might well be the way to go. As to Brand, matters not a jot as all to the Recommendation Spec does the job. Just a diesel engine after all. IMO.
8755 Software Update - Skoda Fabia 2019 Carplay Issue
Checking Your Version Turn on your car's ignition and go to the Menu on your infotainment screen. Select Settings, then look for System Information or Version Information to see your current firmware build. ?
Just bought 1 Ltr of Shell Helix Ultra Professional AV-L 0W-30 to keep in the back of the car should a top up prove necessary (no signs yet, thankfully) 👍
Changing timing belt on an 1.4 TSI ACT engine
Come back at 40,000, or say 140,000. I think the complex procedure is about maintaining the long service intervals. Eg 300,000km belt change interval. I would agree that this will probably work in most cases, but its a bit of a botch job. Cam timing may drift a bit due to inherent tension imbalance between the cam pulleys and crank etc. Also, by loosening the pulleys and tightening the belt before unlocking the cams, you are ensuring the tension is consistent or at least correctly distributed around its length. By doing this, they can run the cam belt out to 300K no worries, probably even longer. Remember many cam belts had 100k or even 60K intervals (thinking Opel Corsa from early 2000s.) Probably more importantly, change the idler. The bearing in the idler is the most common failure I have seen. Obviously junks the belt thus engine when they fail
TDI is VW 508 00 / 509 00. Same 0w 20 FS IV, but VW 508 00 is TSI Fixed or Variable. TDI VW 509 00 is even if on Fixed Oil & filter service. Same with the 0w 30 FS III or 5w 30 FS III. 504 TSI fixed or Variable. But 507 00 is a TDI even if Fixed Oil & Filter servicing.
Evolution13 started following Karoq diesel engine oil 4x4 - recommendations / manufacturers?
Opinions for new shocks+springs
if 88 in xour nick suggest you are born in 1988, than you are to aged to have stiff car suspension. it will become unconfortable. if you like it, go on, aif not, stay with basic B4 which are like OEM.
imart143 started following Opinions for new shocks+springs
Wheels and Tyres
The only person a locking wheel nut/bolt stops, is you. I had a rounded key on my first car, and sorted the issue with a blank socket and a mallet. I've kept the lockers on all cars since, as the wheels don't come off very regularly, but different designs have varying levels of usability. Usually, the BMW/VAG ones are pretty good - but the two-piece design, like on Ford, are horrendous.
OccyVRS started following Wheels and Tyres
VW Specification: VW 508 00 (petrol/diesel dual standard for 0W-20) or traditional VW 507 00 for long-life 5W-30/0W-30. if you living ih cold climate zone use 0w20, if you live in hot climate, than 0w30. manufacturer, i like Shell (Shell Helix Ultra Professional AV-L 0W-30) Shell, Castrol, Aral, Liqui moly...
imart143 started following Karoq diesel engine oil 4x4 - recommendations / manufacturers?
Spacesaver spare wheel
These 2025 and 2024 forum topics discussed (in some depth) spare-wheels for Fabia Mk4 cars. https://www.briskoda.net/forums/topic/533394-fabia-spare-wheel/#comment-5952581 https://www.briskoda.net/forums/topic/522682-spare-wheel-and-central-tool-holder/ The 'genuine' Skoda Fabia Mk4 spare-wheel + tool-kit is currently advertised here at £225.15 (Sale price) https://skodapartsdirect.co.uk/product/skoda-fabia-2015-2026-spare-wheel-tool-kit/
DGW started following Very wet carpets
- [GUIDE] Activated Android Auto + Apple CarPlay on MIB2 Technisat for €0 (No dealer, no paid codes)
DaveP61 joined the community
- Yesterday
Photography Thread
- the truth about electric cars
Not for many years as have not had an ICE vehicle. When my son went from ICE to EV about a year ago we tended to go to MFG stations and they seem to get the future as they oft seem to have EV chargers and petrol pumps. Do go in to the Tesco fuel station but only to get a meal deal but they always ask if I have got fuel and I can so no each time. Our Tesco is quite a poor one as no EV charging there and Sainsburys seems to be getting the jump on Tescos and I expect Tesco to lose a lot of customers due to their lack of foresight.- Gear changing started making sounds
Hi @vmt, We're you able to get closure on this topic? Facing the same "issue" and I'm not sure what to do. Car has 30k km. Thanksnmsilva96 started following Gear changing started making sounds- Spacesaver spare wheel
The below foam and jack kit can be ordered for the Fabia MK4 from any VAG parts department by quoting the relevant OEM part number, ie. 6VA093860A. The VAG parts department can confirm whether this is correct for your vehicle by reference to the car's VIN number. The Czech price on "skoda eshop cz" is 2079CZK which is about £74. The below foam and jack kit uses a 185/65R15 5.5Jx15 ET40 5/100 57.1 spare wheel. Fabia MK4 foam and jack kit (includes everything except for the actual spare wheel) (OEM part number 6VA093860A) Sada pro výměnu rezervního kola 15Určeno pro: Fabia IV.Alcar 4055 5.5Jx15 ET40 5/100 57.1 steel rim (for Fabia MK4) https://www.mytyres.co.uk/rims/details?vehicleId=1360399348768339044&rimCode=ALCAR4055 Alcar 4055 5.5Jx15 ET40 steel rim with fitted 185/65R15 tyre (includes valve and balancing) https://www.mytyres.co.uk/cw/tyre-selector?share=&vehicle_ids=1351328927594845284&sortCode=none&limit=15&rimCode=ALCAR4055&rimType=steel&sizeTyresOnCW=noChanges&season=so&price=&brand=Uniroyal&brand=VredesteinCarlston started following Spacesaver spare wheel- 8755 Software Update - Skoda Fabia 2019 Carplay Issue
How do I figure that out?PhilRhodes joined the community- the truth about electric cars
I know about that, hence my surprise that you actually admitted to using Tesco fuel after you posted this.- Upgrade Carplay on my Superb 3T
Interesting, how have you done that?- Octavia RS AFS (Bending) Lights don't work
Turn your cornering lights back on and see if that brings them back. My Sharan has AFS lights and when one of the static cornering lights bulbs was out it disabled the AFS headlight function. Also, there is definitely and off switch for AFS as I have the option on the display to disable bend lighting, so there must be an equivalent VCDS option somewhere.- [GUIDE] Activated Android Auto + Apple CarPlay on MIB2 Technisat for €0 (No dealer, no paid codes)
- Guess the Hire Car.... Mac's 2019 game
Nope sorry @Gaz ... It's actually not a bad drive, is from part of the Stellantis group and has lots of little 'easter egg' (unfortunately not of the chocolate variety) motifs all round it harking back to it's WWII forefathers. Enough of a clue??- Full Matrix Led headlights on motorway
Is this a LHD car on UK motorways?- Karoq diesel engine oil 4x4 - recommendations / manufacturers?
What's the best oil for a.... Brand SKODA Model Karoq Engine 2.0 TDI 4x4 (110kW) Fuel type Diesel Production year 2020 - 2025Ooopnorth started following Karoq diesel engine oil 4x4 - recommendations / manufacturers?- 2011 Fabia 1.2TSI, 67,737 miles, AP Coilover conversion *non-running*
There's this? IMG_0754.HEIC AFAIK all recalls were actioned. I got the vehicle late 2014 from a Skoda dealer. - the truth about electric cars
