Upgrading from MIB1 to MIB2 on skoda octavia MK3
Yes you need to change the usb port if you want to have carplay, part code 5Q0035726E. By the way do you own an OBD device such as OBD11 or VCDS?
What to look for when buying
Thats a smart looking car plus really like the colour. Lot better colour than my cappochino beige octavia. Hope you enjoy it Alasdair
I was referring to generic aftermarket direct TPMS systems - not OEM. Definitely do not consider worth the cost of fitting one of these to a vehicle that already has a perfectly adequate TPMS system fitted!
Inexplicable tyre deflation - no puncture, valve OK
The thing can be, if they spot any marking on the inner surface of the tyres - like that that will be caused when a car has been moved with a flat tyre, then nowadays typically they will declare the tyre to be unrepairable. Kwikfit tyre pricing, at least in the past, Kwikfit can offer 2 prices, one for booking online and another for turning up and asking - you can easily work out which one will be lower without putting it to the test. Last time I had a slow puncture, I made sure that I stuck a trolley jack under that side/end of the car to avoid it even resting on a deflated tyre. My older daughter seemed to get lucky when she drove her car round to her tyre place last year with a very soft/flat tyre, I warned her not to plan to try that trick again as it could get expensive, it sounds like it happened again for her last week - I've not heard what the outcome was yet!
Fabia 1 dash dump
Hello i have big trouble. Some time ago, I wanted to read the EEPROM from the instrument cluster. Unfortunately, my kid was playing next to it and the EEPROM was erased. Does anyone have the EEPROM file from the 6Y0 920 841L instrument cluster with Maxidot?
Simondecoder started following Fabia 1 dash dump
Silencing the loud spoken traffic congestion warnings
I think it is the Traffication app, if I am not mistaken. You can check your settings in Traffication to disable the sound or even the entire notification.
ducu started following Silencing the loud spoken traffic congestion warnings
HS1970 started following Skoda Superb Mk3 (2015 - 2023)
HS1970 joined the community
Octavia MK4 MY2023 OTA update went wrong (03A8)
Welp, the infotainment is offering 03A8 update on my late 2023 Octavia every time I turn the car on. I don't want to. I don't need it. It's going to mess things up. Bugger off, Škoda, and stop behaving like a Stellantis product. 😖
nin0 started following Octavia MK4 MY2023 OTA update went wrong (03A8)
Wiper Blades
I am looking to buy replacement front wiper blades for my 74 plate Superb Estate. Just wondering if the Bosch A8674S are compatible?, or recommendations would be much appreciated. Thanks.
MintyPanda started following Wiper Blades
- CarPlay crackling issue, software update fix?
Sorry for the late reply, I don’t have canton on my car or at least don’t think so as of my speakers not beeing labeled with it. Do you think i should change the usb port also? I already have a usb port with jack next to it
UmOm456 joined the community
Very high bite point on Skoda Fabia 2 2011 estate 1.2 tsi (CBZA) 5 speed manual
Sons is a mk1 55plate and one side of the clutch disk disintegrated. Probably down to old age as there was still a reasonable amount on the flywheel side. No air in system. It only had 60k on the clock when he got it it so it had only being doing around 3000miles a year so could also have been an elderly driver that slipped it a lot. Good shout getting it noted in the contract. His has been very reliable apart from clutch. Have had to do a couple of suspension bushes/ball joints, rear brake shoes and as said fitted a new slave cylinder but nothing major. Pretty good for a 20 year old car. Alasdair
rich_70 joined the community
Hi everyone, I hope someone can help me. I have a 2021 Škoda Fabia with the Swing infotainment system. Part number: 6V0 035 869 H Hardware: 695 Software: 8742 I’m experiencing the well-known Apple CarPlay crackling/distorted audio issue. The sound starts crackling after a while. I have tested multiple iPhones and they all show the same problem, while Android Auto works perfectly. My Škoda dealer confirmed there is no newer official software available for my VIN, but I have read that several people solved this issue by updating to MU 8755 (MEN2_EU_SKGPx_P0080L_8755). Would anyone be willing to share the firmware or point me to a working download? Thanks in advance!
Jory started following CarPlay crackling issue, software update fix?
Remote App Pre Heating / Cooling & Also Infortainment Updates
I find that both heating and cooling do work well if they start, but at busy times it's not unusual to have the attempt to contact the car time-out multiple times. For example it will work OK at 10am, but no chance of getting it to connect at 8am when everyone is preparing for their day. I'm guessing that Skoda have undersized the servers that handle the requests. When it does work it does an effective job, provided that the traction battery had a reasonable level of charge, I'm not sure what the lower limit would be.
SteveMcK started following Remote App Pre Heating / Cooling & Also Infortainment Updates
Jory joined the community
@Warrior193 As far as i understand there is no necessity to buy original part. But there are different sensors listed as if the part matches. Which sensor should i look for?
JacobSladder joined the community
pushtunas started following Updating maps and radio logos - slight issues and few questions
Software Update available for Bolero?
Hi, I was looking for the latest firmware update for my Scala (MIB3 Bolero). I had problems where the unit would sometimes reboot by itself spontaneously. The Bolero had the following system details: SW Train: MEN3_EU_SK370_P2345L MU SW: 1790 I didn't want to take the risk of bricking the unit, so I made an appointment with the dealership. They told me that they weren't sure if an update would fix the problem, but they were happy to diagnose it for me. So I left the car yesterday at the dealership and they gave me a rental car. This morning, I got a call that the car was ready. They diagnosed that the unit had faulty software on it. They replaced it with the correct software with MU SW: 1800. I didn't had to pay anything, it was free of charge, and I gave the rental car back. Now the unit is working flawlessy. Kudos to the dealership and Skoda Netherlands.
Hi from the Netherlands
Hi, my name is Nick and I live on the west side of the Netherlands, about 15 minutes away from Schiphol. In September 2025, I bought a Skoda Scala 1.0 Sport Business from 2023, to replace my Opel Corsa D from 2007 with 220k KM, which was still running and driving good. I bought the Scala with 35000 KM, and found out that the battery was broken after I just got home and want to drive somewhere. It was solved under warrenty. Right now the car has 48xxx KM's and I'm very pleased with it's performance, fuel economy and handling. I just registered on this forum to browse around for tips and trics. Kind regards, Nick
I'm pretty sure 100m at 20psi and lowish speeds wouldn't be the reason the tyre was not repairable.
ScalaNick joined the community
It is possible to fit an aftermarket direct TPMS system - although I'd not consider it worth the cost. In my experience with a number of slow punctures, the indirect (ABS) system is accurate enough. Tyre pressure checks should be part of regular driver routine, along with fluids.
Emsee joined the community
- Heated REAR seats: coding and visualizing
Update: I called 5 skoda service. They all said it can not be done. They mentioned that if there is no direct tpms on the car when it is produced it is not possible to add this equipment.
Podders joined the community
- Activating SmartLink on Swing 3
pocem joined the community
Oh wow, that's quite concerning... We ended up signing the contract earlier today, but made the dealer add that they have knowledge of the clutch bite point being high and them confirming that it's normal and the clutch is in good condition into the contract. Did you figure out if it was the air in the system that caused the problem? Also, was there wear on the clutch when you removed it?
Sagittarius 19" alloy cover loose and fell or theft?
Don't forget Asda. I needed four tyres due to cracking, ordered online and fitted at my local tyre centre. The tyre centre manager said I had paid an amount less than he could buy the same tyres for. tom
Head Gasket?
I agree doubt you would get white smoke if its a bad oil cooler. White smoke is normally HG so maybe both? Alasdair
