  2. I've got Octavia from 2021. For some while I was disappointed because it wasn't a "go for a brand new one and visit dealer for maintantance issues only" experience. However after hearing stories about other brand new cars, looks like it's not that bad. Somehow people with new cars have way more problems nowadays. In overall it think that quality should be better. In the very beginning my battery discharged twice. First time I thought that it was my fault somehow but actually it wasn't. Some software didn't go to sleep and drained it. Dealer solved this. Then I had interior lighting issues (switched on/off on it's own). Windscreen wiper motor died. Some clutch pedal bearing (if i recall correctly). All this was annoying but it was solved. Then there were 2 major things: 1) Parking sensor fault. During wintertime these sensors didn't work at all. I believe that car thought the battery was not full enough or something like that. I visited dealer for several times and each time I had a useless update. Only after 4 (!!!!!) years it was solved. 2) Keyless system sucks. During summertime everything is mostly fine however during autumn/wintertime it often doesn't work at all. Sometimes it works, sometimes not. As I understood from the dealer, there are different handles and some are reliable but some not. That's my experience. What will be yours - who knows. Maybe these issues are yesterday and there are some new.
  3. TomRoadTrips joined the community
  4. DogBook replied to vRSG60's topic in Skoda Yeti
    That interesting as I read it exactly as the OP said, will they loose the Apple CarPlay? So going by what you say thats a simple yes then. Your reply says new patch, but what new patch? Is there an update with the clock fix that comes with Apple CarPlay or did you mean another patch?
  5. There are bound to be 1.4 tsi PHEV,s that did not get Fixed Regime oil changes. No reports I am aware of these engines in a PHEV having issues. Are you getting a warranty? As long as the warranty provider would not say 'not serviced to the manufacturers schedule, recommendations or advice '. Which is something Skoda UK does quite regularly.
  6. For anyone looking for covers for the DRLs once the lamp is replaced, the equivalent Hella part number appears to be 160184. Plenty of these available, used on Ebay at reasonable cost (55mm diameter).
  7. As far as coolant leaks it could be anywhere but if tank is emptying quickly its a fairly major leak so check inside of car front carpets arent wet (leaking heater matrix) Check around any radiator hoses you can see for signs of crystals(dried antifreeze) and also radiator itself. Could also be a failed waterpump but not sure where that is on your engine. If you fill it to max and park over dry garage or even cardboard it may help pinpoint where the leak is. All depends if its dripping straight down or running along a pipe etc. Quite often drops onto undertray and runs backwards. Also does it drop overnight or when left for 24hours without starting?and is there white smoke from exhaust when car running. Alasdair
  8. Thanks for the detailed feedback and the heads-up on the DQ400e transmission! That mechatronic filter/actuator issue is definitely good to keep in mind. Fortunately, I went through the official Škoda digital service records in detail, and the DSG fluid + filter replacement was carried out right on schedule at 61,677 km (along with the spark plugs). Given that it's sitting at ~105,000 km now, I plan on doing the next DSG service soon (around 115k–120k km) just to keep the mechatronic safe. Your routine on doing annual oil changes even with heavy EV usage makes total sense, and that’s exactly the maintenance schedule I’ll be sticking to (10k–12k km / 1 year max). Out of curiosity, are there any other 2020–2024 VAG PHEV owners here whose cars were also kept on the 30,000 km / 2-year flexible oil service interval from the factory / dealer network? I would be really interested to hear how the engines held up over time on that regime. Appreciate the advice!
  9. kostikas joined the community
  10. Today
  11. You mis-understand me. I mention the coolant tank draining quickly so you get the gist of the issue. I do not know and will not claim to know where the coolant is actually leaking from. I want to know if this has happened to others and where their leaks were sourced, so I get a rough idea of where to start looking, prior to taking it to a mechanic. I am not a mechanic and I don't expect anyone to diagnose my issue. Thank you for your helpful response. I will do that. Appreciated.
