Digital cockpit.
I was under the impression that, by 2025, all Skoda Fabia cars had, as standard, a 10.25" Virtual Cockpit. However, I now realise that the SE Edition model is the exception and its standard 'screen' specification is as stated below Infotainment and Navigation DAB - Digital radio reception Wireless SmartLink for Apple CarPlay and Android Auto 8" Skoda Infotainment touchscreen display 8" Digital display There's a video about the 8" digital display here Although you will not be able to have the separate round rpm and speed dials display you were asking about and that's available with the 10.25" Virtual Cockpit, there's still quite a lot of flexibility. The full digital 'look' is very tidy (image below) and what I used to use on my 2021 Hyundai i20 that had a similar type of instrument cluster.
About to buy Octavia vRS
Annnd just picked up her up. Water pump and LSD oil change has been done by the dealer (at no cost to me) and, full service history with Skoda, recently had DSG serviced too. Right now, I'm a happy bunny 👍🏻 All in all, an excellent service from Skoda Southend.
lufa1986 started following hrdinaveliky
Can I enable Indirect (ABS wheel sensor based) TPMS on 2012 Yeti SE?
Hi All,I haven't posted for a while, Wifey's Tdi Yeti still trouble free until last week. Had 2 new tyres fitted on front, 3 weeks later she gets a nail in one. It would have been an easy puncture repair, but she drove it (miles?) until after parking somebody told her the offside front tyre was flat. She got no TPMS dash warning and said she couldn't feel anything odd in steering (?) although as soon as I arrived to put on the spare I could see the body canted at an angle. The new tyre was trashed and unrepairable. I checked the driver manual for TPMS and despite a procedure, there's no reset switch in the switch panel. Sad because I have a 2007 V.W with TPMS. I've been through VCDS long coding for Gateway, ABS, and instruments modules, Settings in MFD now show tyre pressures but basic ABS indirect doesn't use pressure sensors. A dash symbol for TPMS does now show up. So what's up? Does the coding procedure here and in other places only refer to a Yeti active sensor system? Can I still get the basic ABS system to work? Do I need the TPMS hardware loom cable and switch to get it active? From old drawings of kits it just looks like a switch on a pair of wires. When I scan the system I now see new module 4C in the Gateway list, but it's empty of data or not communicating when scanned. Is this a real control module hardware addition for active sensor TPMS? Any help appreciated, particularly if you have a 2012 Yeti with the TPMS reset panel switch. Does your MFD Settings say anything about indirect TPMS or offer a second means of reset? In the process of coding I accidentally hit ABS basic Settings 'start test' and got into ABS fault error 0486 loop that was really hard to get out of.
voxmagna started following Can I enable Indirect (ABS wheel sensor based) TPMS on 2012 Yeti SE?
Vacuum hose stuck in dipstick tube during oil change – what did it snag on?
I just did an oil change on my 2015 Fabia III 1.4 TDI and had a slightly alarming experience with my oil extractor pump. I've used this before without issue. I inserted the hose through the dipstick tube as normal and didn't feel like I'd pushed it in especially far. I gave it a wiggle as I turned on the pump, but when I came to remove the hose, it was completely stuck. After a bit of careful pulling, the hose unfortunately snapped about halfway along the dipstick tube. I then removed the dipstick guide tube from the engine (mercifully easy!) and, with some gentle but firm persuasion, managed to retrieve the remaining section of hose intact. Thankfully, nothing appears to have been left behind in the engine, and everything is back together and working normally. What I'm struggling to understand is how it got stuck in the first place. My assumption was always that the extraction tube bottoms out in the sump. I certainly don't think I forced it in excessively, so I'm surprised it managed to snag on anything. Interested to hear if anyone knows what it might have caught on.
Mark 2 l&k headlights
This is driving me nuts. In my headlight cluster, there are 2 bulbs. A short one with a wire attached, and the bulb cannot be removed. It is held in by a spring clip. What should I be looking for if I need to replace it? The wire has a spade end which can be disconnected to completely remove it once the spring clip is undone It lights up on full beam after the main bulb stops moving Silly question, I know, but as I said, driving me nuts on the net.
