  2. There is a post open on this recently but no one seems to be answering my query so apologies for another post on same subject... When I press the button to open the boot from the keyfob, it opens about 6" then closes again. If I open using the button on the boot, it opens the same distance but just sits there. When I manually push it up from this position, there is a certain amount of resistance and when open fully and I press the button on the boot to close it ,bleeps about 6 times and does nothing. Are there likely to be any fault codes that would indicate what the issue may be? I can`t think it would be a break in a wire as I`m guessing it wouldn`t open at all. If it were a faulty strut , how would you ascertain which one? or is it likely both could be faulty? Or indeed could it be something else entirely?
  3. Mine stopped working. Eventually I discovered that I had switched off the ESC control, by pressing the button, which is behind the gear lever. No LED shows if it on or off. I turned it back on by entering the big service screen, and locating the menu.
  4. Thanks to all , ive got it booked in so i will reply on here when i find out what it was. (The garage suggested centre prop bearing was a common fault.) Alan
  5. Yesterday I received a new update that I suspect is to fix the repeated updates problem, after two fails to download I left it installing overnight.
  6. 6:08 Happened to me also in one side by a sloppy mechanic 22:14 I have removed the whole thing due to dirt-moisture,you can save some weight this way 23:21 You can make a cleaning with a/c spray.In the past i asked for a thoroughly evaporator-blower cleaning from a a/c specialist (he removed the cover) 23:51 You can find info about this in my attachments,was bringing hot air from the intake cover inside the air filter box to help the engine at cold starts in Winter. https://www.briskoda.net/forums/topic/499328-how-much-time-do-you-warm-up-your-felicia/page/19/#findComment-5638614 https://www.briskoda.net/forums/topic/499328-how-much-time-do-you-warm-up-your-felicia/page/18/ Now i use that hose for different purpose: https://www.briskoda.net/forums/topic/477677-skoda-felica-13-what-kind-of-air-filter-do-you-use/
  7. So clean now. Its the steering rack or steering gear that is leaking not the engine. Amazing i had the low level light on the engine oil at the same time as i saw the leakage under the car. so two problem in one go. Anyone have any good guides on how to change the steering gear? Guess youtube have plenty. Thanks help all
  8. ianjmcd started following Skoda superb estate
  9. New here just bought my first skoda
  10. ianjmcd joined the community
  11. Today
  12. Hopefully the fault codes point to an easy fix.
  13. LesterMAyers joined the community
  14. Yeah this one's not huge as I think it's paired with the fiat 500x. Those mini countryman are definitely bigger and uglier
  15. Hello. I'm have plans to install a subwoofer in my superb this weekend and wonder if anyone has find a good spot to go through the firewall for the positive cable, preferably om the driver side (LHD) as I plan to put the RCA cables on the passenger side as I already have a camera cable there
  16. skomaz replied to BlueDun's topic in Skoda Yeti
    A photo would also help...
  17. muddyjim replied to BlueDun's topic in Skoda Yeti
    Hi, It would help if you could tell us the model of Yeti you have - e.g. engine size petrol/diesel, manual/auto gearbox, front/all wheel drive. There are many permutations, so it's possible that the pipes you describe are not fitted to all models.
  18. Fantastic, thanks Cairus!I will give it a shot, hopefully I can get it back to work🤞🙃I will update. Cairus, You're a star mate 🙂
  19. Full Backup Superb 3 Facelift L&K Superb3_L&K_Full_Backup.html
  20. Interesting. .I have to look into this , thanks Cairus! I will probably check if the plug at the back of the lights is not loose or pins corroded first. That would be the best and easier option...🤞
  21. Don't apologize Cairus, I appreciate your help anyway mate! It's not on top of my list to get this lane assist working and we will get there eventually 🙃Hope you're Ok bud, look after yourself and we will try again whenever you feeling good👍
  22. There are microswitches inside the lock mechanism. These are a known issue within the group—specifically, the solder joints tend to break. When this happens, the trunk lighting or the Multi-Function Display (MFA) often starts acting up.
  23. Yes and I did several times with long coding from other cars with same camera and trim. It did not work. Looks like the older models, pre Facelift are quite easy to code but after 2019 some models are blocked from coding lane assist with other tools than Obd11 , vscd...I will give it a go, thank you, but I'm not too optimistic. Many thanks for support!
  24. Sorry @Rafal78 I have a couple of health issues.
  25. I have a similar thing around 2500rpm in my vRS, but only under load (uphill or accelerating to enter motorway), and only very occasionally, i.e. not easy to reproduce at will. I suspect something is loose around the engine, several possibilities, including but not limited to a cracked piston ring, a cracked piston skirt around its wrist pin, or some balancer shaft issue. If it is any consolation, I have done 60k+ miles since I noticed the issue, though for me, it happens quite rarely. The engine drinks about a 250ml glass of oil per 1k miles, in line with my previous 1.9TDI Octavia which did have a cracked piston ring but otherwise engine was bulletproof. Fuel consumption and performance are both very good, and I intend to keep my vRS until the engine dies or until it meets some other end of life event, as any manual gearbox diesel car replacement will have 35% less power.
  26. Hi everyone, I’m trying to trace a water leak in my right-hand-drive 2019 Skoda Kodiaq Ambition+ 1.5 TSI in New Zealand. After prolonged or heavy rain, the carpet and padding in the driver’s footwell become wet. The water is clean and odourless, so I believe it is rainwater. So far, I have lifted the carpet, removed trim around the bonnet release and inspected the driver-side scuttle beneath the windscreen. I removed leaves, dirt and a few small plastic pieces, cleared the drainage area and flushed it with water. It now drains quickly, but I haven’t been able to reproduce the leak during controlled water tests. I noticed what appeared to be a wet trail on a metal ledge high above the pedals, near the bulkhead. This makes me think water may be entering higher up and travelling behind the dashboard or insulation. Possible causes I’ve considered include the scuttle seams, a bulkhead grommet, windscreen bonding, the door membrane or the wheel-arch area. Has anyone experienced this on a first-generation Kodiaq, particularly a right-hand-drive model? Are there any known water-entry points above the driver’s pedals? Thanks, Daniel
  27. DanielAlv joined the community
  28. You should be able to check the individual bytes/bits in your long coding using car scanner based on the vcds info above.
  29. Rafal78 replied to Nahum's topic in Hellos and Goodbyes
    Hi, welcome to Briskoda. You in the right place then 🙃There are plenty of people here willing to help with advice and knowledge. 👍
  30. Rafal78 started following Hello
  31. Thanks guys, Some great feedback there. That gives me much more comfort & confidence.
  32. Yesterday
  33. Yes, you absolutely right. Lane assist can be easily coded using Obd11 or vscd. The problem I had was limitation of Car Scanner which codded actual function but it would not enable it. That's why I'm waiting until get my hands on Obd11 or vscd. 2Q0 camera is the newest available for MK3 so Traffic Signs are possible to code with same tools, they will appear but there will be error "not available" because its locked by SWaP/FEC software certificates. It was easier with models up to 2019 but after Facelift, VW/Skoda are actively blocking access. You would need someone with ODIS-E or VCP to put dataset in and there you go 😎. You right, we shifted slightly from the subject but it's a beauty of this forum to learn about 10 other things that the one you asked for 🤣
