Autodoc - avoid!!!
I don't think the parts come from the UK, it's all from mainland Europe as far as I know. They just pretend to be local by using .co.uk web address. There was a very similar thread about a week ago, and will continue being more because their pricing is so enticing.
How-to Guide to Upgrade MIB2 to MIB2.5
Hmm I appear to be stuck. It’s on this screen with the new 9.2” screen plugged in but I press skip and nothing happens. Almost as it the touchscreen doesn’t work. I don’t know whether to turn it off or what! I’ve tried unplugging and replugging in the screen. Nothing. Any help? @Cairus ?
harmonic humming at motorway speeds
I put my money on a failing wheel bearing. MOT is just a safety inspection, so the drivetrain is not part of it.
Continuous Bearing rumble on 4wd , coasting in neutral
Update - It was actually the n/s front wheel bearing so thats a relief . Prob a lot cheaper than propshaft. Thanks all for your comments , Alan
Autodoc - avoid!!!
Just a heads up for anyone thinking to order anything from this company. If they send you wrong parts from UK you are supposed to return them to Germany and cover postage which is not refundable!!! There is no phone to call them or email unless they provide you with one and only way to speak to them is via their chat where if you don't reply within 3 minutes another person will take over and then whole chat clears after 3 hours so there is no trace. About 15 different employees told me different things each. Plus where i live ( channel islands) local post refused to accept my parcel due it's value ( apparently post only accpts up to £120 worth) so only option i had left was DHL which cost £189 to Germany for set of 4 springs. Bear in mind i paid £233 for springs with postage from UK. And return is fully covered by you and not refundable. So if i did that i would only be getting back £44 ( that's if they deem returned parts eligible for refund) So just a little warning before you give your hard earned cash to these people 👍🏻
Skoda Fabia mk4 2022 Lane Assist
I did my question on gpt chat, I rang auto electrician, who said he can remove the vibration on steering wheel by remembering last setting, it can be reversed, He even said vibration was strong and it pulls you back into lane.
Online Logbook - How to access?
Yes that's correct. 3 different garages but all official Skoda/VAG dealerships in Switzerland... I think I'm going to write to Skoda Switzerland directly... Drop a bit of heat on the dealership at the same time. Gabbo
Skoda superb mk2 2012 elegance columbus unit fail
OK. You can try to reflash it with the new firmware but it might be HW issue as well. I have just sent you download link in PM.
thamestrader started following Built in Sat Nav and Post Codes
For anyone else who uses the Build-In Sat Nav - I discovered today, after owning the Karoq for 30 months that destinations can be searched for with the Post Code. Just type it into the Search box. I like the Sat Nav - I know many do not, and this is great.
Wrong suspension springs -help
Yeah that's what i mean... On your picture above the Eibach is quite a bit shorter than original spring, what i received is almost identical length but wider diameter 🤔😣 Anyway I've opened a dispute with Autodoc because the way they handled this is ridiculous...
No quite right... estate springs still fit hatchback but don't lower as much on rear as specific spring for hatchback would as estate is slightly heavier. What i received is completely different rear axle spring.
Wanted: Octavia Mk1 VRs in yellow
Still after?..
Zander started following Wanted: Octavia Mk1 VRs in yellow
Hi there. Are you saying that your car has been exclusively serviced by Skoda? Just at 3 different dealerships? If this is the case then I cannot see any reason why any of the dealerships are unable to present you with a printout of the lifetime digital service history, as surely all of the Skoda workshop visits Should be stored on their system (I will caveat that by saying 'Back to 2016'), possbly slighly beyond then? The Independent VAG specialist who I've used for my Skodas also has access to and can/does record and recall all of the work which they've done in addition to being able to view details of all prior 'Recorded' Workshop visits. Maybe a Skoda Service Dept. Employee on here can chime in and correct me if/where I'm wrong. https://www.briskoda.net/forums/topic/512890-digital-service-history/ Please let us know how you get on.... Thanks
messed with fusses
thanks for reply,i was checking all fuses,...and fuse i didnt put in right place,so car wont start,(made mistake i didnt make picture of fuse box),so even more problems,probably best solution to call auto electrician or AA?
the truth about electric cars
I would have expected Tata to have already taken the rules of origin into account when they are alledged to have granted production space to Chery at their factory, and if such a thing ever takes place, it would surprise me that job creation would be minimal, as they are most likely to be built by JLRs own staff alongside their own cars. It will either way, all come out in the wash as my mum used to say. I know what you mean about the video, it certainly was not the most polished production at all, loads of AI imagary and the fact that he kept calling Bedford as Bedfordshire, which is not a town but a county, but hey ho, it is what it is.