Arcadash started following Mark 2 l&k headlights
- 2017 SW update questions??
mmw started following 2017 SW update questions??
mmw joined the community
So good
Just got rid of a nightmare 1.6 tdi , the regens started being a problem , the water pump broke , the egr played up , started cutting out randomly, never got to the bottom of this , the electrics were dire and her dash was often an xmas tree however i love the size and versatility of these so i have bought a low milage pre dpf 1.9pd , this is more like it and much better economy
Advice please on DMF
Hah yes. You know what you mean. Has got me wondering though. There are list of ‘. Mens shed clubs’ around us for woodworking etc. turn up , chisel some wood into a cupboard or Something. Pay to use the time there. Wonder if there is anything similar for the mechanics world where you can use a 4 post and some air tools. Slightly off topic but just gone down a mental worm hole!
I was the same. Got quoted £700 for my sons MK1 fabia plus was going to have to wait for a few weeks. Decided to do it myself as time doesnt cost me anything. Managed to do it for around £200. Cars worth about £1000. Used to have a local garage friends I new well and they said if I ever needed a shot of there lifts help your self over a weekend as long as they were free for Monday. Alas Robert retired and garage is now gone. My plan is to get myself a 4 post lift in the next year. Will pay for itself in no time plus will be able to get on top of underbody corosion properly and these days I'm getting a bit old and stiff for crawling under cars. Alasdair
- Advice please on DMF
Amundsen MIB2 Firmware Update
Hi, I'm trying to update, but I can't find the link to do so. I tried Mibsolutions, but it seems to be having problems could someone please send me the download link for MST2_EU_SK_ZR_P0369T? My current version is MST2_EU_SK_ZR_P0359T Thanks.
chico25 started following Amundsen MIB2 Firmware Update
Rember doing a volvo 940 which thought no probs. Just disconnect propshaft and drop Gbox then new clutch and back together. I know what you mean re crushed. They are some weight plus they never sit level and are impossible to lift when under a car. Always want to tilt the wrong way. Trying to lift it under a car is a nightmare. I got this which is an absolute godsend when I did my sons Only £50 off amazon and allows you to raise engine/gearbox independantly Needs channels to sit in though. Worst one weight wise was my son in laws Landrover 110 TD5. Gearbox and transfer box at the same time. At least its got the clearance but what a weight. Took three of us with two trolley jacks to do it Alasdair
chico25 joined the community
Tips to remove consol bush bolt on front swing arm. Very stiff been at it for hours.
Not sure if its been done before. Cars on around 80k but large bush pretty soft and looks like plastic part not sitting flush with bracket and the bump on inside of bush is furthest away from engine not nearest. Reckon I will have to destroy it to get swing arm out. Definitly Recomend 50/50 acetone/hydraulic fluid seems to reach parts others fail to. New bolt threads in ok and feels secure and not loose but will try and clean up threads a bit before fitting. New bolt is completely threaded but old bolt only partly but same length 100mm. Did find the old bolt had a very slight bend in it which wouldnt have helped trying to remove. Reckon its the hardest bolt I have come accross to remove in 40 years. Might seal the threaded hole with silicone once fitted to stop salt etc getting in. Not sure if a smear of copper grease is a good idea with a bit of thread lock on end for good measure. Wish me luck for passenger side!! Alasdair
Radio Head Unit Issue
Remove it and post the picture of label from upper housing
Ive done gearboxes on the floor before but its a right PITA, thats on the floor of my mates barn, which is set up as a workshop with lifts (sadly none were free at the time). Its not that its a really challenging job its more that gearboxes are just a terrible shape and weight to man handle, took me and two friends to get mine back in and Im pretty sure I was nearly crushed to death by it about 4 times. @Alasdair1 has covered the other main points, id just do the master cylinder for what they cost its not worth not doing it, some clutch kits do come with them included.
