  2. Just noticed it is face-lift model so more likely to have CR engine which is still a reliable engine.
  3. ok guys thought id let you know the fault came back again , it lasted about 2 weeks been messing since then with setting on actuator etc etc had every vac hose off again blah blah blah and the eventually vac tested my new oem n75 (valve which id peviously ruled out as it was 80 quid and not 12 quid on ebay ) and boom it was only letting 15 inches of mercury through at idle when it should be at least 20/22 or preferably more .it must have been just coping until certain conditions were met which i found to be more often than not low rpm in gear just letting the torque pull the car without any throttle input normally when crawling in traffic etc ,the boost should be max at this point but without the correct amount of vacuum it was reading the discrepancy between expected and actual boost on the actuator . i then bought another oem n75 and the car woke up ,boost bact at approx 1200rpm and not 2500 ish where it was when not in limp mode . anyway it was a big learing process(id never done a turbo actuator and set it up before but now can do with my eyes shut lol ) and the car now fixed at last .. i really hope somebody can get something out of the post if the same happens to them and they wont have to go down the same n75 rabbit hole as me,i wouldnt mind but i never bought a cheap one .just goes to show dont trust any parts without testing .. dave .. ps the n75 that was faulty was a meat and doria product from euro car parts which is billed as being equivalent oem .. it now has a pierburg n75 which is oem........
  4. Still ongoing issues so thought I'd put an update in. Took it to a garage to get a professional opinion. They swapped the sensor and then rewired the plug. All was good for a couple of days and then the light came back on and the air temp was reading 140 celsius this time, rather than -40/60 celsius previous. Took it back again and they swapped the sensor out again and took another look at the plug and then once again it was ok for another couple of days before the light came back on. Then the ECU light came on for fuel pressure, turns out the fuel rail came loose and pulled out the injectors apparently so I was peeing fuel all over the road. Managed to get it recovered and taken to the garage and they sorted out the fuel rail and once again replaced the sensor, this time with an original apparently and they were very confident that this time that it was all sorted. Now, once again the light has come back on. I've got to think at this point that the sensors themselves are not the problem but a symptom, something is killing them. I'm going to take it back to the same garage for this final time to see if they can find something other than just swapping out the sensor. My only thought would be that it's electrical and something is blowing the electronics in the sensors. Looking around some people are mentioning it could be a grounding issue or the battery may need to be changed, or disconnected from the car for 24 hours to reset the ECU. I'm kind of at a loss at this point and praying the garage can figure it out. Maybe the code is a red herring.
  5. Today I bought a 2016 1.4TDi DSG Spaceback SE. With 67,000 miles, MOT till Jan 27. Private seller. Previous owner for the last 5 years was an elderly lady. We agreed on a price of ยฃ3700 for it. One downside is that has 4 x assorted cheapo 215/45 R16 tyres on it. With the bigger downside being that they all have plenty of tread left. ๐Ÿ™„ It has parking damage to the rear bumper and front bumper. It's the sort of thing where I'll probably leave it as it is, as it's not going to rust and it doesn't look too tragically bad. The driver's side sun visor holder, the grey plastic swivel mount thing, next to the A pillar in the roof is cracked, and the sun visor fell off when I moved it to the side window position. It looks like it's an easy enough item to replace with a trim tool and a small flat bladed screwdriver. I have a feeling I might have to buy a whole sun visor assembly, instead of just the small plastic bit that clips into the roof? The sun visor works OK if you just fold it down for windscreen shading. The car drives fine. Feels and sounds nice and tight and unworn. As it should be on 67k miles. The driver's seat is pants. You can tell by looking at it that it's not shaped like a human body is shaped. And it's uncomfortable for any journey lasting longer than 30 minutes. I'm on the look-out for a pair of used SE Sport front seats. Or maybe the upper spec seats from a Toledo. I'm mildly disappointed with the MPG from my first 60 miles of ownership. It seems to be about on a par with my 2016 Superb Greenline Estate. Which is probably more down to how amazing the Superb Greenline is, than any failings in the Spaceback 1.4 TDi. I intend getting my local VAG specialist to do a cambelt and water pump change, sooner rather than later. And from there will do my own oil changes every 8,000 miles.
