  2. What about one of these... https://reversee.co.uk/
  3. This tempted me once. But as I have good relations with my dealer and the whole team. I thought it wouldn't be fair... I've kept my yellowish torch light.
  4. I think it should. Just have a look on ifinterface.com and compare the P/N of your own one and the P/N from a 2023 FL version (the latest manufactured Mk3).
  5. Sunset over Mordor? :)
  6. A total of 4 Abarth in this small car park; just a shame not enough spaces for the fourth to line up with these, and the third is parked nose in.
  7. You missed your opportunity when yours was in for the work!
  8. Today
  9. Just go to the dealer and do it whilst looking around a car….. hmmmm
  10. Also another thought. If it is OEM does it have a part number on it. I wonder if they can be bought from Skoda?!
  11. A few more from today. Sun was setting on the return journey so snapped some more.
  12. Very jealous. I came to the forums too late for @ApertureS to be doing the cool white upgrades. Was it from a newer Skoda? My father in law has a new enyaq, I wonder if I can swap it without him noticing…
  13. Got to try out my new boot light, fairly impressed It’s a direct replacement courtesy of a rental car, company played me about bit, so swapped my old warm looking rechargeable torch, that’ll teach em 😂
  14. Misty today.........
  15. The only proposed Duracell for mine is unfortunately too high and too short...
  16. Nothing over bumps. Just when releas and press aceleration pedal in low speed and low gears. Thank you for test
  17. No clunk in mine. Does it do it over bumps as well or just when picking the drive back up ?
  18. Rev limit approx 3K max is correct when out of gear.
  19. No idea, I've complained bitterly for years, and got nowhere. We used to have a company car scheme that was fantastic, but we were just punted out of it, given an allowance, and told to get on with it. No training regarding reclaiming scoreboard from HMRC or anything. Very poorly handled. But on the brighter side, they've said we need to be carbon neutral by 2030, so maybe an EV scheme on the horizon.
  20. How on earth do they get away with only giving you 13p per mile for Company use? ☹️
  21. I just bought a Duracell branded one as it comes with 4 year warranty. It’s a banner manufactured one relabelled. Might be a UK only brand perhaps. I went for highest Ah with longest warranty.
  22. Hi, If you only need the arm (without cap on the motor axle, part #4), it should be 3V5955707 (part #2) based on ifinterface.com data.
  23. I have the Patch The actual problem lies with the instrument cluster; there is a programming error in its EEPROM. Updating the 5F unit—the radio—was a customer-friendly workaround, but it does the job.
  24. My Favorites: Banner Varta Exide
  25. In that case, start by completely removing the door, which is a single 13mm nutlike thing at each hinge. Then release door checkstrap and electrical connector. Lift door off, preferably with an assistant (certainly when refitting). Then you have easy access to hinge parts on A-pillar. Fit new ones exactly over clean bit of paintwork that's currently hiding under the originals. Make sure you have the correct size bit for the screws that hold them on. Tx45?
  26. @Breezy_Pete cheers but I prefer to replace the worn ones, should see the car out 🙁 Less than £15 each