Sharpy64 started following Advice please on DMF
Hi! Newbie here from UK
Hi all! been lurking a little while & thought it about time I introduced the pair of us!😉 My Yeti is 2013 2.0 140 DSG 4x4 L&K with 106k miles, after buying it I had the cam belt done, Haldex & DSG serviced by a VAG Indy, &the infotainment system (RNS-510 Dab) is off being repaired (constantly restarting). It's a fabulous car to drive, & hopefully will be more reliable than my Jag xf!!😆 I'm 64, & do a lot of my own work on my cars, using Indys when the work is above my pay grade! Just outside Cambridge UK I'll leave it there! See you in the forums!! Regards Skippy
skippy1962 started following Hi! Newbie here from UK
Oh well done. Very poor design in lots of ways. When I did mine recently, I found that the driver's side long bolt had been replaced by a much shorter one (65mm instead of 100mm), and that was previously done by a garage. Can only have had a few mm engagement with the thread in the console. ☹️
Buying a 2004 Superb ?
Had a 1.9tdi pd octavia and exellent car and engine. Even at 50k as the car is 22 years old so definitly due a belt change. Did mine myself and fairly straight forward plus water pump change at same time. Mine was 1.9tdi BXE. Not sure on your engine but mine had no DPF so no problems. Alasdair
Alasdair1 started following Buying a 2004 Superb ?
Doubt it would be easy on drive. Main problem will be getting car high enough to get Gbox out in the first place plus cant see the Gbox being much less than 60kg. Did my sons Fabia using a beam that sits accross engine bay and supports engine and gbox independently. I couldnt get car high enough to get Gbox out but managed to swing it out of the way enough to get to clutch etc. £1200 is probably about right. £400-600 for clutch and dmf and aprox 5-6hours labour as long as everything goes to plan. Reckon its a garage lift job unless you have access to a inspection pit. Factor in a new clutch slave cylinder at the same time. Alasdair
Hi I have 2014 superb and the head unit is stuck in software download ! It won’t turn off or on what is this and how It be resolved ! Any info would would be appreciated thanks
ESim causing problems
ESim After entering my pin number incorrectly 3 times I lost access to my primary user account. I eventually managed to get back in as primary user by changing the email address and password to the same on the log in on the car, on the app and on the Skoda digital I’d website. I created a new email address and password for these 3 log ins. This email address I intended to use only for the car. Everything worked perfectly for a couple of weeks until 2 days ago when Google blocked that email address citing unusual activity. After appeal I have managed to get the email address unblocked.. According to AI Google doesn’t like the fact that I have the setting for data ticked as the esim. I don’t pay a subscription to Cubic. I could untick the box and use my mobile but looking at my data usage on my phone it is very low, I have Android auto on all the time and the latest update 0334 download must have come via the esim because it is certainly not on my phones data record. Over air Map updates are around 30. GB so I would prefer to leave the esim switched on. Has anyone else had the problem of Google blocking their email address and if so how did they resolve it. I have tried all the suggestions given by AI without success. According to AL“When you start the car and it attempts to authenticate your Škoda ID (the primary user account), the vehicle uses its built-in eSIM (connected via Vodafone/Cubic Telecom in Europe/UK). Because the car's data is routed through a centralized regional telecom hub rather than a local mast, your email security provider sees the login coming from an entirely different region, triggering the "unusual activity" flag on your mobile phone.”
Round trip Calais to Prague - any tips?
Sounds like a nice trip. Yes German motorway services are serious price gougers... Always pays to look for an Autohof or a local station near a motorway exit. Will cost you less than 5 minutes in time. For example look below:
Skodaman33 joined the community
Hi all, I'd like to update my Karoq's MIB2 High to the final SKG13 release. Could anyone who has copy of MHI2_ER_SKG13_P4526 (MU 1440) share it, or confirm it's the right target for my unit? Car: Skoda Karoq 2018, UK System info: - SW train version: MHI2_ER_SKG13_P4514_1 (1163) - SW MU version: 1163 - Part number: 565035021B - Hardware: H54 Unit is unmodified (no GEM, no toolbox, no patches). Main reason: improving SmartLink/CarPlay stability with an iPhone 18 Pro. If anyone can share a link via PM, that would be much appreciated. Happy to report back once done. Thanks in advance!
odoro82 joined the community
Sub Woofer Install
Hi everyone, i want to connect pioneer TS-WX140DA to the oem multimedia (skoda octqvia mk3) , is there any harnesses adapter for it , and to replace the rca without cutting and destroy it . Any help please ??
