  2. AKK joined the community
  3. What does your temperature gauge read in day to day driving it should be around 90c , is your thermostat working, can the fan be run bypassing the normal connection.
  4. Thanks, I understand. I’ll try using other available pins, if I can find any. I’m not planning a front-end facelift for now, everything is set up only for the rear-end conversion.
  5. The two signals are just for the animation. You would, of course, need to wire your headlights to match the facelift version. As far as I know, the BCM supports this. I haven’t wired it up myself, as I personally feel the animation is pointless—though perhaps I’ll get around to it when I retrofit the LED headlights.
  6. Today
  7. Hi Hi! How did you connect the two additional wires to the BCM (5Q0937086BR) at pins T46B/35 and T46B/3? In my case, these pins are already occupied and lead to the front parking lights. I have a 2019 Kodiaq.
  8. https://www.briskoda.net/forums/topic/531352-petes-rescue-roomster/page/2/ Manifold valve shown in a post about one third of the way down page 2. But read first bit with diagrams to get an overview.
  9. My car Skoda Rapid 2013 just overheated a bit, and complained about oil pressure, I newer hears my fan spin.. So I think this could help me.. Are you able to maybe support me in my srarch for the problem?
  10. Ciux23 joined the community
  11. It may be the spring thad broken too and taken the top mount with it. This is what happened on mine. I got a garage to do mine, but I think it’s relatively straightforward if you’ve got the tools. You either have to split the hub from drive shaft to take the strut out or compress the spring in situ to remove the bottom end of the strut from the lower control arm. I have the workshop manual I can share with you if you require it. Really good guide here:
  12. Binx1310 started following Top mount
  13. Hi! Thanks for reaching out, your iOS demo looks really nice. For now I’m not looking for contributors, I want to focus on the Android version first. Good luck with your project!
  14. Yesterday
  15. Fabiaidan joined the community
  16. Build code L08 means they are 5Q0411105GN front springs. According to Sachs this front spring has length 318mm and wire diameter 12.5mm. Build codes 1JA+0YE means they are 3Q0511115M rear springs. According to Sachs this rear spring has length 360mm and wire diameter 12.75mm. Kilen/Lesjofors list a front spring sold to replace 5Q0411105HS for the VW Passat B8 Alltrack. KYB sells a front spring to replace 5Q0411105HS with a 326mm length and a 13mm wire diameter. Kilen/Lesjofors list a rear spring sold to replace 3Q0511115AT for the VW Passat B8 Alltrack. KYB sells a rear spring to replace 3Q0511115AT with a 364mm length and a 13.75mm wire diameter. Although 326mm is only 8mm longer than 318mm, the 0.5mm increase in wire diameter should mean that the 5Q0411105HS front spring increases the front unladen ride height by about 15mm. Although 364mm is only 4mm longer than 360mm, the 1.00mm increase in wire diameter should mean that the 3Q0511115AT rear spring increases the rear unladen ride height by about 15mm. Conclusion: 5Q0411105HS front springs and 3Q0511115AT rear springs should give the car about 15mm of increased ride height and provide a much needed increase in stiffness.
  17. I’ve also used Bosch aerotwin on other cars too, including Skoda Octavia & Fabia, & had trouble with fitting on one & ended up going to the local dealer for wipers & couldn’t get the twin pack to work & had to get two individual blades, I seem to remember that they have part numbers on the blades which I’ll have to look at
  18. Our 2016 Vrs TDI came with an AGM battery as standard and we never had any issues, our 2019 Kodiaq came with an EFB which died after 3 years, replaced with a Yuasa AGM, recoded with OBDELEVEN all working perfectly. Our new Scala also came with EFB which had to be replaced after 3 months under warranty the replacement lasted another 3 months. Turned out the ECU was somehow killing the batteries. ECU replaced under warranty and a new AGM battery fitted all good after that. Think it's a bit of pot luck with the quality of some of the batteries Skoda fit as standard.
