Matrix headlights with auto high beam
I had the same thing yesterday, decided to try the auto function and then couldn't remember how to turn it off. As others have mentioned I needed to wait until it auto-activated, and then pull on the stalk - that turns it off. Otherwise you're just toggling between manual high-beam and auto "matrix mode"
TAKATA Airbags fitted to Skodas can explode like a granade
This has been floating around for a little while, We had a 2007 Polo which was recalled in August/September and had a replacement airbag
Skoda Fabia 1.2TSI Monte Carlo 09/2011 - Electric Windows Fault
There were 3 quite different types of motor module fitted to mk2 Fabia during its production run, I think yours will be the last version but can check with VIN. I seem to remember there's at least two incompatible versions of the switchpack also. I'll message you to request the VIN and then I can look up for you. Still reckon a 5 minute look at the wiring in the bellows is the very first, and likely the only thing you'll need to do.
Skoda Superb Alloy Wheels 18 inch from 2013 Superb Elegance Mk2. Set of four. Plus steel spare.
These wheels are still available if anyone is interested.
- Advice required
- Advice required
The door window module may be repairable as mentioned. If you are getting one make sure the part number is identical. Quite a few on ebay that are for LHD cars so wont work. The wiring from door to door pillar as Pete said is the first and likely culprit if fuses are ok. I found by removing stay that stops door opening too far you get better access to rubber bellows. The loom plugs into a socket/maybe two on door pillar under rubber gator. You should be able to test continuity from there back into door once door panel is off. Watch the door handle release cable. Its clipped into a plastic bit that has a tendency to snap if not careful. On my sons it was temperamental at first. Passenger side would sometimes work then control/motor failed completely. I was driving and had to drive home with window open in -8C with wet slush hitting the side of my head. Pete repaired it and its been fine ever since. Alasdair
He's bought a policy with a Blackbox. Cheapest he could get was £1845 if he insured it from the 23rd November. It was £2660 if he insured it from last Sunday. I went with him and bought a temporary policy to get the car home, hence why I fee a little responsible and want to help him repair the fault. We used "Covered on Demand" for the learner cover, I think it's similar to marmalade, was really good. Getting back to the fault I've checked fuses 51 & 52 and a scheme on another thread pointed to checking fuse 11. This was my starting point. I was then going to check the Connectors on the Door Gator then start belling out the door loom, hence why I was looking for some help in locating the correct wiring diagram for the year \ model. Beyond this I've bought the drivers side double window switch from eBay, which I'm waiting to arrive. If they're not too expensive I'd also try and get a door Window Control Module, so I had the most likely components for when I have a go at finding the fault.
- ORU3 - OCU - SW0311 – Octavia (O3A8)
Amundsen MIB2 Firmware Update
Hello! I have a 2019 Škoda Karoq with the radio shown in the attached photo. Is there any new software available for it, and if so, where can I download it? Thank you!
DARGOS started following Amundsen MIB2 Firmware Update
Removing pcv valve
I wish sone one had told me when I was young "If it aint broke don't fix it" The blunders I made. In later life someone also told me the thing you worry about rarely happens ,but the real problems are the ones that come unexpectedly out of the blue.
Latest Software update information (Recommended?)
Just checked and my currently intalled software version is 2768
Leaking coolant - Superb 2.0 Tsi 4x4 2019
Thanks. If it's the pump, would coolant still leak when the car is not being driven.
Most obvious is to check for signs of coolant on the block or general area below the vehicle when parked. Most likely failure is unfortunately the water pump already mentioned. Expansion caps have been known to fail and leak as well.
UndertheRadar started following Leaking coolant - Superb 2.0 Tsi 4x4 2019
As for Insurance I know what you mean. We used Marmalade insurance for my son while he learned to drive. Bought a 1.2htp mk1 for him to learn as all our other cars were 1.9tdi or larger. I put the car on my policy and marmalade covered my son while he learnt. My NCD was protected and was cheapest way we could find. Immediately he passed his test he wasnt covered as its for learners only. Think they do a Blackbox scheme if he has the car in his name. Alasdair
Upgrade Carplay on my Superb 3T
Is this plug and play?
Superb2015-09 started following Upgrade Carplay on my Superb 3T
1.0 TSI manual: difficult to pull away smoothly
Yes, but it's a situation that has been designed in, whether intentionally or as a flaw that didn't need to be there and you shouldn't have to make adjustment to pull away smoothly. Making an adjustment is fine if you have time to do it and not under pressure. You shouldn't need anti-stall anyway. I've driven countless cars over the years and can count the number of times I've stalled on one hand and that was usually due to having a manual choke! And I've rarely been with other drivers who have stalled either. Sounds like another of those solutions where none was needed and is more hindrance than help.
My money would be on broken wires in driver's door bellows.
Coolant level has been falling since the summer. It seems to be mainly happening after drives, although it did also drop a little when it wasn't driven for five weeks. Ive been topping up with G13 coolant as needed, but it's just putting off the inevitable imvestigation. No obvious leaks in the hoses. Really hoping it's not the water pump. Before i take it to the garage, what could i check myself? TIA
Aciduzzo started following Leaking coolant - Superb 2.0 Tsi 4x4 2019
Part number for the S3 Estate wiper arm
Thank you everyone. It appears that it was fitted with the same wiper arm that was used on the 2015 S2 estate cars
Creaking dashboard
2025 Fabia SE Edition, intermittent loud creaking from passenger side. Comes and goes sounds like a crisp packet being scrunched.
robsie started following Creaking dashboard
Not sure on yours but on the MK1 the drivers side controller/motor also controls passenger side. My sons was the same and Breezy Pete on here repaired it for me. Get in touch with him if he hasnt already seen post. Excellent service. From memory there a couple of components that fail and stop it working. Check fuses etc first and also wiring at drivers door pillar/rubber gaitor in case theres broken wiring which is fairly common. Alasdair
Alasdair1 started following Skoda Fabia 1.2TSI Monte Carlo 09/2011 - Electric Windows Fault
Amundsen MIB STD2 infotainment system with Android in Superb II
I just ordered a used MIB2 from 2015 Fabia to my 2014 superb. I've read this whole thread, but I'm still wondering how can I bypass component protection and what exactly i have to do with wires? Are they plug and play with old RNS315? Car does not have reverse camera.
Takkis started following Amundsen MIB STD2 infotainment system with Android in Superb II
robsie started following Skoda Fabia Mk4 (2021 > )
- Car juddering during acceleration
Takkis started following Car juddering during acceleration
Takkis joined the community
PRich joined the community
Superb IV - what no scheduled charging??
That's interesting, thanks. Apparently the early version of the MK4 Superb manual mentioned scheduling, and the 'Immediate charging to 80%' button only makes sense if scheduling was available.
