Martin0k94 started following FL Maxidot/non-Maxidot with pics
Karoq guide - engine advice and infotainment issues?
From what I’ve seen posted in this forum and the Facebook group, issues with the infotainment system are mostly to do with connecting to the MySkoda App, a recent issue with repeated update messages which is now resolved and moans about the Sat Nav - in the 30 months I’ve had my Karoq I’ve had no issues with infotainment system apart from the update messages, the Sat Nav is really good I use it all the time. After the initial 3 year free period expires there is a yearly subscription to get map updates and traffic info. 1.0 TSI seems to be a good engine no reports of issues from owners unlike the 1.5 TSI. If over 3 yrs old buy the Skoda All-in-one 2 yr service plan to get the Skoda 2yr warranty which is included.
thamestrader started following Karoq guide - engine advice and infotainment issues?
Travall dog guard for Mk 2 Superb Estate
Travall Dog Guard from a 2013 Skoda Superb Estate. I bought it new last October and the car was written off in June, so hardly used and as new. I’ve got a Kodiaq now and it won’t fit so hopefully someone here can benefit. We’re in North Wales, might be able to post it but no idea what the cost will be. I’ve not done enough posts yet to PM but if anyone is interested we can WhatsApp or something. £50
OrvilleTheDuck started following Travall dog guard for Mk 2 Superb Estate
Tire size conundrum
All Season 3PMSF (Three Peak Mountain Snowflake) tyres might be all that is needed if you do not require FULL SNOW Tyres. Plenty All-Seasons suitable for use in Snow or pisted or non pisted roads and even if Snow Chains are needed. @Mariosti The ABS / TPMS / TC will not give a monkeys if there are different widths or circumference of tyres fitted. Reset the TPMS. But you are intending changing the Diameter / Circumference. Maybe just fit narrower treads / sidewall to sidewall if cost is an issue. Set your Winter Tyre speed warning on the car if Winter / Snow Tyres are fitted.
Evolution13 started following Tire size conundrum
Tire size conundrum
If the tire size is not specified in the car's official papers (e.g. Certificate of Conformity), just don't use that size - there are plenty of reasons for that. BTW - if you're looking for a winter setup, why are you searching for All Season tires?
SkOmk4 started following Tire size conundrum
Those that have the 1.0 TSI all seem to be happy enough with them. I bought the 1.5 simply because the difference in fuel consumption was so small. So it made sense to me to go for the more powerful option, given the size of the car. How old is the car & is it a Skoda dealership? If it's outside the original three year warranty then I'd say buying from an approved dealer is essential. While I'm not aware of any specific infotainment issues, there are a number of others that really need to be covered. But that probably applies to most modern cars, given the complexity of the electronics & reliance on software combined, with manufacturer cost cutting. An example being LED lights which should easily outlast the life of the car. But Skoda have managed to produce LED indicators built into the headlight, that cost around £1k to replace. My car was new in June 25 & in December, the speed limit detection stopped working properly. Here we are nine months later & they're still unable to fix it.
Rbz5416 started following Karoq guide - engine advice and infotainment issues?
P0299-Underboost-2.0TDI 110KW DSG
in August I had 4 times P0299- Underboost. Car goes to limp mode with Error: Drive System. Turning car off and on deletes the message and car drives normally after that.I did 1000km after the last error with no problem . I asked VW workshop to do diagnostics and they said that its a actuator broken and that I need new turbo as only actuator cant be replaced. I logged live data in CarScanner Pro for Turbo position with variable geometry request and actual and there are no differences. Did anyone have that problem and did you had to change whole turbo( Prices is insane they are asking for 4000 euros)
digiboy94 started following P0299-Underboost-2.0TDI 110KW DSG
Martin0k94 started following Octavia Mk2 Workshop Manual free download
- Steering-wheel control of phone?
Skoda enyaq 2022 full electric won’t start after crash
Welcome to the forum. Do they have a trained EV technician? Was that just the Pyro Fuse that was changed then? The Electrician needs to be Speaking to another Electrician that is trained on working with EV,s I suspect.
Door lock barrel
How did you get on with your lock? I'm having same issue unable to remove lock barrel to remove lock mechanism.
Skoda Superb Alloy Wheels 18 inch from 2013 Superb Elegance Mk2. Set of four. Plus steel spare.
Hmm no, don’t know what that is. Just WhatsApp text, mobile and email. Think my daughters do though if that’s a way to get a safe PM to you.
Mk2 Octavia underside maintenance
Interesting I never thought about zinc I’ll take a look at it. It’s going to be a driveway job also unfortunately as I don’t have any access to a lift so can see it being very challenging job with a lot of grinding to before I can even think about coating it.
- skoda roomster 2008 starter battery exchange- how to remove those covers
Problem is folks mention when they have issues, not when they don't. Our first Karoq, which we traded in for another new one in March, was bombproof for the 8 years plus we had it. We've had no issues with our new one, or with our nearly 4 year old Kamiq. Having said that the infotainment system does take a bit of perseverance to set up correctly, with numerous options. Our salesman for our new Karoq told us one option wasn't included on our car, but I found it was switched off in the menu system, just needed switching on!
camelson3 joined the community
I use zinc spray lavishly on anything underside and around engine bay, including exhaust (note pure, high temp 400deg C resistant zinc for exhaust, cheaper zinc-alu will do for other parts). Easy to apply and easy to top up in places every couple years or so (cars not garaged). Zinc is better than other coatings in that it offers galvanic protection also of nearby exposed areas. Pinch welds / jacking points are definitely worth zincing up then painting over as visible, but for lifting using garage lift it is best to put in lift pads IMHO, I have had them on all cars. Not expensive, easy to install, double the amount of support points and save wear on pinch welds. I usually lift using a trolley jack with a wide rubber pad on a lifting point/ pinch weld, then put a jack stand under the lift pad. Of course, much easier with a garage lift. HTH.
