Kodiaq steering wheel vibration
Waiting for your feedback if any better on your side after changes. I am waiting if they will come to something new what it could be wrong.
Upgrade oil cooler
Well I upgraded the radiator to to the higher core 190 model. It's still crap - overheating both oil and water on incline - even at 65 kmh. Towing van is 1300 max Inc stuff in it. Not impressed.
Google Maps etc. in Virtual Cockpit
I could set it up on the table, I could test it. Why Only Columbus, MIB2 STD also have MOST
superb 2014 timing chain
I am a out to buy a 2014 superb tsi s estate, with Only 27000 miles on an EA111 engine. should i worry about the timing chain?
Rodfabia started following superb 2014 timing chain
Brake pedal soft but brakes fine. Doesn't pump up, no fluid leak - air in system or master cylinder problem?
I got air in my ABS unit once and I can confirm it causes a soft pedal. The pedal can be pumped hard with the engine off but would sink soft as soon as the engine was started. A little engine start sink is normal, an inch or so due to the servo, but I mean much more than that. Normal brake bleeding won't help but a VCDS ABS bleed procedure immediately cured the issue. You say you've refitted an ABS unit, I would not hesitate in saying you need to do the ABS bleed procedure on it. It is not only VCDS that can do that, many OBD scan tools can do ABS Brake Bleeding.
1.9 diesel fuel pump not working advice needed.
Hi, Can’t say if there’s fuel in the filter but there’s residue around the top. Does the filter need priming? I’ve been searching the net and think I’ve found the fuel cut off and what I think it is is picture below. If that is it there was not “click” when ignition turned on and off. If that is it any idea where I can get a replacement?
- Need help to identify Correct steering rack part number
Saying hello again for the first time in many years
This was my 2001 on a Y Reg vRS, some may remember it, yes that's the nurburgrimg. Poor thing did about 70 laps of that. After I sold it, I almost bought it back when it appeared on ebay many years after I sold it. Sadly it needed a fair amount of work to bring it back so I pulled out, and it sold to a breakers yard instead.
Thanks everyone, Good to see some of the old guard still around, just looked back and I joined here 24 years ago, that's scary. This is the Volvo, can't believe this is almost 10 years old now.
Hi from Mercury 009
Ah - the of a petrol or diesel! Maybe my problematic second hand 80K PHEV Octavia will come up trumps now multiple issues sorted and with ongoing oil crisis. You will still be in the money with all my recent service bills though!
BillyLeach joined the community
StevesTruck replied to Rsedmonds's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI'm fairly sure there's no lift pump on a D, I know there isn't on an SDI. Take a picture of your engine bay and I'll try to spot the stop valve. Is there fuel in the filter?
- 38 mph in 5th gear ?
Hi, I’ve had my first attempt to look at the issue and to be honest, I didn’t get far. First of all I found that the diesel gauge isn’t working so I put 12l in. I then cranked it and was getting no fuel out or either the bleed nipple at the front or the injectors. My plan tomorrow is to disconnect the fuel feed pipe from the filter and try to prime the pump from there. I looked and place my finger on everything that had a wire going to it but I neither heard nor felt anything clicking. So, today’s questions are: 1, is there a lift pump in the tank or should the fuel pump draw the fuel up? 2, where is and what does the stop valve look like? I’ve google it and noting that’s coming up on my search looks like anything I have 🤷🏼♂️
Finally signed up
Hi Shakelton Snap Octavia First Skoda for me in fact. Mk iV Estate SE Technology 1.4Tsi PHEV Covid model early tech Plenty of problems Not being a spanner twirler myself left the multiple red and Orange fairy lights to the main dealers It’s been an expensive introduction to Skoda Picking up after latest issue HV chiller failure after previous incorrect diagnoses. Hopefully will start paying me back with my job now. I am not convinced but must live in hope. Tbh at least it’s not diesel and the complexity of the hybrid is maybe a silver lining in view of current oil supply crisis
Hi from Mercury 009
Mercury009 started following Skoda Kamiq 2021 MIB3 update request (Hardware 040 / SW 1310)יין and Hi from Mercury 009
Error: selector lever...