  6. I purchased my Karoq 1.5 DSG SE L at the end of July 2026. The car was pre registered on 31 March 2026 and I believe it was built in January 2026. Skoda Customer Services tell me it has what they call virtual pedal electric tailgate operation but I'm not at all sure. Easy Open is selected in the settings but I cannot get the tailgate to open using my foot. I have looked underneath the rear bumper for some sort of sensor but can't see anything. I can't get at a January 2026 brochure to check but I can see the virtual pedal is shown in the latest brochure. It could be that Customer Services are quoting from this brochure rather than the January 2026 one. I don't know if the virtual pedal was specd in the early 2026 brochure, I'm not doing something right or it simply doesn't work. Can anyone throw any light on this and if I'm not doing something right, where am I going wrong? Thanks.
  7. Today
  8. Iโ€™ve got an L&K and think thereโ€™s nothing wrong with adding cosmetic touches. Iโ€™ve removed the badges on the front wings and the Superb and 4x4 on the boot. Also have a Reiger rear diffuser in the pipeline - looks tasteful and subtle ๐Ÿ‘๐Ÿผ
  9. Iโ€™ve bought a set of B4s for the rear, but I havenโ€™t got around to fitting them - Iโ€™ve had them for more than six months ๐Ÿ™„ I really must fit them. Itโ€™s not a VRS, just a โ€˜normalโ€™ Octavia with a beam axle, but I find the ride a bit harsh.
  10. I did not touch air vent, only removed speakers mesh. It simply unclips, so slide thin trim tool in the gap and pull. If I remember correctly, to remove air vent you'd need to remove this mesh first, anyway.
  11. That was no passengers - only a full boot and roofbox. This is the empty height.
  12. vadim_dobryyy joined the community
  13. Simon21 joined the community
  14. Good choice as you can't beat an old school PD engine as with annual oil changes they run forever, I got rid of my PD140 at 200k and it was still running strong.
  15. No issues with infotainment so far with CarPlay disconnected.
  16. Thanks for the welcome. I'm sure I will have lots of questions in the next few weeks. It's a close run thing between the Superb and the E-class for boot space. They actually have the same 660ltr capacity but the Merc is slightly wider between the wheel arches and when looking for a car to accommodate my wife's mobility scooter every mm counts ๐Ÿ˜
  17. Try Kilen springs as i had good experience with them as you need ones specific to an estate as it sounds like you have either sport springs or saloon springs causing it to be too low.
  18. @Carlston might be able top assist with specs.
  19. Partly to have crisp handling, partly to replace 5 year old parts, partly to chase a creak: Superpro Front and rear droplinks ordered (the creak is front but thought I'd do the rears). Superpro LCAs (standard geometry with poly bushes), H&R front arb. Ordered Superpro but given they're on back order until October, I started hunting around for parts in the country. Whiteline, Superpro and Hardrace are all part of the same group and all on back order, APR/IE and 034 were also rare and the best part of ยฃ100 more, but found the H&R one as last in stock at Progressive Parts so happy with that. Given I'd also been lovetapped in the rear (which showed that the rear bumper had indeed been repaired with putty and resprayed) a replacement bumper has been ordered from a breakers in the same colour (needs a machine polish to tidy but I can do that) and to go with it is a Reiger diffuser on its way too. Will tidy and fit all that together when off the car and then put it on with @OccyVRS when the time comes. Coolant Vent Union also ordered but, obvs, Racingline version.
  20. 2.0 TDI CR 170 PS (125 kW) diesel, yes this is what has been explained to me that when they do the bench testing they cannot create the conditions under which it is failing. Auto Electrician has been asked by me many times if heโ€™s definitely checked everything and he says yes I can only go on what heโ€™s saying. At this point I either take the car back as it is donโ€™t fix it and get rid or I put two injectors into the group B which I think are injectors two and three, just unsure whether I should trust getting refurbished ones even though they come with a test sheet and 12 month warranty.
