  2. After months, last time was 25th of June before the car went in to Skoda for warranty work. I washed the car today, been putting it off but after France/Belgium, Devon/Cornwall in the summer and then some other trips the car was filthy, more the wheels than anything Wash it twice due to only buckets!!
  3. Thanks, do you know how I locate the fuse please? Zero car maintenance skills
  4. The stats support it, more piwet and mire torque. My comoany Ceva was seeing several minutes quicker runs by the EV trucks running up from the Spanish ports that connect with Morocco up to Madrid and onwards. Ceva use Winrose EV truck for such runs.
  5. When the alarm backup battery fails it can leak and cause damage to circuit boards which can trigger alarm randomly. On a temp measure to silence it you could remove fuse for backup battery. It would stop the siren eventually once it goes flat. Indicators will probably still flash but at least it wont annoy neighbours. From memory its fuse 35 either 5amp or 20amp
  6. Exactly, but those speed limits where put in place before EVs were as common as they are now.
  7. What actually makes you think that electric trucks will out perform ICE ones in terms of towing etc? That certainly has not been demonstrated by the electric vans, or indeed cars towing caravans has it? Manuefacturers hyped up claims are never ever matched in reality and nowhere is that more evident than in the EV world.
  8. Thank you, battery seems fine but I’ll follow your other suggestions
  9. At motorway speed the drive by noise is dominated by tyre noise, so EV or ice the noise levels are similar unfortunately, and can, in fact, be higher with EVs due to the harder compounds and structure of the tyre needed for their (usually) extra weight.
  10. It may be the alarm siren backup battery thats failing/failed or also check the voltage of the car battery. My old donor cars go off when the battery gets a bit low. Try hoovering the sensor in roof. Think its near the interior lights. Sometimes a build up of dust or in my case a small spider was setting it off. Think the siren is rh front wheel arch under plastic cover. Alasdair
  11. Alasdair1 started following 2012 alarm issue
  12. Today
  13. Glad it seems to be sorted and fingers crossed it stays that way.
  14. Lovely. I had Superpro front droplinks on order but researching the length reduction on lowering meant they were still too long. Got the longer of the two RacingLine offerings as could adjust when on the ground. The TT arms have a solid rear bush - just standard front one though. Question @MarioVrs H&R says ARB bushes go in dry - did you go along with that?
  15. Wow... A blast from the past but welcome back @mannyo . Sorry to hear about your woes and the curve balls life has thrown you but hopefully things are now back on the straight and narrow...
  16. Welcome back and nice to say hi again @mannyo Last time we met was either at JKM on a rolling road day or at one of the New Forest meets. I'm afraid my trusty MkI Fabia Elegance (154.5bhp by the way ) has long since gone. In between I've had a MkII Fabia which was sold when we moved to Germany, a Rapaid Spaceback (sold a month ago) and I'm now in a 2023 SEAT Ateca.
  17. Thanks, I didn't know that. Still learning after all these years, to paraphrase a line from one of my favourite singers.
  18. kamiltt12 joined the community
  19. It's been a very long time since I posted anything here. Over the last few years, life has thrown a lot of curveballs my way, both good and bad. Some may remember me from the very early days of Briskoda, from what I remember I think I am something like member number 6. I was very active for a very long time on this forum, I started with my Mk1 Octavia vRS, one the first imported into the UK, then got a MK2 Octavia 1.9PD and then a Mk2 Superb. From there I had a couple of Audi's. Then life got in the way, both my Parents passed away, I got made redundant from my job in Dorset and times were tough for a long time. Today I am back in my home town, have a job working for a previous employer, and became a first time buyer in my late 50s after years of renting. My present car is a 2017 Volvo V90 Inscription with 2.0TD engine. I got it 5 years ago with 28K miles on it, and it now stands at 71K. So I am still around, I am not going to post much, but just saying hi. Here are two of the Audis, both taken at Briskoda Meets. Once is at Gaydon and the other was up noth somewhere.
  20. I have a 2011 fabia MK2 in sprint yellow with a factory sun roof and cruise control. How rare is this.
  21. singian started following Sprint yellow fabia
  22. Skomaz - success (I hope) !! I had a closer look at the join between the headlight glass and the black casing and there appeared to have been a minute gap, literally millimeters but crucial. I've run a clear piece of tape all the way along the join and despite rain and a dip in overnight temperatures, the headlight lens has remained perfectly clear for nearly a week now. 😀I'm hoping this has finally solved the issue and so thanks for your feedback. I just need to make sure the tape stays adhered now but if the worst comes to the worst, I now know what the issue is and I can easily put some clear silicone along the join. Cheers Skomaz. 👏
  23. singian joined the community
  24. This is the quickest way I can access this data using VCDS. In theory, it should reflect the actual condition, but I’m not entirely sure whether I’m correct.
  25. Can anyone help please. My alarm has been going off on my 2012 Octavia, I have tried turning off the internal sensor but to no avail. Seems to keep going off at intervals, especially at night which is making me popular with my neighbours. Any help would be very gratefully received
  26. simonba started following 2012 alarm issue
  27. “The OTA update system uses the vehicle’s built-in mobile network connection to communicate with Škoda servers.” This should be explained more clearly. Vehicles with and without a navigation system have the SOS system connected to the mobile network via an eSIM with 2 GB of preloaded data, which should last 10 years (Proactive Service). What other connection is there in the vehicle to the Škoda servers besides a Wi-Fi connection to the home network—which is reserved for vehicles with a navigation system—or purchasing data from Cubic Telecom? I’m very curious to find out if carrier pigeons could do it!!! Translated with DeepL.com (free version)
  28. EVs are quite apart from tge standard tyre rumble and aero noise as motor almost silent though it does sing Jean Michelle Jarre when sub 20 mph. We are still waiting for those ENSO tyres which can give 10% more range and presumably are quieter as well.
  29. Thanks to all for the help. 😀
  30. I think it was also mentioned at the time of introduction as a means of noise reduction for those living alongside the motorway.
  31. CataB98 joined the community
  32. Just to chime in, my car 2014 Vrs 2.0 Tdi CUPA engine, manual gearbox, has 248kkm now and OBD11 shows oil ash mass 57g with the limit being also 80g. My car uses about 1,5dl of oil per 1000km, has been like this for the last 100kkm. Only used 5W30 oil. The engine has good power and i can get 5-5,3 liters/100km consumption with 225/40/18 tyres in the summer with speeds of 100-120kmh.
