  2. Ah didn’t think so, I quite like the dimming
  3. Today
  4. Hi guys, My radio was stressing me so I bit the bullet. These were my steps... (0742 maybe not needed but I did it anyway) 0463 → 0469 → 0741 → 0742 → 1790 → 1798 → 1800 Radio seems to be working ok, my wifes car so I haven't spent mych time in it. Looks good and works with my phone now. Massive thanks the everyone on here who helped but especially to the tech-savvy heroes who risked their own radios, that first upgrade is the hardest!
  5. Can anybody do me a favour and take a picture from underneath the yellow clip, I’m wondering if there is some type of washer on the underside.
  6. A few things I'd look at on that one specifically, as a diesel auto vRS is quite a different car to a manual petrol SE L. 1. Warranty. Skoda's standard warranty is 3 years, but the third year has a 60,000 mile cap and it all ends three years from first registration. On a 2023 car there may only be months left, or it may already have ended, so check the registration date and ask exactly what cover comes with it. 2. Gearbox. The 200PS diesel's 7-speed DSG is the wet clutch type (DQ381), which has a fluid change in the schedule. VW Group's UK trade guidance puts it at 80,000 miles for that gearbox, so at low miles it won't be due yet, but ask the dealer to confirm the gearbox from the VIN and to show the service history on Skoda's own records rather than just stamps in a book. 3. Your driving. Think honestly about how many short trips you do. The Mk4 handbook says that if the particulate filter light comes on, you clean it by driving with the engine warm at 60 km/h or more with the revs at 2,000 or above, and if the light hasn't gone out within 40 minutes it hasn't worked and needs a garage. If most of your driving is short local runs, a diesel may not suit you however good the car is. 4. It uses AdBlue, which you top up yourself between services, so factor that in. 5. If you buy from a dealer, you've got 30 days to reject it if something is wrong, and for the first 6 months a fault is assumed to have been there when you bought it unless they can show otherwise. So use those first weeks to test everything, including the DSG from cold and in stop start traffic.
  7. Is it possible to get to pipes that feed matrix from engine bay. Remove them from engine/coolant system and flush through with garden hose leaving matrix in situ? Alasdair
  8. I replaced calipers and flexi hoses on my 69 plate Challenge two years ago. Assuming you need the same, the hose part number is 5Q0611775M
  9. AKK joined the community
  10. What does your temperature gauge read in day to day driving it should be around 90c , is your thermostat working, can the fan be run bypassing the normal connection.
  11. Thanks, I understand. I’ll try using other available pins, if I can find any. I’m not planning a front-end facelift for now, everything is set up only for the rear-end conversion.
  12. The two signals are just for the animation. You would, of course, need to wire your headlights to match the facelift version. As far as I know, the BCM supports this. I haven’t wired it up myself, as I personally feel the animation is pointless—though perhaps I’ll get around to it when I retrofit the LED headlights.
  13. Hi Hi! How did you connect the two additional wires to the BCM (5Q0937086BR) at pins T46B/35 and T46B/3? In my case, these pins are already occupied and lead to the front parking lights. I have a 2019 Kodiaq.
  14. https://www.briskoda.net/forums/topic/531352-petes-rescue-roomster/page/2/ Manifold valve shown in a post about one third of the way down page 2. But read first bit with diagrams to get an overview.
  15. My car Skoda Rapid 2013 just overheated a bit, and complained about oil pressure, I newer hears my fan spin.. So I think this could help me.. Are you able to maybe support me in my srarch for the problem?
  16. Ciux23 joined the community
  17. It may be the spring thad broken too and taken the top mount with it. This is what happened on mine. I got a garage to do mine, but I think it’s relatively straightforward if you’ve got the tools. You either have to split the hub from drive shaft to take the strut out or compress the spring in situ to remove the bottom end of the strut from the lower control arm. I have the workshop manual I can share with you if you require it. Really good guide here:
  18. Binx1310 started following Top mount
  19. Hi! Thanks for reaching out, your iOS demo looks really nice. For now I’m not looking for contributors, I want to focus on the Android version first. Good luck with your project!
