  2. imart143 replied to Nimrod2's topic in Škoda Kamiq
    Look at any glass on doors, most of them have year of production. For example, my Karoq which is produced 2019, have number 9....... So if your have 5.... Than is 2025. Etc.
  3. imart143 started following Model help
  4. So just to confirm please What you saying vcp deffo will be able to code it?
  5. AmeliaParker joined the community
  6. ian-inhome replied to ian-inhome's topic in Skoda Karoq
    Thanks CJJE I already had the my Skoda app installed, I use it for keeping track of petrol usage etc. my subscription to Skoda connect runs out at the end of this month. Google assistant is being fazed out and replaced by Gemini, so the suggestion of using this feature on assistant is pointless.
  7. Alasdair1 replied to Nimrod2's topic in Škoda Kamiq
    Think the 10th digit in vin is year. According to google 2024 should be R ,S-2025,T-2026 etcThere are a few letters that arent used. Give dealer a phone and ask for 10th digit if they wont give you the VIN. Alasdair
  8. Alasdair1 started following Model help
  9. Today
  10. 3TCFFB joined the community
  11. Hello guys, can i have the newest update please! Thank you!
  12. the front fog lights work properly
  13. Heated front screens are wonderful in this cold weather. Standard fit item on my 2016 L&K & my first experience of one. Better still though is my wife's EV which we can pre-heat & defrost the entire car without even leaving the house.
  14. Not sure I quite got your point but here are two answers: 1. When I turn the ignition on first thing in the morning, I hear the LPFP prime just fine without weird noise. 2. When the car is up to temp and start/stop is active, when it cuts the engine at a red stop I hear the same whistling noise.
  15. EE-Lab joined the community
  16. Ah im with you, that makes sense. I've never had the luxury of a heated front screen.
  17. Hello, I would need help at fixing the rear fog light. Bulb is intact, the switch works and on the dashboard the indicator light for rear fog lamp turns on but at the bulb socket there is no power. Might be related that long time ago some cable burned and also the left driver door's panel lamp is not turning on when door is openend nor does the door open sensor is working for the driver's door.
  18. Thanks for reporting that observation - I'll go out and check my MY2019 Karoq. Until now, I had discovered that the best cure for the squeak was to take my hearing aids out.
  19. StEdmund started following Squeaky door fix
  20. One doesn't have a carburettor but some air thing! 😊 Now it seems that if its not detected by computer diagnostics it doesn't exist. I know how the accelerator felt under my foot before during and after the fault. I have experienced limp mode and it's a horrible feeling. And it was unnerving and didn't give me confidence . Now the dealership has said they think it's the slider switch on the indicator stick, which I may have inadvertently switched on and off , the speed limiter...but there's no way my small hands could do that when using the indicator, I have tried.
  21. Thanks. Good to know that the sensor can throw up pressure alerts without ABS or ESC so I'll get on the case with checking it out. much appreciated.
  22. Hi thanks Derek, Yes I understand that a lot of cars have limp mode, my old Peugeot did, it went into limp mode when there was a fault with the engine management system. That's the confusing thing about it, the engine light does not come on the dash. I know a little about old cars lol but not new, this
  23. A dipstick reading low while the engine is running is normal, because the oil is being pumped around the engine. Check it on level ground with the engine switched off, after a few minutes so the oil has drained back to the sump, and judge it then. The handbook wants it in the proper marks, never above the maximum. You have already changed the switch, so if the light still comes on, especially on roundabouts, treat it as a real pressure issue until the oil and filter change and a pickup check say otherwise. If the light comes on, stop and check the level the proper way rather than keeping going.
  24. @Binx1310 yep my car is the hatch and does have the standard heater wires, but what imeant wasby the time the windscreen wa clear the rear hadn't made much of a change, infact it wasn't totally clear until i was half way home,
  25. most tuning companies can remap once the ecu is unlocked but at the moment [ bearing in mind that the technology to unlock bosch md1 / mg1 ecu's has only recently been available] At the moment very few companies can or are willing to unlock themselves, but that is likely to change in the future, so most tuners are outsourcing, it's not just because they dont have the equipment or know how to do it, there is a risk when unlocking of bricking the ecu and with some ecu's a resistor has to be removed and re soldered etc and at £2k+ for new ecu's, it's a risk they are not willing to take.
  26. Is this with a manual gearbox? If the problem occurs only when using SS, it could be due to a problem with the clutch pedal sensor (if manual) - or the shift position sensor if DSG. When this fail to restart happens when using SS, does a message like 'start engine manually' display on the cluster?
  27. Your software is the latest version. Your maps is outdated (yours is January '25, as identified by 25.1) The latest map update is from within the last few months. You can manually download and install map versions, search the forum there's plenty of discussion on the matter
  28. Did you find your air con pressure sensor as I am looking for mine at themoment
  29. Wel joined the community
  30. The 2015 Octavia uses a Tyre Pressure Loss Indicator, not a valve sensor, so a false alert on the same corner can happen without an ABS or ESC warning light. After you have set all four tyres to the handbook pressures, store the values. Ignition on, then either CAR, Vehicle status, Tyre Press. Loss Indicator and SET, or press and hold the SET key until the warning light comes on, a beep sounds and the light goes out. If it still flags the rear nearside after a stored set, have the NSR reluctor ring and ABS sensor inspected for cracks, dirt or corrosion, and compare tread wear and tyre size with the offside, because the system is comparing wheel speeds. A lingering malfunction light can be an MOT Major on a 2015 car, so it is worth finding the cause rather than just clearing it.
  31. Didn't you know? All Skodas have a heated rear screen to keep your hands warm when pushing them 🥸
  32. I have only had my superb for 10 days but have never managed to get anything when swiping down from the top of the screen. Is this only available in certain displays or should I be able to to it whatever screen is showing?
  33. BillyParker started following Média display
  34. Have you tried to listen when the vehicle is at operating temperature but engine stopped but with ingition ON. The LPFP should be running, if you have the noise like that and it stops as soon as you go ignition OFF, you'll have your answer ;)
  35. 5 hours in total does seem high especially as they have lifts and should have the proper tools. The fact that the wheel is off centre and pulling slightly isnt right. I reckon something is out of alignment or the steering angle sensor needs recalibrated. Did my old Octavia in around 2 hours but its an old rusty car so nightmare to take apart but didnt affect steering etc. May need a wheel alignment check and if they are ok then steering sensor recalibrated. I would get them to check it over ASAP in case something isnt tight plus depending on whats wrong tyres may start wearing badly. Try full lock left and then right and hold for a few secs each time to see if it helps. Alasdair
