Got Locked Inside My Car - “Key Not Recognised”!
I used to have a dog that would lock the back doors, when they had a button to push down
AC coolant level/ system function indicator?
You can read AC system pressure with OBD eleven, I did it last week to confirm I have a partially depleted system.
CianKT started following AC coolant level/ system function indicator?
the truth about electric cars
Indeed but only for those with home chargers and the right tariff. Those public charger costs you mentioned would have evened thing up and possibly even swung the answer the other way.
See my answer above. Could have been done much cheaper the Inogen Bhogal (BSc Hons) quoted ie free or even got paid £5 for what she used if on an even better Octopus tariff !
You mention one side of the coin but there are plenty of other factors on the other side of the coin. More homes, those without drives, are getting approval to have cable channels through the pavement and the install grant has now been upped to £500 from £350 I gather.... https://www.birminghammail.co.uk/motoring/motoring-news/uk-households-without-driveways-handed-34073227 You may be a bit more limited in low population density areas like Northern Scotland but there are plenty of Public charging places where you can charge for less 65p a KWh. MFG are currently doing 59p per Kwh for the next 2 months, BE.EV is oft at 49p a KWh, sadly Southern Scotland is a close as they get to Northern Scotland, TESLA BRUM are charging 23p a KWh for much of the time at Frankley, M5 J3 Brum. The 3p a mile, when it comes in in 20 months time, looks like it will not be onerous. if one under estimates the mileage one does and only catches up when the annual reporting is done, has the money in a savings count to cover when due, pays on a credit card as some government sites allow and get some kick back. definitely get me to check my tyres more to check inflation and replace at 3mm tread to maximise rolling radius. Also, as I mentioned before, I and I suspect other EVs will choose the shorter routes through villages and towns to bring down the mileage rather than go the slightly quicker long way way round on the A roads and motorways. I think the mileage policy could backfire badly. Imogen Bhogal, BSC Hons, charged on a Octopus GO or IOG tariff it looks like so the 52 KWh R5 battery could be charged for a £5. I charge our R5, Scenic and Mini on the cheapest going rate on Octopus Agile which is sometimes, oft this summer, less than the Octopus GO or IOG, rate, sometimes about 5p a KWH, sometime about zero P per KWh and sometimes as low as minus 10 p per KWh so the Lincoln to Exeter I would have been paid £5 for the electricity used in that journey. Balcony / Plug in solar, especially when linked to upcoming home batteries, from Octopus-CATL, can mean most doing some charging from solar via home batteries. looking forward to the zero rating of home electricity in 58 days but frightened just much diesel, gas and petrol will cost and effect cost of living. Need to look more in to Heat Pump.
No surprise there given ait was effectively a rigged test using cheap overnight charging compared to full cost liquid fuel. And ONLY achievable in that scenario.
Skoda Octavia 1 RS
Scrap yard/ car breakers.
Coming back to this, when I initially read @PetrolDave 's response, I (mis?)understood "a diagnostic tool" to mean something specific to the high-pressure gas system, but, did you mean an OBD-II reader e.g. the OBDeleven that I own? I asked Google the question of whether modern cars actively monitor A/C system gas charge/pressure, etc, and came up with: https://autoacrepair1.com/how-can-i-check-my-cars-air-conditioning-systems-freon-level-without-opening-the-hood/ .. which comments: "You cannot accurately confirm your car’s exact refrigerant charge without accessing the A/C system with proper service equipment. An OBD-II scanner may show A/C pressure-sensor data, compressor commands, clutch status, evaporator temperature, and diagnostic trouble codes, but these readings only provide diagnostic clues. They do not directly measure how much refrigerant is inside the system." I'm aware that the OBDII information includes 08 - Air Conditioning, but what I haven't found is how complete is the monitoring done by the Octavia III (Facelift), in the sense of "Occasionally spending the time to have an OBDII device read the A/C control unit is actually likely to help you notice an impending A/C problem before you notice that the system isn't cooling properly"? Any thoughts? thanks,
- Transfering witter towbar to mk3 superb?
leolito started following Transfering witter towbar to mk3 superb?
- Heated REAR seats: coding and visualizing
Viorel_92 started following Installation of Dashcam , Heated REAR seats: coding and visualizing and Reversing Camera 'bBind Spot'
I search a lot regarding this topic, I also want to get rid of that but I don't think there is a way. I found something which I tried on my car but without any success: 💻 Hide parking sensor image overlay by default 5F → Long Coding → Byte: 16 → Bit: 7 → enable (hide sensors overlay by default)
^^^ Social Divide. Yes pay with the right Tariff. Home Charge fill up for £5. But if paying 65 pence a kWh Public charging gives you 7.7 kWh or just less. times 5 miles a kWh is 38.5 miles with the BEV. 75 pence a kWh is 33 miles from 6.6 kWh getting 5 miles a kWh. Coming soon to a BEV you might be driving an ADDITIONAL 3 pence a mile charge. (7.7 kWh getting 4 miles a kWh is only about 31 miles for £5.) That is real world BEV driving for many many people once the Cheap Battery fill has gone, if you ever had the very cheap charge up in the first place. PAY PER MILE. £5 for 31 miles then the additional 3 pence X 31 miles 93 pence. £5.93. Petrol at 163 pence a litre.. 3 litres for £5. 10 miles a litre =30 miles.