  21. Really stuck for answers with this one. I've owned the car for 11 years so I know its history. I'm having some issues with my 2.0 TDI 170PS DSG FWD Superb elegance estate rear suspension sitting too low with after market parts and wondered if anyone knows the correct dimensions or what the issue could be? 2 years ago the N/S rear was catching on some speed bumps with only myself in and 2 young kids. I had the car in the garage for repairs and while fixing them, a broken coil spring was noticed. This was replaced, but the the problem never fully went away. A month later work was completed on the O/S rear and again another coil spring was replaced and at the same time 2 rear arms and 4 wheel tracking. These were pattern parts from one of the local suppliers. The cars been catching ever since and having unloaded everything from the car recently, I could tell that the gap from rear tyre to the arch was far too low. I took the car to a different garage who put it up on the lift. We could see scuff marks to the underside of the newish rear arms, the fuel tank and the plastic covers that run down each side of the car. We noticed a failed shocker on the N/S and decided to book it in for replacement and while the springs are out, measure them and compare the dimensions against the ones stocked at the various local suppliers. The dimension is 368mm and the diameter of the springs on the car are the same as a new part. Skoda themselves won't provide a spring length and say that they only use a 3 colour coding system. We've ran various history and part checks with local after market stockists and all springs listed seem to be the same. This then turns my attention to the rear arms, as only the springs and arms have been replaced and the ones removed will have been the genuine ones from new. I can't buy a genuine Skoda rear arm, because they don't keep them for Superbs, and so if they order one I can't return it and they are ยฃ450 each. I'd normally say that springs determine ride height, but it feels like the after market arms could be the issue, but would they really throw out the rear ride height by an estimated 40 to 50mm? The fact that the arms have score marks to the underside indicates they are too low to the ground because spring length sets the vehicles ride height over the wheels and chassis. The arms can only sit lower if the geometry is different. The ones now installed have a slight camber to them and the mechanic thinks some can be straighter, so I've asked them to order a replacement pattern part to compare to whats on. The garage needs the car off the lift so it's going to have to be assembled on Monday regardless and I might still have the same issue. To summarise: I have 2 rear arms and 2 rear coil springs installed from 2 years ago and the cars now sitting too low. Currently replacing both rear shockers and damaged bump stops. If anyone has a genuine rear spring length and or colour code it would be helpful.
  22. P2149 is as far as I know is a failing injector or wiring fault. The injectors would probably have been tested when cold and could be failing when very hot or there is a wiring issue the autospark missed. What engine is in your mk2? Alasdair
  23. So just go carefully with whatever trim tool you have handy to remove the vent. That will probably get you a better chance to get the speaker cover off. Here's a picture of the clips under the grille you need to get at.
  24. It,s a simple test. Just to see what certain engine and DSG combinations do. Takes a few seconds to find out. Once the car has started and foot on brake chose D, look at the rev counter. Then choose S, does the RPM rise? With a Manual Hand Brake car with a DSG for Sprinting it is simply clever, hold the car on the parking brake not the footbrake. Accelerate in D or S on Manual 1st as you release the hand brake. You get a better acceleration. PS, Earlier DSG,s, some applications, 6 speed DQ250 only has 5 gears in S, DQ200 in a Twincharger vRS 7 speed DQ200 only 6 gears in S. Some of the first built would go into 7th at 127 mph in S. (If on Cruise Control & you change the gear selector to S from D as you are just driving it would show S7, or with a DQ250 S6.)
  25. Welcome to the forum. I thought the Superb was actually biggest in class for rear space.
  26. Another thing I would add is solid engine mounts are not the way to go! Itโ€™s a tad vibeyโ€ฆ
  27. Definitely you can accelerate as fast as you like and the gearbox will deal with it and you should just see the rev counter movements. The example i can think of when i have noticed the change as a jerk would be slowing down for say a roundabout and then you quickly come of the brake and hit the accelerator because it's clear and the gearbox has to go up instead of it's anticipated down. I never noticed the revs being higher whilst stationary idling in S or D, it just appeared to hold gears longer.
  28. When loaded with 3 kids and luggages for a whole week in the boot, my ex Superb Estate Mk3 rear axle also lowered by 1 to 1.5ยดยด. DCC doesnโ€™t change thisโ€ฆ
  2. Tap Permissions โ†’ Notifications.