- the truth about electric cars
'call me Dave' Cameron. The PM back in 2016. This is the stuff you get with films like this. Find pictures any pictures.- the truth about electric cars
Rules of origin are quite involved and if Chery are just screwing a few big bits together the cars will not count as UK origin and not entitled to go to European mainland without paying duty. I was auditing at our Hailwood warehouse as well as Midlands ones that supply Solihull and Wolverhampton and there is lots of non UK and non European major parts going into JLR cars but if this is a virtual whole Chinese kit being put together here in the UK, or in the Slovak JLR factories then the origin to have preferential status or even avoid penalties for being Chinese will be quite a calculation and planning. Did watch most of the video, did have a speculative feel about it. Hope we get some UK jobs from such operations. More interested to see how the £4B Tata battery factory in Somerset gets along. UK needs to be more proactive in customs duty so China, India etc are forced to add at least half the value of these cars in the UK IMO.- Soaked passenger footwells front and rear
Have you confirmed that the sunroof drains are running freely, to outside the car and cabin? As Warrior has said, the door seals were a known issue in early years - my then 2015 vRS was an affected car ( where the door seal prevented the doors from being able to drain properly). Gaz- the truth about electric cars
@lol-lol I take it that you never watched the video then? Nobody mentioned importing these Freelanders; the makers (Chery, 50% owned by Tata, who own JLR) are highly likely, as explained in the video, to be making these cars here in the UK, either at JLR or Nissan, where they already have agreements to make cars in those factories and our government is supposed to be in on the deal. This might well be total BS; only time will tell us which it is, but the Freelander is designed in the UK by staff employed by JLR at their design centre, so again, make of that what you will. I have long said that many of the vloggers are ahead of the game, as they cannot be told what they can and can't report on, unlike the mainstream news channels. As always, there are 2 sides to things, and one will be proven to be right at the end. It never hurts to be aware of the other side of things, does it? With Jaecoo being 50% Tata owned, then they will be still getting income from every Jaecoo sold and not having to build them and there is no denying that their sales are growing in the UK in all traction varients.- the truth about electric cars
Dont think that £37k includes the shipping cost or 10% customs duty on the import value ie item cost plus shipping and 10% of that total. Perhaps EU and UK need to whack Anti Dumping and or Countervailing duty on hybrids as well as EVs from China. Dont think that £37k includes the shipping cost or 10% customs duty on the import value ie item cost plus shipping and 10% of that total. Perhaps EU and UK need to whack Anti Dumping and or Countervailing duty on hybrids as well as EVs from China.- Soaked passenger footwells front and rear
Have you checked both rear doors to confirm they aren't full of rainwater? The drain holes in the lower seal can be prone to blockage, allowing the door cavity to fill, especially the LH rear door. Mine has never got to the point of flooding into the car itself, but there has been quite a lot of water inside the door on several occasions. I think I've seen mentions of there also being rear drains on the sunroof - have you checked for that?Warrior193 started following Soaked passenger footwells front and rearDadzadonkey joined the community- the truth about electric cars
Fancy a Freelander, electric with 818 hp for £37,000, complete with a 46" screen on the dashboard? Then you need to watch this video, and it also helps to explain just why and how the Jaecoo looks like a knock-off Range Rover.- Dealer Or No Dealer?
Look for an independent who specialises in VAG motors, there are some out there who can service your vehicle and update the service log just as the dealership wouldscotthugh3s started following Dealer Or No Dealer?- Wrong suspension springs -help
@MarioVrs your looks different to one which i installed on my previous FWD car - the truth about electric cars
