- HELP! Hot brake AFTER changing caliper and flexi-hoses
Rust around fuel filler door
I have just spoken to Skoda's extended warranty department who were very helpful. Skoda have nothing to do with a claim. It is down to the dealership warranty manager to make the decision. It only goes to Skoda annually in the form of an audit so it is Caffyns that are lying to me. Looks like I will be going back to Caffyns
- Rust around fuel filler door
Wrong suspension springs -help
I managed to do this but didn't realise until the car was in the garage having a broken spring changed! Turns out you can match them by eye and buy a new key from amazon for a cheap price, kind of defeats the object of having them, so I am now back to normal bolts on all wheels!
They have a Warranties Manager. Ask the Dealer Principle who theirs is, or ask him / her if they are covering that position.
I have the new 0334 update installed 2 days ago & this morning I had another popup for "application updates".... I clicked ok so let's see if it comes back again or if it is really fixed now. I'm not convinced it is really resolved by 0334 infotainment update...
summerflame joined the community
Soaked passenger footwells front and rear
Better still, once the source is found and fixed - use a de-humidifier if driveway/garage plug-in access is available.
Claim update. Skoda finally managed to contact Caffyns, the dealership, who claim Skoda warranty rejected the claim without giving a reason despite telling me it was because it wasn't corrosion. Caffyns have asked I return so they can take more photos, more (?) they never took any in the first place. I have an email train with Skoda but interestingly they rang me to say they had suspicions that Caffyns have asked for this to cover themselves so no proof. I asked for the number for warranties but for some reason customer services can't provide one. Anyone have it to hand. They told me to go to the ombudsman. There's a 6 month wait there so I guess Skoda are just hoping I go away! I won't be returning to Caffyns so they can cover their backsides.
I had the same message as yesman yesterday when I pulled up for a doctor's appointment, though I didn't have time to read it properly before everything was switched off. No further messages came up on the short journey home. I'm not using the car much at the moment as we're having a new bathroom and cloakroom fitted, so it'll be interesting to find out in due course if it's finally fixed.
How-to Guide to Upgrade MIB2 to MIB2.5
New screen should be delivered later today. Car was critically low on voltage so that may have also had an impact. All packages got an OK after installing and the log file on the SD card states all partitions etc completed succesfully. So I am hoping it was a voltage and/or screen issue. I ended up pulling the fuse for the radio as MIB unit was stuck at this point and draining the battery. Car now recharged to 98% SOC and I have bought a higher amp charger! Will make sure car is well charged before recommencing the task. I have been in touch with @pab567 as the resident MIB expert and he is confident that it can be recovered if theres no improvement on the new screen!
Lower seats
I suggest test driving a Sportline as the seats have very good side support. I’d go as far as saying they are one of the most comfortable seats I’ve had in 55 years of car ownership ( I may of course previously owned rubbish cars I suppose). The seats in my previous VW Touran also had good side support, and they would probably fit the runners too - plenty available in the breakers, R Line Tiguan seats might be another option.
Skoda Fabia Monte Carlo 1.2 TSI CBZB - Alternator belt tensioner replacement and Water pump recommendations
it was, but not any more. go for INA, Gates ... In the original OE (Original Equipment) box under the catalog number 03C145299Q, there is an automatic tensioner (spanner) which for the Volkswagen Group (VAG) first installation is usually produced by Gates or Litens (which closely cooperates with the INA / Schaeffler groups). this pump on photo is produced by NIDEC GPM, Germany producer for OE VAG engines.. now produced in Jiaxing, Zhejiang, China.
2008 Roomster - Scrubbing noise (Help please)
@jim-mapps Re it being an Auto. Is it a Tiptronic? Has it ever had the box serviced with an oil change? Even though VW / Skoda never gave them as Schedule, Recommendation or advice on Oil Changes.
Evolution13 started following 2008 Roomster - Scrubbing noise (Help please)
Kamiq MY20 MIB3 Update
Hi Roberto, could you post the Mega archive again? I’m in the same situation you were in at the start and I’d like to know how to do it. Best regards from Milan
Stefanoio started following Kamiq MY20 MIB3 Update
Thanks. The noise definitely comes from the front though and all tyres wear evenly. It's very strange. One to think on thought, cheers.
Stefanoio joined the community
messed with fusses
If the car wont turn over or start check fuse 49. Its the small brown one just above relay marked 645 at bottom of picture. Its the clutch switch fuse so if its blown car wont turn over but dash etc will come on. Alasdair
Lower seats
I do not find the current seat setup uncomfortable, but I think one click below the current lowest setting might make the ride feel a bit smoother as we would feel the side to side rocking or sway/body roll less.
- Emission control system faulty warning light ON
Haiderali123 started following EML - P03AA00 - ECU Update or sensor? and Emission control system faulty warning light ON
Oil temp while towing - help please
No. I didn't realise how critical it appears to be. Though with the upgrade radiators, and twin fan figured it should have coped with what is essentially way below it's stated capacity.
Lower seats
Id suggest setting your seat up using a physio guide such as the one linked on the page below. https://www.physiomed.co.uk/simple-movements-improve-lifelong-energy#video-with-guide-18 A low seat can restrict visibility and cause aches and pains in different ways other than your knees. Physically you're generally better sitting higher but slightly reclined and legs not straight out.
Has anyone had the issue with EML coming on with code P03AA00 - Cylinder 3 Pressure Sensor Citcuit Range/Performance? I've had a look online and it says a ECU update fixes this issue as Skoda/VAG released a TSB to address this issue by updating the ECU to version 1825 (im currently on version 0780). Anyone have any ideas about this or had this issue? 2021 Skoda Kodiaq 2.0TDI 200bhp DTUA engine code.
harmonic humming at motorway speeds
Worth a close look at the rear tyres, especially inner wall edge. Estates are very prone to camber issues causing sawtoothing/feathering and noise. I had this a while ago and a 4 wheel alignment sorted the issue. Tend to run the tyres at a slightly higher pressure as well, I'm using Crossclimates on my 4x4 Estate. Could be something else but worth checking the basics.
TasMan started following harmonic humming at motorway speeds
Lower seats
I have the seat at its a lowest as I don't like a driving position like a bus driver. I need my knees straighter otherwise they ache on longer drives. I'm 5'11". The rear passenger room is praised in many Karoq reviews but it seems to rely on the driver having the seat higher & towards the steering wheel. If I have a comfortable driving position rear legroom is less than in my previous Seat Leon.
Rear light bulbs
Does anyone know how to gain access to the reversing light on the tailgate? Dont have reversing cameras on mine. At night cannot line up the tail quickly when backing into my unlit drive; especially bad in rain with fogged and wet windows and side mirrors. An upgraded LED bulb would boost visibility way better.
Nipa started following Rear light bulbs
Some photos of a genuine water pump, not sure if they help. Plastic impeller. Possibly from 2010 (410)?