  20. Yesterday
  21. Fabiaidan joined the community
  22. Build code L08 means they are 5Q0411105GN front springs. According to Sachs this front spring has length 318mm and wire diameter 12.5mm. Build codes 1JA+0YE means they are 3Q0511115M rear springs. According to Sachs this rear spring has length 360mm and wire diameter 12.75mm. Kilen/Lesjofors list a front spring sold to replace 5Q0411105HS for the VW Passat B8 Alltrack. KYB sells a front spring to replace 5Q0411105HS with a 326mm length and a 13mm wire diameter. Kilen/Lesjofors list a rear spring sold to replace 3Q0511115AT for the VW Passat B8 Alltrack. KYB sells a rear spring to replace 3Q0511115AT with a 364mm length and a 13.75mm wire diameter. Although 326mm is only 8mm longer than 318mm, the 0.5mm increase in wire diameter should mean that the 5Q0411105HS front spring increases the front unladen ride height by about 15mm. Although 364mm is only 4mm longer than 360mm, the 1.00mm increase in wire diameter should mean that the 3Q0511115AT rear spring increases the rear unladen ride height by about 15mm. Conclusion: 5Q0411105HS front springs and 3Q0511115AT rear springs should give the car about 15mm of increased ride height and provide a much needed increase in stiffness.
  23. I’ve also used Bosch aerotwin on other cars too, including Skoda Octavia & Fabia, & had trouble with fitting on one & ended up going to the local dealer for wipers & couldn’t get the twin pack to work & had to get two individual blades, I seem to remember that they have part numbers on the blades which I’ll have to look at
  24. Our 2016 Vrs TDI came with an AGM battery as standard and we never had any issues, our 2019 Kodiaq came with an EFB which died after 3 years, replaced with a Yuasa AGM, recoded with OBDELEVEN all working perfectly. Our new Scala also came with EFB which had to be replaced after 3 months under warranty the replacement lasted another 3 months. Turned out the ECU was somehow killing the batteries. ECU replaced under warranty and a new AGM battery fitted all good after that. Think it's a bit of pot luck with the quality of some of the batteries Skoda fit as standard.
  25. The car in question is diesel and an automatic, as opposed to my manual petrol SE L. If I was to go for it, it would be the first time I'd ever owned a diesel car in 30 years of driving, and the first auto I'd ever owned too. Just wondering for those with experience, if there's anything in particular I should look out for or be wary of? It's a fairly low mileage example with a supposed full service history, so in theory everything should be in good shape... Although as we all know, when it comes to the Mk4 any kind of theorem is little more than just a guess Appreciate any input, it's just an idea at present but interested in people's thoughts
  26. Yeah mine are just on or off.
  27. My late 2015 (MY16) Octavia had the battery (AGM) and alternator replaced under warranty in mid 2016, the EFB fitted then currently tests as 89% health at 82% charge (DIN) with internal res. of 4.61 milliohms. Due to frequent short trips, I use external charging when SS stops operating consistently - usually around 2-monthly during winter.
  28. Go to top right and click on your avatar/user name. ( EJB ) Go down to Account settings. Go down to email address and on the right click the 'change' tab. HTH. Thanks. AG Falco
  29. AGFalco started following Change details.
  30. The LEDs won't dim like the normal bulbs did in the foglights.
  31. Don't know yet. Not had the car out on the road since I replaced the fogs.
  32. Skiprat77 started following Top mount
  33. Only had my superb a few weeks. Yesterday it started making a horrendous twang. I suspected a spring , turns out the o/s top mount has left the chat. So I wanted to ask, is it a pretty straightforward DIY job. And what's a decent replacement brand to use. Its a 2016 superb estate L&K 4x4 2.0tdi 190. Many thanks
