Past hour
piotr1_1 joined the community
ScrapMyCarUk joined the community
- Bixenon Headlights auto-adjustment problem
maxpage joined the community
Thermostat Pipe O Ring
O ring purchased 👍
Today
L&K Front Fog light Bulb access?
Ah didn’t think so, I quite like the dimming
Software Update available for Bolero?
Hi guys, My radio was stressing me so I bit the bullet. These were my steps... (0742 maybe not needed but I did it anyway) 0463 → 0469 → 0741 → 0742 → 1790 → 1798 → 1800 Radio seems to be working ok, my wifes car so I haven't spent mych time in it. Looks good and works with my phone now. Massive thanks the everyone on here who helped but especially to the tech-savvy heroes who risked their own radios, that first upgrade is the hardest!
Bonnet support clip come away
Can anybody do me a favour and take a picture from underneath the yellow clip, I’m wondering if there is some type of washer on the underside.
Considering getting rid of my 2020 SE L in favour of a 2023 VRS...
A few things I'd look at on that one specifically, as a diesel auto vRS is quite a different car to a manual petrol SE L. 1. Warranty. Skoda's standard warranty is 3 years, but the third year has a 60,000 mile cap and it all ends three years from first registration. On a 2023 car there may only be months left, or it may already have ended, so check the registration date and ask exactly what cover comes with it. 2. Gearbox. The 200PS diesel's 7-speed DSG is the wet clutch type (DQ381), which has a fluid change in the schedule. VW Group's UK trade guidance puts it at 80,000 miles for that gearbox, so at low miles it won't be due yet, but ask the dealer to confirm the gearbox from the VIN and to show the service history on Skoda's own records rather than just stamps in a book. 3. Your driving. Think honestly about how many short trips you do. The Mk4 handbook says that if the particulate filter light comes on, you clean it by driving with the engine warm at 60 km/h or more with the revs at 2,000 or above, and if the light hasn't gone out within 40 minutes it hasn't worked and needs a garage. If most of your driving is short local runs, a diesel may not suit you however good the car is. 4. It uses AdBlue, which you top up yourself between services, so factor that in. 5. If you buy from a dealer, you've got 30 days to reject it if something is wrong, and for the first 6 months a fault is assumed to have been there when you bought it unless they can show otherwise. So use those first weeks to test everything, including the DSG from cold and in stop start traffic.
Heater Matrix Flush??
Is it possible to get to pipes that feed matrix from engine bay. Remove them from engine/coolant system and flush through with garden hose leaving matrix in situ? Alasdair
Alasdair1 started following Heater Matrix Flush??
- Vrs rear banjo bolt sizing
AKK joined the community
Skoda Rapid Radiator fan not working
What does your temperature gauge read in day to day driving it should be around 90c , is your thermostat working, can the fan be run bypassing the normal connection.
- Facelift Crystal Style taillights in the VFL
The two signals are just for the animation. You would, of course, need to wire your headlights to match the facelift version. As far as I know, the BCM supports this. I haven’t wired it up myself, as I personally feel the animation is pointless—though perhaps I’ll get around to it when I retrofit the LED headlights.
Pro1 started following Facelift Crystal Style taillights in the VFL
Suspect engine oil leak
https://www.briskoda.net/forums/topic/531352-petes-rescue-roomster/page/2/ Manifold valve shown in a post about one third of the way down page 2. But read first bit with diagrams to get an overview.
My car Skoda Rapid 2013 just overheated a bit, and complained about oil pressure, I newer hears my fan spin.. So I think this could help me.. Are you able to maybe support me in my srarch for the problem?
Claus@DK started following Skoda Rapid Radiator fan not working
Ciux23 joined the community
Top mount
It may be the spring thad broken too and taken the top mount with it. This is what happened on mine. I got a garage to do mine, but I think it’s relatively straightforward if you’ve got the tools. You either have to split the hub from drive shaft to take the strut out or compress the spring in situ to remove the bottom end of the strut from the lower control arm. I have the workshop manual I can share with you if you require it. Really good guide here:
- DataPlug app (trip log & refuel detection) – looking for Android testers
Yesterday
Fabiaidan joined the community
Skoda Superb Combi 3V539Z suspencion
Build code L08 means they are 5Q0411105GN front springs. According to Sachs this front spring has length 318mm and wire diameter 12.5mm. Build codes 1JA+0YE means they are 3Q0511115M rear springs. According to Sachs this rear spring has length 360mm and wire diameter 12.75mm. Kilen/Lesjofors list a front spring sold to replace 5Q0411105HS for the VW Passat B8 Alltrack. KYB sells a front spring to replace 5Q0411105HS with a 326mm length and a 13mm wire diameter. Kilen/Lesjofors list a rear spring sold to replace 3Q0511115AT for the VW Passat B8 Alltrack. KYB sells a rear spring to replace 3Q0511115AT with a 364mm length and a 13.75mm wire diameter. Although 326mm is only 8mm longer than 318mm, the 0.5mm increase in wire diameter should mean that the 5Q0411105HS front spring increases the front unladen ride height by about 15mm. Although 364mm is only 4mm longer than 360mm, the 1.00mm increase in wire diameter should mean that the 3Q0511115AT rear spring increases the rear unladen ride height by about 15mm. Conclusion: 5Q0411105HS front springs and 3Q0511115AT rear springs should give the car about 15mm of increased ride height and provide a much needed increase in stiffness.
Wiper blades for 2022 Karoq
I’ve also used Bosch aerotwin on other cars too, including Skoda Octavia & Fabia, & had trouble with fitting on one & ended up going to the local dealer for wipers & couldn’t get the twin pack to work & had to get two individual blades, I seem to remember that they have part numbers on the blades which I’ll have to look at
Our 2016 Vrs TDI came with an AGM battery as standard and we never had any issues, our 2019 Kodiaq came with an EFB which died after 3 years, replaced with a Yuasa AGM, recoded with OBDELEVEN all working perfectly. Our new Scala also came with EFB which had to be replaced after 3 months under warranty the replacement lasted another 3 months. Turned out the ECU was somehow killing the batteries. ECU replaced under warranty and a new AGM battery fitted all good after that. Think it's a bit of pot luck with the quality of some of the batteries Skoda fit as standard.
The car in question is diesel and an automatic, as opposed to my manual petrol SE L. If I was to go for it, it would be the first time I'd ever owned a diesel car in 30 years of driving, and the first auto I'd ever owned too. Just wondering for those with experience, if there's anything in particular I should look out for or be wary of? It's a fairly low mileage example with a supposed full service history, so in theory everything should be in good shape... Although as we all know, when it comes to the Mk4 any kind of theorem is little more than just a guess Appreciate any input, it's just an idea at present but interested in people's thoughts
Yeah mine are just on or off.
My late 2015 (MY16) Octavia had the battery (AGM) and alternator replaced under warranty in mid 2016, the EFB fitted then currently tests as 89% health at 82% charge (DIN) with internal res. of 4.61 milliohms. Due to frequent short trips, I use external charging when SS stops operating consistently - usually around 2-monthly during winter.
Change details.
Go to top right and click on your avatar/user name. ( EJB ) Go down to Account settings. Go down to email address and on the right click the 'change' tab. HTH. Thanks. AG Falco
AGFalco started following Change details.
The LEDs won't dim like the normal bulbs did in the foglights.
Don't know yet. Not had the car out on the road since I replaced the fogs.