  19. The car in question is diesel and an automatic, as opposed to my manual petrol SE L. If I was to go for it, it would be the first time I'd ever owned a diesel car in 30 years of driving, and the first auto I'd ever owned too. Just wondering for those with experience, if there's anything in particular I should look out for or be wary of? It's a fairly low mileage example with a supposed full service history, so in theory everything should be in good shape... Although as we all know, when it comes to the Mk4 any kind of theorem is little more than just a guess Appreciate any input, it's just an idea at present but interested in people's thoughts
  20. Yeah mine are just on or off.
  21. My late 2015 (MY16) Octavia had the battery (AGM) and alternator replaced under warranty in mid 2016, the EFB fitted then currently tests as 89% health at 82% charge (DIN) with internal res. of 4.61 milliohms. Due to frequent short trips, I use external charging when SS stops operating consistently - usually around 2-monthly during winter.
  22. Go to top right and click on your avatar/user name. ( EJB ) Go down to Account settings. Go down to email address and on the right click the 'change' tab. HTH. Thanks. AG Falco
  23. AGFalco started following Change details.
  24. The LEDs won't dim like the normal bulbs did in the foglights.
  25. Don't know yet. Not had the car out on the road since I replaced the fogs.
  26. Skiprat77 started following Top mount
  27. Only had my superb a few weeks. Yesterday it started making a horrendous twang. I suspected a spring , turns out the o/s top mount has left the chat. So I wanted to ask, is it a pretty straightforward DIY job. And what's a decent replacement brand to use. Its a 2016 superb estate L&K 4x4 2.0tdi 190. Many thanks
  28. Hi. If you have any issues with insurance at all for a change of engine then please feel free to drop me a line. Regards, Dan.
  29. Hi Pete. Found this on the Rapid Guides on here, Is this what you are meaning ? 1.2TSI Crankcase Breather Hose One Way Valve Replacement Guide (by Mintyfresh)
  30. Nothing the dealer can do about it. That is how the dash cameras automatically switch on and off is by detecting the actual voltage being fed to it. If it drops below a certain point, the camera switches off. When the car starter kicks in, there is a large drop in voltage everywhere in the car at the same time, so it is just as likely to do the same even if it is plugged into the power socket. At least with the camera wired up so it wakes up when the ignition is switched on, it removes the chance of you forgetting to plug it in, leaving you without any video protection in the event of an accident. If the voltage gets to a critical point when it is plugged into the 12V socket, the camera switches itself off to prevent it from draining your battery even lower. So wiring it in will prevent it being forgotten to be plugged in when driving and also prevent it from being forgotten to be unplugged when you aren't driving the car. For the small cost of an OBDII scanner tool, you can ensure that you can never forget to switch off the stop/start by tweaking the point in which it cuts in, all the way to disabling it completely, and also alter the way other things operate, and also enable some options that aren't operational unless you have a range topper car model.
  31. Hello all, long time lurker, 1st time poster. I'm having trouble with the (external) ambient air temp sensor. When I start the car in the morning (2010 CFGB TDI 4x4 estate) the sensor works fine, when I return to the car initially the sensor works and then it starts shutting down ---- on the MFD and then occasionally reads 58C then ticks down to the the actual outside temp and then shuts down. I have a Carly scanner and I get fault codes for the circuit being too low, too high, with the addition of 'sensor for outside temp, resistance too small" at the instrument cluster. I also get a faults for the air quality sensor, and the glow plug controller/relay and wonder if they're all connected? Also I get error messages on MFD for various bulbs being out I.e DRL, side lights etc but, no fault codes stored so wonder if this is also connected? So far I've replaced the external air temp sensor with a OEM part from DSD, replaced the plug and 100mm of the cable. I'm wondering where the sensor draws power and that perhaps there's something wrong with the wire in, I've chased it back to where the two cable meet with the rest of the loom that serves the engine bay and goes through the firewall seemly to the instrument cluster. I'm all out of ideas part from unwrapping the loom to see if there's a break in the cables or whipping out the clocks to see if there's an issue behind them. I'm hoping that someone has experienced the above and can help me solve this conundrum because it's causing mayhem with the HVAC system
  32. Adiwez joined the community
  33. Hi Pete. I will definitely give that test a go to see if it is possibly the fault you have described re. the breather diaphragm. Thanks for the heads up on that. Will keep you posted. Hi Alistair. Yes, that is the problem, tracing the source of the leak. I am sure I have pretty well eliminated steering (electronic) and brake fluid as there is no drop in the reservoir level. I am going to look into what Breezy Pete has suggested above and see where we go from there.