- Im looking to upgrade my stock suspension but have no idea where to start
Skoda superb sportive estate 2023 suspension to soft
The Superb MK3 can leave with factory with increased ride height, standard ride height, or lowered ride height. Many Superb MK3 owners find the suspension on the soft side, but the spring rates are similar to the Passat B8...so it may be down to the shock absorbers. The cheapest way to improve the handling is to fit slightly stiffer rear springs, such as the rear springs from the estate, ie. 3Q0511115M. A more expensive way to improve the handling is to fit Bilstein B6 shock absorbers (if standard ride height) or Bilstein B8 shock absorbers (if lowered ride height). Before making any final decisions on what rear springs to go for, it's best to check what rear springs the car left the factory with. Creating an account on "skoda parts com" and parking the car (with its VIN number) in the online garage enables you to find the rear springs that the car left the factory with. Rear springs (according to the Kilen online spring catalogue) Superb MK3 2.0TSI 272PS 4x4 hatchback 3Q0511115AL Superb MK3 2.0TSI 272PS 4x4 estate 3Q0511115M Below, I've used the Sachs listings on autodoc to find out what the approximate specification of 3Q0511115AL and 3Q0511115M rear springs are. In the Superb MK3 parts catalogue, 3Q0511115M is shown as one up in the hierarchy compared to 3Q0511115AL. Sachs rear springs matching 3Q0511115AL Length 359mm Wire diameter 12.5mm Number of coil turns 8.0 Sachs rear springs matching 3Q0511115M Length 360mm Wire diameter 12.75mm Number of coil turns 8.0 Kilen 65126 rear springs (matches 3Q0511115M) (about £34 each) https://www.ebay.co.uk/itm/352663645884
- Yesterday
First Service Cost
First service, 30000 kms 12 months, oil and all filters , 340 €....2.0 l tdi 4x4, Greece, official service network
Tire size conundrum
Hi, Earlier this year I bought a 2026 Octavia IV RS Combi, and it came with 225/45 r18 summer tires. It's this time of year that I have to start thinking about getting a winter setup. I've noticed that even current gen Golf's use 225/40 R18 tire size, and quite a lot other cars do as well. I've also noticed that 225/40 R18 size has much more new premium tire models available (like Michelin CrossClimate3 Sport, or Goodyear Vector All Seasons 4), while they're not available in 225/45 R18 size. And interesting tires that are available in both sizes, like Pirelli SF3 are exactly 50% more expensive in the 45 profile compared to 40 profile. Needless to say, I see a lot of benefits of going with th 225/40 R18 for my winter tires setup, but that will give me over 3% smaller wheel diameter. Therefore does anyone know if that will work? Won't abs/esp go crazy? Is it possible to modify the wheel diameter in the car computer using a new OBD Eleven interface perhaps?
Ranzo joined the community
Should I Choose an Octavia?
Replying to the OP, I have had my Octavia 4.5 manual since new in March 2025 (built late 2024) and it has done 8,600 miles. It is brilliant on dual carriageways, motorways and long journeys. My only concern is with Assist Brake (AEB) and I have just written about this on a different thread; I do not know whether an automatic (DSG) would work better with AEB and I am waiting for replies on the other thread. I have had no other issues at all with the car. It was given a Main Dealer service at 5,000 miles. To recap, the car has been brilliant to own and drive except for the AEB. It will take 5 passengers in comfort. The rear seats can be folded down and the boot space is enormous. I know a taxi driver with a diesel Mk4 and it has done 100K miles quite happily. It is a large car to park in small parking spaces and the doors open a long way out.
After the issues with the radio it’s more than my marriage is worth to be spending more money on “pointless upgrades”!
skoda octavia 2025 tsi 1.5 manual
Octavia 4.5 with manual gearbox: Yes, I have had this a few times. If the revs drop too low in third approaching a junction it will cut out, sometimes even in second with the wheels still turning. It's not a huge issue. I always use Shell VPower but don't know whether that makes a difference either way.
Famous last words
Autonomous Emergency Braking in Manual Transmissions
I bought my Octavia 4.5 with manual gearbox in March 2025 with 22 miles on delivery - i.e. brand new with delivery mileage. Since then I have had 5 activations of Assist Brake (AEB) where it slowed instantly to a complete halt and stalled the engine. On all of these occasions, I was in complete control of the car and there was no danger to me or anyone else, but the car knew better. On three of these occasions, the car came to a halt and left me blocking the road and in danger from other traffic; I was left to restart the car and hope that I would get away from danger; on one of these occasions, there wasn't another vehicle for hundreds of yards in front or behind but Assist Brake objected to me making a right turn. On the other two occasions, the activation was nonsensical, e.g. I arrived at a T junction to turn left and was looking R-L-R, when a white van drove along the main road from left to right and the Assist Brake saw this and activated. I'm becoming used to the activations now, can recognise what is happening, and can restart the car and move off fairly quickly. Obviously, Assist Brake and subsidiary functions can be turned off but this has to be done every time the ignition is turned on. I like the car but I am thinking that Assist Brake and a manual gearbox don't go together. Questions: 1) Does anyone else with an Octavia 4.5 with manual gearbox have any experience of erroneous activations? 2) Can the sensitivity be turned down by using the in-car controls? 3) Can the sensitivity be turned down by the dealership? 4) With an automatic gearbox (DSG), would the car actually stall the engine or just stop with the engine running? If so, in which gear? 5) Do other VAG cars with manual gearboxes (e.g. the current Golf) have the same Assist Brake technology?