- Installation of Dashcam
eirelad1 started following MAF (P0101) and EGR (P0401) Faults – Looking for Advice
Hi all, I'm looking for a bit of advice on my 2013 Skoda Octavia Mk3 vRS 2.0 CUPA engine. I'm getting fault codes P0101 (MAF sensor range/performance) and P0401 (EGR insufficient flow). Has anyone experienced these two fault codes together? Could one fault be causing the other, and what would you recommend checking first? I'm thinking maybe an Egr that is sticking open, so maybe trying to remove and clean it might help, are there any good guides for my particular engine? Any advice or common causes would be greatly appreciated. Thanks!
Imogen Bhogal, first class Mech Eng science degree from Oxford, in the well selling R5, and her husband, Deep Bhogal, in a petrol Citroen. Both people are ex JLR engineering staff. Not quite even as he is much bigger / heavier than Imogen but the range achieved is so much it would have made little difference (spoiler, more than 4 times) swapping drivers around......... (I wanted pop green but my ordered car got damaged in transit so had to swap to yellow and very happy except for the extra £800 cost but should get back if I ever sell, but not planning to).
Afnguy joined the community
Skoda Octavia 1 RS
Hello everyone i would be really happy if someone will help me with finding gear knob for skoda octavia 1 RS this is the code for the product :1U0711141P IF You will find something hit me up please
Snow chains with 18" wheels
@26DIPP Is this for use abroad in a region where Snow Chains must be carried and fitted if sign posted to use Snow Chains? Fitting them is a plaster and time consuming. Making it more awkward is simply not clever. Clearance with clean chains is one thing, but what is important is the size / clearance once the chains get snowed up and the wheel arches do and the area between wheel and where the mud flaps would be fitted if fitted. There have been threads over the years with other Skoda Models and Snow Chains fitted to bigger Wheels / Tyres than the SKODA Recommended ones.
Evolution13 started following Snow chains with 18" wheels
Headlights problem
They are lit by LED, same type as on my UK 2020 SE model. LED strips hidden along the top inside, with thin daylight running light strip along the bottom. Surprised that both main and dipped beam stopped working. Maybe a wiring fault rather than the LED’s themselves?? Does the daylight strip light still work? Bad news - I believe- is that they are sealed, no way to change the LEDs.
Shuggyboatsuperb started following Headlights problem
Aulis2 joined the community
Understanding Safelock Most users on Briskoda agree that the notification simply reminds you that the car is fully deadlocked. When safelock is active, interior door handles are disabled so no one can open the doors from inside. Do not leave pets or people inside the car when safelock is turned on. How to Control Safelock Full Lock (Safekey active): Press the lock button on your key fob once. Disable Safelock: Press the lock button on your key fob twice quickly if you need people or pets to be able to open the doors from the inside. (If you have a pet that is able to open the door from the inside then please share).
New Superb wipers leaving a hazy/milky film after rain – anyone else?
I just picked up my new superb estate SE L Iv on Friday. I hadn’t been able to identify a rear wiper in the spec but there is indeed one fitted im happy to say. I agree with Coral-C that, for me, also, it is an essential item and under uk motorway winter conditions I used it all the time. I replaced the OEM front wipers with the Bosch ones and although haven’t tested them in the ongoing desert conditions of southern England yet, I could tell just by comparing them that they are more robust and better quality than the ones that came with the car. So far, I’m loving the new car. Still fiddling incessantly with settings but am getting well over 110 mpg in the short time I’ve been on the road, with a couple of hours of motorway driving and a few city low speed electric trips. The seats are great and the thigh support makes a big difference as well as the massage seat features. I’ve got a 3.5 hr drive next week and I’m really looking forward to it:) Thanks to the helpful suggestions I’ve already received from other members of Briskoda.
- CR170 Hard to start after replaced fuel tank.
As it turns out - yes. Pulled the pump - bottom and top halves not attached (and no sign of the spring either) and the key transfer pipes were disconnected. So someone had been in there before. Sorted that and all my issues seem to have been resolved 🤞- 2015 vrs occasional brake judder
Could it be the ABS?- Yesterday
- Headlights problem
- Timing of transition/implementation of the EU driver assist regs for different Skoda models
Cairus, Thanks - that's an entirely new rabbit hole for me! Avocet, Thanks for the very detailed answer, and I understand the complications. In summary, and this is subtly different (and I may have been less clear with the original question): If I can switch it off, and it stays switched off (unless I choose to switch it back on), then that's actually what matters to me. A 10 year old Octavia has some of this stuff - drowsiness alert for example - that was one of the first things I got rid of: it was uselessly inaccurate! The brake warning system (just a warning), despite the occasional false alarms, I judged to have more merit (it's possible to be temporarily distracted by something at just the wrong moment on a very busy road). But in each case it should be the driver's decision. On the older car, that is the case. What I can't tolerate is the idiocy of being forced to configure settings individually from scratch every time I get into the car. Could I (broadly) assume that both the Kodiaq and the Karoq prior to the facelifts (ie, Kodiaq Mk1, and Karoq up to 2022 or whatever the date was) are probably fine on both counts (remembering settings and SFD 2)? Or - to ask my question above differently (re the settings): Have people here using the Mk1 Kodiaq had problems themselves - or heard of problems - wrt user settings no longer being remembered? If not, then that presumably answers that question, at least here wrt the Kodiaq? The Certificate of Conformity - thanks again. Two elements here, a) what I initially narrow any search to, which is the above, and then b) DD once I see something I like. That Certificate looks like b) , ie something prior to buying. Along with physically checking... Ie, change some "driver aid" settings, switch off - come back and switch back on... Just now reading your reply to Lee01 - that's the crux of my question. Which versions have user settings that are remembered, and which more modern versions have now failed that test.... - CR170 Hard to start after replaced fuel tank.
