  2. Yeh, everyone I've spoken to agrees with you. I'll get that ordered today. I still have the front brakes to work on to keep me busy.
  3. paco replied to paco's topic in Skoda Karoq
    Thank you but I only use the satnav in this car very occasionally
  4. This is a classic, which has been the staple in all "mother factory" assemblies ... it has advantages and disadvantages, but in general the pattern is the same. Whether is Alfa Romeo to FIAT, Moto Guzzi to Piaggio, Skoda to VW, the "poor cousin" always gets to suffer šŸ™„
  5. Could be corrosion at terminals as said or its on its way out. I would clean and check condition feed and earth straps first. If that doesnt improve it I would replace starter. Got a febi one a few years back for my folks 1.9tdi and it was around £80 from parts in motion. Alasdair
  6. Rbz5416 replied to paco's topic in Skoda Karoq
    Buy a hardwire kit. https://www.briskoda.net/forums/topic/448233-dashcam-switched-power/
  7. Rbz5416 started following Sat Nav Lead
  8. paco posted a topic in Skoda Karoq
    Any clever people on hear who had a neat solution to attach the Satnav lead to the dash, I’m using a sticky substance at the moment but would prefer a neater option like a small clip ?
  9. The legal side might help when you go back. Your contract is with the dealer that sold you the car, not Skoda UK, so Skoda customer care saying it's down to Vertu is technically right. That's also where your rights sit. Under the Consumer Rights Act, when a dealer repairs a fault on goods they sold you, they have to do it within a reasonable time, without significant inconvenience to you, and at their cost (the Act says "any necessary costs", including labour and materials). It doesn't mention courtesy cars by name, so I wouldn't say for certain the £20 is unlawful. But you can reasonably argue that paying to be mobile while they fix their own fault is a cost of the repair, and being back a third time is the kind of inconvenience the Act is talking about. Put that in writing to the dealer principal rather than arguing at the desk. The bigger point is this. Under section 24, once a car has had one repair for a fault and still doesn't conform, you can ask for a price reduction or reject it (the final right to reject). As the squeak has come back after the first fix, you're already at that stage. On a car, rejecting at this stage can come with a deduction for the use you've had, but with a squeak you'd more likely go for a price reduction or a proper fix this time. The point is that it gives you leverage. As it's within 6 months of delivery, the fault is assumed to have been there from the start unless they can show otherwise. So I'd let them have the third go if you're happy to, but tell them in writing it's being repaired under the Consumer Rights Act, that you won't pay for the courtesy car, and that if it comes back again you'll be asking for a price reduction.
  10. Today
  11. Buy a new one... It'll cost you that in your labour time to fix it
  12. A GOOGLE-search on car dealerships charge for courtesy car will reveal that this has become 'normal practice'. A couple of the many several-years-old discussions on the subject: https://www.pistonheads.com/gassing/topic.asp?h=0&f=23&t=1996303 https://www.reddit.com/r/CarTalkUK/comments/yda1yd/why_have_garages_suddenly_started_charging_for/ (Since 2009 I've used a local Skoda dealership for servicing my cars. I've never needed a courtesy car, so I can't say whether they used to provide this free-of-charge but now no longer do so, but I do know that a free valet and wash used to be offered and became a charge-option some years back.)
  13. Debris or a leaf touching the heater fan. It is not a difficult task to remove (and clean its housing) the motor/fan from underneath the glove box. I am talking from a LHD perspective and do not know the RHD layout of the hvac system.
  14. @Wlad69 Hi, sorry to bring up an old thread. I have the same problem on my Yeti 5L 2015 (halogen, front fogs, BCM 1K0937087AN): I changed byte 18 and lost the original light config. Could you tell me which byte 18 calculator you found, and which value worked on your Yeti? It would help me a lot. Thank you!