  12. I deleted the car from My Skoda app and the infotainment was reset to factory, in order to delete all user data.
  13. I'm not sure how any of that information responds to the question of which piece of hardware to buy - MX+, vs. OBDeleven gen3, vs. something else? thank you,
  14. Car key blade should be able to get a new one cut and fitted. Try an autolocksmith or timpsons. The handle you will get the part number off LLLparts under original manufacturer diagrams although there are some on Amazon (chinese) cheaper. Alasdair
  15. Rifleman, That’s very interesting. To be honest whilst I used ACC for the Mway journeys, I didn’t monitor the screen enough to see of this happened to me. No Mway journeys planned foe at least this month. I’ll try torember the next time ‘I hit the M4’ Thank for the very informative post 👍
  16. Long shot but oil filler cap seal/dipstick seal?? Alasdair
  17. My info, whist not disagreeing with yous has more info: Carista OBD2: Carista is fully compatible with the OBDLink MX+ hardware. It offers basic code clearing and simple, menu-driven customizations ("customizations" or adaptations). Note: Because your Superb is a late 2025 model, Carista's beta testers network is actively updating compatibility for Mk4 platform elements. [1, 2] The "Gold Standard" Alternative – OBDeleven 3: If your main goal is advanced custom coding, the OBDLink MX+ will face limitations on a 2025 Skoda due to VW's factory SFD2 firewall restrictions. The OBDeleven NextGen device is an officially licensed Volkswagen Group partner that has built-in tokens to automatically unlock SFD protections, making it the preferred tool for modifications and "One-Click Apps" on a June 2025 vehicle. It is AI generated, however it not been asked to make a decision other than show me the best options available today
  18. Salve volevo aggiornare firmware di sistema il software della radio Amundsen (unita MIB2) della mia Skoda Superb Executive 2016 mi potete aiutare ad avere delle informazioni al riguardo,grazie Hello, I wanted to update the system firmware of the Amundsen radio (MIB2 unit) of my Skoda Superb Executive 2016. Can you help me get some information about this, thanks. Salve, la lingua predefinita di questo sito è l'inglese. Sono disponibili strumenti di traduzione online. Grazie per la comprensione. Amministrazione di Briskoda Hi, the default language on this site is English. There are online translation tools available. Thanks for your understanding Briskoda Admin
  19. Fat@Vei started following Aggiornamento
  20. On my first Formentor (same engine and gearbox) there was a fixed service interval: 15.ooo km / 1 year. The facelift Formentor (same gearbox but the 1.5 TSI engine) came with a variable 30.ooo km / 2 years oil service. However, I did service the oil after 1 year and ~14.ooo km - less than half on ICE, since Monday-Friday I'm 100% EV. You should ask for the gearbox service history, since the DQ400e is well-known for it's mechatronic failure caused by an oil filter/mesh that fails and blocks one of the actuators. The 100k km "barrier" is quite often mentioned as higher risk mileage.
  21. SkOmk4 started following Long life servicing
  22. Fat@Vei joined the community
  23. DavidMTB joined the community
  24. You really need to find out where the coolant is leaking from, you can't just blame the reservoir for leaking unless you already can see that it is. Maybe include your engine type/code.
  25. Compression test next, just to establish that pistons/cylinders are okay.
  26. I had exactly the same problem as you when I bought my 2023 Superb 2 years ago. The dealer where I bought it (Sinclairs of Swasea) couldnt fix it and it had to be referred to Skoda Support, who came up with a solution, but it had to go back to the dealer. As we were selling our house and searching for a replacement in Lincoln at the time and we were then living in Brecon, which was nearly 50 miles away, we deferred it until we moved to Lincoln, where it was resolved by Hortons. You will probably need to take it to the dealer. Mine was done under the manufacturer's 3 year warranty, so I assume you'll be able to get them to fix it under the warranty you had with your car? One thing they couldn't fix is when I use a pin location on the map, it shows the address, then England, Deutschland. Also, traffication shows the traffic laws for Germany in this country. The dealer says a software update should fix this when Skoda issue one, but I'm sure I'll have to live with this until I sell the car. I'm not that bothered about it, but a relatively new car should have everything working correctly. When we went abroad in April and May, pin locations and traffic laws came up correctly in other countries as far afield as Lithuania with the traffication notifications working correctly.
  27. As far as I'm aware, the Skoda connect data is connected to you, and not the vehicle. If you weren't to reset your infotainment before you sold it, and the buyer didn't either when they bought it, then they'd probably benefit from it.
  28. @Day40 How did the injector replacement go?
  29. If you subscribe to the traffication app, you receive alerts to both fixed and mobile speed cameras. Well I do in the UK anyway
  30. scotthugh3s started following Route Data
  31. I'm On my second mk3 in last 6 years. Not found any problems other than the odd battery and sensor issues. Buying a used motor , same things need to be checked. ie, make sure it's been regularly serviced etc. I've been very happy with my 1.5 tsi SE L dsg estates. Good luck.
