  2. I'm a bit late to the party here but are you sure it's the servo? I remember not long after I got my mk1 the vacuum hose that's connected to the servo had split which resulted in a complete loss of servo assistance.
  3. My Karoq is out of warranty for about a month now. Been holding out hoping for an All In offer but doesn't look like it's happening - just keep seeing adverts saying service plan prices have been frozen for the rest of the year 😒
  4. JXR started following All in servicing
  5. Today
  6. Actually €120 off, from €860 (including mounting and balancing of the 4 wheels). It's ~€190-195 each before the bargain, so ~160-165€ each in the end (without mounting etc.).
  7. Probably yes, cuz UK is not in EU anymore 😕 Okay i will keep diggin 😎
  8. I did consider it but I am not certain of how the dimming function works as if is a top layer on the glass it could get damaged. Didn’t want to risk it having sourced the mirror WITH dimming/heated glass for less than £50!
  9. Didn't you think to scrap the mirror with a razor blade (of course with slow movements, to avoid bouncing into the plastic trim all around) ? Very efficient on our induction cooktop and never scratched it...
  10. Texter joined the community
  11. Another diagnostic tool to add to your collection? What can this one do that your others can’t?
  12. Prices seem mad sometimes. Range from £150 to £400 on uk eBay. Cheapest currently is £150 but not sure about postage to Latvia as there would be import duty, or you risk declaring lower value and not being insured. https://ebay.io/m/EBd4oo Perhaps someone within eu can advise. @pab567 may be able to source one.
  13. MakisVeny joined the community
  14. There was a nice package today.
  15. Okay, thanks for a reply 😎 Next question is where to buy it? Cause i'm from Latvia, and only site where i can find it is rrr.lt but the price for a second hand is WOW 👽
  16. €120 each or €120 for all 4? Either way it’s a good price!
  17. Dear vehicle dismantlers of eBay. Please please please don’t write on the most expensive part of the wing mirror with tipex/paint pen…. 30 Minutes with a soft plastic trim tool and some window cleaner and it’s as good as new! I could have used a solvent on it but I dare not in case of damaging the dimming function. I Will need to plug it in to the car to adjust the glass down to remove it so that I can swap the black mirror cap onto it. But that’s a door card off job and not one to do in the dark at 2•C!
  18. I had the same experience... 30 GB of files on the pendrive, but after 45 minutes of driving, my version changed from 23.2 to 26.11:
  19. Do you work for them?
  20. I'd recommend using the Autodoc app to search for car parts it's actually quite convenient. It makes tracking your order easier and reduces the risk of mistakes.
  21. Here I look at the lowered ride height front springs and the standard ride height front springs for the Superb MK2 1.6TDI. These front springs will be the same on both the hatchback and the estate versions of this car. It's the rear springs that usually vary depending on whether the car is a hatchback or estate, with the estate usually having slightly stiffer rear springs than the hatchback version...all other things being equal. Although 338mm-306mm=32mm, that's not the difference in the front unladen ride height because when you take into account the different wire diameter and number of coil turns the difference in the front unladen ride height is about 20mm. This could be useful if you decide to fit standard ride height front and rear springs. Kilen came up with the OEM part numbers and Sachs has supplied the specifications of each spring. Superb MK2 1.6TDI lowered ride height front springs 3C0411105P Length 306mm Wire diameter 13.00mm Number of coil turns 5.25 Superb MK2 1.6TDI standard ride height front springs 3C0411105B Length 338mm Wire diameter 12.75mm Number of coil turns 5.75
  22. Tyres have production date. First 2 digits are the month from 01 to 52, then last two digits of the year.
  23. Routemaster1461 started following Model help
  24. ItsChrisW changed their profile photo
  25. Yes, that's correct. However, the original poster also wasn't able to activate the taillight animation.
  26. The superb mk2 parts catalogue only lists two rear shock absorbers for the FWD lowered ride height cars. One is for the softer springs, and the the other is for the stiffer springs. Aftermarket rear shock absorber brands will often sell you the same rear shock absorbers for lowered ride height, standard ride height, and increased ride height, ie. a one size fits all approach. So at least you have rear shock absorbers that are specific to lowered ride height and FWD...assuming they haven't already been replaced with aftermarket shock absorbers. Bilstein B4 19-151083 rear shock absorbers are sold to replace ten different rear shock absorbers including both 3C0513049BD and 3C0513049BE lowered ride height rear shock absorbers, and a number of standard ride height rear shock absorbers. Lowered ride height is also known as sports suspension. Superb MK2 rear shock absorbers (1JC=Lowered ride height/Sports suspension) (1X0=Front Wheel Drive) 3C0513049BD Rear shock absorber for sports suspension 0YB, 0YC, 0YD,0YE 3C0513049BE Rear shock absorber for sports suspension 0YF,0YG, 0YH,0YJ, 0YK
  27. Broraaen joined the community
  28. I assume you've read that Installation of rear dynamic lights from FL on Skoda Octavia A8 (NX) Pro
  29. "Hello. I need a wiring diagram and a step-by-step guide for routing the wiring and connecting to the CAN bus for the installation of an electric tailgate actuator on a 2017–2020 Skoda Octavia A7." Вітаємо! Мовою спілкування на Briskoda за замовчуванням є англійська. Будь ласка, скористайтеся онлайн-перекладачем для публікації повідомлень. З повагою, адміністрація Briskoda. Hi, the default language of Briskoda is English. Please use an online translation tool to post. Regards, Briskoda admin.
  30. Доброго дня потрібно схема як підключити та Покроковий процес прокладання проводки, та підключення до CAN-шини схема електропроводки Установка электропривода багажника на Skoda Octavia A-7. 2017-2020
  31. Lotte joined the community
  32. aleks0603 joined the community
  33. It will not raise the Floor. It will fit in the spare tyre well. You may have to put something on top of it to support the floor.
  34. Same here with 1.5 petrol...dealer is aware and had car in for 3 days for a sw update....and it has stalled once since then...I'm not confident...
  35. I can't give you the part number but we had this issue on our previous Yeti and I followed this 2018 thread. I bought both parts but the main one was wrong, despite trying to carefully match and even the garage said it's very easy to get the wrong one. I would have a look at LLL Parts schematics or Skoda-parts.com as a starting point.
