Past hour
- Model help
tonashi joined the community
Today
PhiltheGreek joined the community
- Model help
Latest Software update information (Recommended?)
Mk4
MIB2 update MST2_EU_SK_ZR_P0363T to P0369T – Octavia 3 1.6 TDI (H30) – firmware link needed
https://mibvault.com/firmware/MST2_EU_SK_ZR_P0369T
MrsM joined the community
Stopping chain noise
Since the oil change to 5W 30W chain noise seems to be eliminated. I had plugs and the factory fitted leads replaced. Start up when hot is almost instant and cold start is with less revolutions of the engine. Idle when hot or cold is so smooth and quiet. So happy bunny.
gthr joined the community
ZacDaMan72 changed their profile photo
ARS24 ROCK-8 Subwoofer - Canton replacement
Has anyone here replaced their Canton subwoofer with one from ARS24? The factory sub is a 6.5" dual voice coil 2x8Ω with 200W total - I'm not sure how bad it'll be to run the ROCK-8 D4 (2x4Ω, 200W total). 2x8Ω: https://www.ars24.com/option-rock-8-d8-subwoofer-im-reserverad-fuer-2-x-8-ohm-werks-subwoofer 2x4Ω: https://www.ars24.com/option-rock-8-d4-subwoofer-im-reserverad-auch-beats 2x2Ω: https://www.ars24.com/option-rock-8-d2-subwoofer-im-reserverad-fuer-beats I'm looking at these ones because they fit in the spare wheel quite nicely and use the factory plug so is fully plug & play.
Nimrod2 started following Model help
Model help
Can someone please help. I have purchased a car and only after being given the quote and paying the deposit and then receiving more paperwork did it show I am actually getting a 2024 model. Can someone please advise the difference in the 2024 model, 2026 model and 2027 model. I am concerned the car will have been sat somewhere for potentially 2 years. I was expecting the current year. Shouldn't I have been told if it isn't the current model? It is the Skoda Kamiq 1.0 Tsi automatic SE L edition
Nimrod2 joined the community
Yesterday
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
Start Stop Stall
P S. in the interim I think I will switch start/stop off. I understand there's a button to switch off the system when setting off on a journey. No more rush hour embarrassment with a green light in front of me, hazard lights flashing and an angry queue behind me!
mjasmin joined the community
Start Stop Stall
Thanks for your reply, useful to know it can be done by oneself, however I'm not too car DIY competent (cars have changed too much during my lifetime) so I might be better having the battery fitted and coded at a service agency. I'll get some prices fitted and coded and x chk cost of just getting a battery and the device you recommend, if it's quite different I might try updating my knowledge! Thanks again.
best way is to top up canister with diesel before putting lid back on, you'll never get any problems with airlocks
Been tightening up on car security, days of nobody steals skoda's are long gone, they steal everything and anything nowadays. Got a disklok, and moved the obd connector to a hidden place with one of these, it leaves a dummy obd in the original place and if scumbag plugs into it, it appears to work but no coding can be done. thinking about fitting a hidden kill switch as well
Rear springs...replace?
If it's a front wheel drive Superb MK2 estate with standard ride height (ie. not lowered ride height or increased ride height), then fitting slightly stiffer rear springs such as two up in the hierarchy should solve the soft rear end problem when the car is loaded. As mentioned in my previous post the upgraded rear springs have OEM part number 3C0511115AF.
- Servicing my serpentine/auxiliary belt, what brands should I get? (CGPA)
I found this video where he prunes using a code reader but says you can just start normally if you don’t have one. He also has other basic service videos on superb which are handy.
Amundsen MIB2 Firmware Update
All check your PMs
Mk4 or 4.5 (facelift) ?
scotthugh3s started following Latest Software update information (Recommended?)
hello hope all is well does anyone have the following: VW Polo 6C 3Q0035874A (MST2_EU_VW_ZR_P0241T) stuck in Emergency Download (Device: cpu Module: cpuboot%1 FileReadError). mibsolution.one is down and MIBVault's P0254T.7z is missing cpu/cpuboot_sec/12/default/Bootloader/init_mibstd2_cpu.dat (SHA1 ad9423fb38ff88c37e3521c58d161785c2ced62e). Can anyone share a working GDrive/MEGA link for MST2_EU_VW_ZR_P0253T.7z / P0252T.7z or that 45KB init_mibstd2_cpu.dat file? currently stuck in red emergency download. i used this file (3.5gb)MST2_EU_VW_ZR_P0254T.7z [21/11/2026 21:44] jessreadingx: https://mibsolution.one website is down and doesnt work also @pab567 @varooom
fclx0 started following Amundsen MIB2 Firmware Update
DCC Slider adjustment option mod
Don't look for them physically, instead use a scanner like OBDeleven or VCDS. That's how u find out part numbers.
fclx0 joined the community
5Q0 612 041 BM Brake booster vacuum hose with a non-return (check) valve and pressure sensor
I think that that reason is acceptable when a car part does not cost much, but once the cost reaches a certain level, owners have a right to expect that parts are fit for use - and fit for use over a reasonable period over time/miles. I'm guessing that this part cost roughly £200 from Skoda UK. I replaced a Lambda sensor on my wife's 2015 VW Polo 1.2TSI this year at roughly 60,000miles, even although I was careful with the Lambda sensors connector support bracket, I broke a tang off it when removing the faulty Lambda sensor connector. I fitted a new support bracket this week and while removing the old bracket, I broke a tang of the "other" Lambda sensor mounting point, the new bracket only cost £6 I think, so no big deal - but that was due to the plastic becoming brittle with age and local heat. One annoying bit of this job was, the cable tie mounting that snaps into this bracket, partially broke up while I was removing it from the original bracket - again "not very suitable" plastic - the sort of thing that people used to complain about when buying/using stuff "made in China" - how standards have dropped in Europe, or even from suppliers that European manufacturers use!
Ceratec diesel additive to Octavia mk3 2.0 tdi
I understand. I had more doubts as well. In my country it costs me around 20 euros, which I will compensate by doing the oil change myself and saving in labour costs haha. Also, here’s an article about the reduced noise and vibration levels by using the product: https://www.team-bhp.com/forum/technical-stuff/196980-review-liqui-moly-cera-tec-friction-modifier-my-skoda-laura.html
The last FEAD belt that I replaced was on my wife's 2015 VW Polo 1.2TSI and it was a Contitech (Continental) that I bought. The belt for her previous car, a 2002 VW Polo 1.4 16V, that I bought was a genuine VW Group part - and it was a Dayco "made in France", and it, when opened out and laid down on a flat surface it had a "bow" in it, ie it only touched the flat surface at 2 points - I examined it and discovered that it had been cut at an angle to the weave - or at least the smooth side material had been, I still fitted it and it lasted okay. I did expect better from VW Group, but there again, I've had failed front wheel bearing due to water ingress - and that bearing was "made in France"!
yeah will do, we tried to get the belt off earlier today and the bit kept slipping off, gonna have to take it to a garage, which is rather annoying as i already bought the belt but im guessing they will want to use their own parts for insurance/warrenty purposes i guess i have a spare belt now 🤷♂️ or i could also return it as well as its still in its packaging
Autodoc - avoid!!!
Oh well, my mate's Autodoc parcel arrived, meant to be 2 rear callipers, but it seems he has been sent 3 Ridex callipers AND a Ridex radio! Hopefully he attempts to refurbish the 2 original rear callipers and just uses these Ridex cheapies to keep things moving!
