Saying hello again for the first time in many years
Wow... A blast from the past but welcome back @mannyo . Sorry to hear about your woes and the curve balls life has thrown you but hopefully things are now back on the straight and narrow...
Welcome back and nice to say hi again @mannyo Last time we met was either at JKM on a rolling road day or at one of the New Forest meets. I'm afraid my trusty MkI Fabia Elegance (154.5bhp by the way ) has long since gone. In between I've had a MkII Fabia which was sold when we moved to Germany, a Rapaid Spaceback (sold a month ago) and I'm now in a 2023 SEAT Ateca.
fr1nklyn started following Ad blue leak - Crystalisation around injector / repair help
CD PLAYER
Thanks, I didn't know that. Still learning after all these years, to paraphrase a line from one of my favourite singers.
kamiltt12 joined the community
It's been a very long time since I posted anything here. Over the last few years, life has thrown a lot of curveballs my way, both good and bad. Some may remember me from the very early days of Briskoda, from what I remember I think I am something like member number 6. I was very active for a very long time on this forum, I started with my Mk1 Octavia vRS, one the first imported into the UK, then got a MK2 Octavia 1.9PD and then a Mk2 Superb. From there I had a couple of Audi's. Then life got in the way, both my Parents passed away, I got made redundant from my job in Dorset and times were tough for a long time. Today I am back in my home town, have a job working for a previous employer, and became a first time buyer in my late 50s after years of renting. My present car is a 2017 Volvo V90 Inscription with 2.0TD engine. I got it 5 years ago with 28K miles on it, and it now stands at 71K. So I am still around, I am not going to post much, but just saying hi. Here are two of the Audis, both taken at Briskoda Meets. Once is at Gaydon and the other was up noth somewhere.
Sprint yellow fabia
I have a 2011 fabia MK2 in sprint yellow with a factory sun roof and cruise control. How rare is this.
singian started following Sprint yellow fabia
Headlight condensation/air vents location
Skomaz - success (I hope) !! I had a closer look at the join between the headlight glass and the black casing and there appeared to have been a minute gap, literally millimeters but crucial. I've run a clear piece of tape all the way along the join and despite rain and a dip in overnight temperatures, the headlight lens has remained perfectly clear for nearly a week now. 😀I'm hoping this has finally solved the issue and so thanks for your feedback. I just need to make sure the tape stays adhered now but if the worst comes to the worst, I now know what the issue is and I can easily put some clear silicone along the join. Cheers Skomaz. 👏
singian joined the community
Ash load in DPF
This is the quickest way I can access this data using VCDS. In theory, it should reflect the actual condition, but I’m not entirely sure whether I’m correct.
2012 alarm issue
Can anyone help please. My alarm has been going off on my 2012 Octavia, I have tried turning off the internal sensor but to no avail. Seems to keep going off at intervals, especially at night which is making me popular with my neighbours. Any help would be very gratefully received
simonba started following 2012 alarm issue
OTA updates or the impossibility thereof
“The OTA update system uses the vehicle’s built-in mobile network connection to communicate with Škoda servers.” This should be explained more clearly. Vehicles with and without a navigation system have the SOS system connected to the mobile network via an eSIM with 2 GB of preloaded data, which should last 10 years (Proactive Service). What other connection is there in the vehicle to the Škoda servers besides a Wi-Fi connection to the home network—which is reserved for vehicles with a navigation system—or purchasing data from Cubic Telecom? I’m very curious to find out if carrier pigeons could do it!!! Translated with DeepL.com (free version)
the truth about electric cars
EVs are quite apart from tge standard tyre rumble and aero noise as motor almost silent though it does sing Jean Michelle Jarre when sub 20 mph. We are still waiting for those ENSO tyres which can give 10% more range and presumably are quieter as well.
CD PLAYER
Thanks to all for the help. 😀
I think it was also mentioned at the time of introduction as a means of noise reduction for those living alongside the motorway.
CataB98 joined the community
Ash load in DPF
Just to chime in, my car 2014 Vrs 2.0 Tdi CUPA engine, manual gearbox, has 248kkm now and OBD11 shows oil ash mass 57g with the limit being also 80g. My car uses about 1,5dl of oil per 1000km, has been like this for the last 100kkm. Only used 5W30 oil. The engine has good power and i can get 5-5,3 liters/100km consumption with 225/40/18 tyres in the summer with speeds of 100-120kmh.
Jo88Mak started following Ash load in DPF
DjZlatko joined the community
Shkelzen joined the community
crono joined the community
Monte Carlo Edition suspension question.
Our 25 plate Monte Carlo Edition has DCC and I wondered what experience others have had with it. When in normal D mode the suspension is ok until to come across bumps or dips in the road where it becomes a bit wallowy on the rear and sometimes bounces the boot content around. When in Sport mode the same bumps are dealt with well though the general ride quality is obviously harsher. It seems the rear damping in normal D mode is virtually nonexistent. Bumps taken at between 30 and 40mph. I currently have individual mode set up with the suspension set to sport but everything else to normal. Anyone else seen similar?
Liteboy started following Monte Carlo Edition suspension question.
Genuine tow bar
Hi, I have a Mk 2 Kodiaq. I am going to have the genuine retractable tow bar installed at my local dealer. I am assuming the tow bar will be compatible with my caravans alko hitch. Does anyone have any experience with this?
eddy1988 started following Genuine tow bar
I was just going on what the signs were saying as I drove on the motorway thru these regions. Would have been a bit much to put all that info on the signs but thanks for the indepth, not surprised on the multiplicity of these reasons, cheers.
Visually etc. My car of the day -today
Yep... In intrigued to take a look at one...
Suspension upgrade installed
Best compromise I’ve been able to find is adding a TTS solid rear bush to the rear of the front lower arm and a poly to the front. The 034 stuff is solid and well put together.
eddy1988 joined the community
They were actually introduced for a few reasons not just air quality, which is one element and caused by a variety of factors in that location, including industry, the shopping centre and the sewage works etc. The other reason for their introduction was to reduce dynamic loading on the viaduct during repairs but that rarely gets mentioned as it's inconvenient for National Highways.
DERAILER83 joined the community
Lukas_2611 started following Weird sound on new Octavia 1.5 TSI mHEV
Probably right but it does annoy me in places like the motorway near Birmingham and Sheffield when it says reduced speed limits due to pollution when it is the ICE vehicles causing the pollution and not EVs. I think the main developments will be in more EV trucks being on the market and its effects. EV trucks look capable of towing two containers / trailers rather than just the one that ICE trucks can also EV trucks are going to want to pass ICE trucks on inclines due to their superior climbing ability and this could cause a few issues.
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
Valerii joined the community
EV,s highly unlikely to be given their own NSL,s in the UK while ICE vehicles have different speed limits. Same thing as far as Electric HGV,s.
karolp1993 joined the community
Excellent alloys with near new tyres to fit Karoq and others
Now REDUCED ... £325 ono
The Games Manufacturers Play
@Guest_ was me.