I'm guessing it is due to some components that is being affected by the temperature. I'm seeing this error mostly in cold weather or in extreme hot temperatures.
Auto Start-Stop not functioning
This rarely works on my vrs - new from Jan, 10k now on the clock. I'd say I do decent mileage, at least to charge the battery sufficiently. Work is 20 miles away, never seems to come on then randomly at weekends maybe on short journeys. Combine it with auto-hold and it's not exactly a smooth motion when it does decide to work.
mork23 started following Auto Start-Stop not functioning
2020 Superb L&K here: Columbus 9.2" (MHI2_ER_SKG13_P4526, MU 1440) with the 10.25" Virtual Cockpit. The dash gets its map as video from the Columbus over the MOST fibre-optic link, which is why only Columbus cars can show a map in the cockpit. The open-source project mhi2_altscreen_carplay on GitHub feeds the CarPlay map into that same link instead. Its reference car is on exactly this firmware. It's been shown working in a real Škoda (Apple Maps, Google Maps, Waze), but it's developer-only for now: you need SSH access to the head unit and there's no SD-card installer yet. Anyone else on SKG13/MU 1440 looking at testing?
Fuel Gauge Sender is kaput- Does anyone have a part number?
In case anyone is interested in how this was resolved. I read that on the 4x4 saddle tank the secondary pickup on the LHS drains the left side of the fuel tank first, once that’s empty it drains the RHS. LHS is just a pickup & a float sensor while the RHS has a pump and another float sensor. The tank was only registering a drop in level after about 200 miles indicating it was the LHS that was at fault. So after a couple of false starts I sourced the correct parts. I got the RHS float sensor from Skoda for about £110, part number 3Q0-919-673-K, I figured I may as well change it at the same time. I could only get the whole LHS assembly, I picked one up on eBay for £100, part number 3Q0-919-098-B I also invested in a fuel pump ring removal tool which made life a lot easier than using a chisel to get the pumps out. LHS side first, I popped the pickup unit out and just unclipped the whole thing from the hose and replaced it with the new one. On the other side I just unclipped the float sensor, popped it out and replaced it making sure the wires were rerouted the same way. On opening up the suspect float sensor the pickups were very worn and was showing intermittent resistance so definitely where the fault was coming from. On the plus side the fuel gauge appears to be working properly again.
Exhaust Backbox
That would be very nice, I think thats why I haven't pulled the trigger on them as I do like the factory look, with the non gloss and fins not being anywhere else on the car. Let me know how much etc
Kamiq MY20 MIB3 Update
Hi everyone. If I update via USB—going from version 304 to 308 and then 330—will everything still work in the MySkoda app? Things like remote unlocking, vehicle location, and alarm notifications? Will I be able to log into my account and set myself as the primary user? And here’s a crucial point: what happens if I don't clear the SVM version compatibility error after the update (since I don't have the cable)? Google AI told me that remote functions wouldn't work due to a software version mismatch. What have your experiences been with the online account after a manual update? I have active Infotainment Online and Care Connect subscriptions, but I'm stuck with old software and an endless OTA update loop for three apps that’s been going on since June. Skoda wants to charge me for an update, even though they broke the system in the first place—which really infuriated me...
MarcinB24 started following Kamiq MY20 MIB3 Update
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
Seen by caffyns today. It needs a new part, which is one that needs the exhaust removing for access! Booked for 13th October. i will try to get a look at the removed part, and a photo if possible.
Shackleton started following Finally signed up
Finally signed up
Hi , after reading many forum entries on here I thought it would be better to join. I normally twirl spanners on motorcycles , not professionally, just a hobby. We are on our fourth Skoda , an Octavia but we also still have a 20 year old Fabia .
