  2. Was it soot or ash content or both that was 20% Soot gets burned off during regen but ash builds up over time. Next time it happens I would take it out for a decent long run and see how long it takes for it to regen again. With mine its random. Recently after decent run it took over a two weeks to start regen again but if I do short trips it starts regen about every few days until another long run. Check the dpf sensor isnt melted. Read a few reports that on ea288 engines the sensor is prone to heat and can melt/be damaged. Alasdair
  3. rdrahota joined the community
  4. Today
  5. Yes everything is missing in that connector, you need something like this https://fr.aliexpress.com/item/1005009980414262.html?spm=a2g0o.productlist.main.7.3dc62ec8BrxS2D&algo_pvid=451b1547-3812-4d8b-bb82-cc7e7de662d3&algo_exp_id=451b1547-3812-4d8b-bb82-cc7e7de662d3-6&pdp_ext_f=%7B%22order%22%3A%22250%22%2C%22eval%22%3A%221%22%2C%22fromPage%22%3A%22search%22%7D&pdp_npi=6%40dis%21EUR%2111.99%2111.99%21%21%2113.32%2113.32%21%40210381f017903173815226031e0dfe%2112000050750775247%21sea%21FR%21914286551%21X%211%210%21n_tag%3A-29919%3Bd%3A583a5b7a%3Bm03_new_user%3A-29895&curPageLogUid=7ANdsZuFX3Pg&utparam-url=scene%3Asearch%7Cquery_from%3A%7Cx_object_id%3A1005009980414262%7C_p_origin_prod%3A
  6. Which vid as read from something else that was published?
  7. I had a feel around in bottom of door but couldn't find anything. I have tried loosening bottom screw eventually to the point where you couldn't pull on handle but barrel not coming out. Tried key in it and pulling no good and tried trying with a screwdriver.
  8. Hi
    Sofo replied to longbloke's topic in Hellos and Goodbyes
    Welcome, You'll find many gruntled Skoda owners here (and a few disgruntled ones). 😉
  9. Sofo started following Hi
  10. Firmware Update to 369 then Patch
  11. Skoda dont exist, Only Cross Flash to VW Firmware with Skoda HMI is the Solution
  12. if u can find someone who can do the DCC Slider Mod for you, that will make the suspension perfect!! sadly its not easy to find someone who can do it, globally. firmer/lowering springs alone doesn't do it perfectly as the car can still bottom out. stiffer swaybars help to an extent with keeping the car flatter, but again, not perfect. performing a DCC Re-calibration helps a good deal, but on BIG bumps, it can still bottom out. the DCC Slider Mod on the other hand is a game changer. essentially the DCC module is loaded/flashed with the parameter file (suspension algorithm) from a VW Arteon. no hardware change. after doing this, the car is so so so much more composed over bumpy road, speed humps, corners, potholes and no more bottoming out!! as added bonus, ur DCC settings go to 15 levels, ranging from Comfort+ to Sport+ i had this done a couple of years ago now. i'm also running Eibach Pro-Kit springs, with front & rear swaybars, and i've also done the DCC Re-calibration.
  13. Yesterday
  14. vladocker joined the community
  15. RichiP joined the community
  16. Counting the hours before the handover scehduled tomorrow! 🤩 Having it delivered on not-so-sexy Luter 19" Nordic winter tires, heading for the mountains on Saturday. Will be a nice upgrade from running a classic Audi throughout the summer season.
  17. There should be, lots of stories of people dropping it inside the door.
  18. Undo the top a few turns and then begin undoing the bottom one a little at a time whilst pulling on the lock and it should pop out. I think I had trouble with the online guides because mine was stuck.
  19. Do you recommend a Eichach Pro Kit alongside the B8 bilsteins?
  20. the fault code is C100D13 Says left hand Parking Brake Motor voltage supply - open circuit Wondering if it could be a simple thing such as dirty connector but not sure about disconnecting it as don't want to break the clip on the connector.
  21. We hung around and were fortunate to see a Spitfire, Hurricane and Dakota 1470330~2.mp4
  22. Hopwood78 joined the community
  23. Angle tightening is essential for fasteners that are taken into the plastic region, but far more often it is simply a far more accurate way of tensioning a(ny) bolt compared to torque alone. The impact and variability of friction when tightening only by torque creates wide uncertainty in the achieved pre-tension. Angle tightening is independent of friction because the bolt extension is directly related to thread pitch and the angle used. Smaller torque plus angle gives a far more predictable outcome. So it's just a better way of tightening important fasteners, not a guarantee that the bolt in question is permanently lengthened in each usage.
  24. snowglowjoe started following Skoda Karoq
  25. Hello bud, Exactly as I've read, anything 1/4 torn are stretch. Ai tells me they are an extra turn but I'll try and look into it further. Someone on a fb page said he's always just reused them without a worry
  26. julienf joined the community
  27. Not normal (and let’s face it, it’s a change that you’ve flagged so you’re on the right track). My money’s on a lower arm bush split meaning as the weight moves forward under slowing down (you mention lifting off but not about braking…?) and then moving back under acceleration there is plenty around the bushes that can move enough to have metal strike metal. Best bet is to get it to somewhere to get it up on a ramp and have a good look and wiggle around.
  28. Bought a new cylinder from a local motor factor, then tried to buy a matching one from ebay (the factor could only get one) and the ebay lads said 'are you sure? that's not the right one'. and we discovered that my old pistons are 22mm and the one the factor gave me was a 19.5mm for an ABS car. My truck is too old and **** for that kind of disaster preparedness. The ebay dude VERY kindly gave me the correct part number which has now gone via autodoc (hmm) and evri (eurgh) and hopefully in a few days we'll have working rear brakes again. No sills ordered yet, I need to wait for payday.
  29. Hi, I am looking for a 2 DIN fascia for my Skoda Rapid after fitting an after market 9 inch android head unit. The part code is in the title. Anyone know where I can get one in the uk? There are hundreds on eBay but they are all in Lithuania....!! I don't want to go to main dealer as I'm sure they won't be cheap. Any help would be appreciated, thanks Image attached.
  30. Hi, I'm looking for the file to unlock carplay on my MIB2. Can you help please? 🙏
  31. mpg_cloud joined the community
  32. Ash content was 20%, which I was told was quite good/normal for a 71,000 miler. I do regular 10 mile runs around town..ish, and a 15 mile there and same on return blast down my local motorway once or twice a week. As I said, I hold the appropriate gear to keep the revs up to 2500-3000 as much as possible when I sense it's regenerating....usually when the mpg won't go above 43.5 whereas it's usually in the low 50's Never had an issue, and do lob a bottle of DPF cleaner in the tank a couple of times a year too to try and keep on top of it. I'm probably worrying about nothing. Absolutely love this car btw.
  33. Hello, I have a 2021 Škoda Superb Combi 4x4, 2.0 TDI DSG, 7-speed. I would like to know what could be wrong, or whether this is normal. At low speeds, usually in first or second gear, when I lift off the accelerator and then accelerate again, I can hear a knocking sound coming from the front of the car. For example, when approaching a speed bump, I release the accelerator and then press it again, and I hear a knock from the front. In other words, if I am driving on a flat road at around 20–30 km/h and repeatedly lift off and then apply the accelerator, I can hear a metallic knocking sound coming from the front. It seems to me that the sound is more noticeable when I let the engine slow the car down and then accelerate again. What could be causing this? Is this normal for this car, or could something be worn or faulty?
  34. When I did my MK2 I just reused the originals and have had no problems although I believe they are stretch bolts so should have been replaced. Think if it gives a torque and then a degree angle they are stretch. If its just a torque setting then they are not. Alasdair
  35. I've been out today in the car and it's updated to version 0334 successfully! Two problems that I had since I bought the car two years ago was that when I pressed a location pin on the map that I want to go to, it came up with the address as England, Deutschland and also, when I looked in Traffication, it showed the traffic laws for Germany but it never issued any notifications for the UK. The dealers tried to fix it but without success and said I'll have to wait for a software update and at long last it's done. It now shows the address as United Kingdom and the traffic laws for the same. I'll have to wait to see if I get any notifications now as I've said yes to all the options, so hopefully something will happen.