  15. @langers2k @claudiu2s Hi both, I found your posts in ā€œBCM module in YETIā€ (2021): https://www.briskoda.net/forums/topic/488992-bcm-module-in-yeti/ You mentioned having Yeti light configs and VCP. My Yeti 5L 2015 (halogen, front fogs, headlight washers, BCM 1K0937087AN PQ35 M) lost its original light config after I changed byte 18. Could you share a halogen Yeti light config (.bcm1), or prepare one I could have written with VCP here in Italy? Happy to pay for your time. Thanks a lot!
  16. Thanks. Yes it's a pre-face lift 2016 model. Looks easy doesn't it. However, mine won't budge. The whole front bumper is flexing when I pull on the trim & both sides are not coming out. The cold weather is probably not helping (currently 1-2c on my driveway & raining hard) so I'm going to try & warm the trim up a bit with hair dryer / heat gun & use a thin plastic trim removal tool where those locating tabs are. I just don't want to break the tabs as the guy in this video did šŸ˜’
  17. edop84 joined the community
  18. +1 With the OEM setup, the only acceptable mode was Sport. With Bilstein B6 Damptronic + Eibach Pro springs, Normal became the new acceptable baseline, while Sport is now spot on." Since they share the same parts, I guess that decision comes from VW to keep the VW Group hierarchy.
  19. Hi all, I have a Skoda Yeti 5L 1.2 TSI (2015 facelift) with halogen headlights, front fog lights and headlight washers. BCM is 1K0937087AN (BCM PQ35 M). In March 2025 I changed byte 18 in module 09 with OBDeleven (wrote 01, then FF, then set it back to 00). Since then the original light config has been overwritten: front parking lights don’t work (faults 02394 and 02395, bulbs are fine) with the light switch at 0, the front left parking light stays on rear fog light switch turns on the front right parking light instead of the rear fogs left reverse light turns off when I switch on the parking lights The Skoda dealer already wrote the factory coding online, with no result. I know byte 18 was 00 from factory, so there is no ā€œcorrectā€ value to write. I’m looking for someone who can read the BCM light configuration with VCP from a Yeti with the same equipment (halogen + fogs, ideally same BCM part number or at least BCM PQ35 M) and share it, so my coder can write it back. Only the light config is needed, not the full BCM dump. Reading it doesn’t change anything on your car. PR code sticker attached. Any help or advice is much appreciated. Thanks! Nicolò (Italy)
  20. nicolo92 joined the community
  21. Hi all, I’ve got the "Error: cornering light (AFS)" warning on my 2016 Mk3 Octavia vRS (pre-facelift Bi-Xenons) and wondered if anyone local with VCDS or OBDeleven could scan Module 55 for me—happy to send some cash your way. Symptoms: All bulbs work fine (dipped, main, and lower cornering fogs) and the beam aim is level (it passed its MOT like this with no advisories). On startup, the left headlight does its full sweep/dance, but the right (offside) stays completely still. I’m no expert, so I ran the symptoms past Gemini - it suggested the rear level sensor is likely fine since the left side still moves, pointing instead to a dead offside AFS module (1T0941329B), a wiring issue, or a jammed internal swivel motor. We’re selling the car in a few months, so I want to understand the exact fault code before deciding whether to fix it or leave it as-is. It might be a long shot, given I’ve seen very few Octy VRS’ in the area, but is anyone around the area of Guiseley / LS20, willing and able to plug in for 5 minutes to help me? Happy to drive to you of course.. Thanks!
  22. @Colin170CR - assuming u have a pre-facelift mk3 Superb..... This is on my Superb MY17.
  23. I’m leaning to that way of thought. According to obd11 over time , the battery seems to be charged to it’s optimum that the car allows but i’ll try the Ctek to see what happens. 25000 equals to an average of 27 starts a day ( including start stop) . It’s probably worn out plates gone to mush. I think my extreme usage needs a AGM. My last car a 2017 Passat had a AGM. . With the same extreme usage i stretched that battery to 7 years and 200k.
  24. 75,000 miles and 25,000 starts sounds a bit extreme. I've no quarrel with the guys who recommend the CTEK charger but if you're using the car that much it really shouldn't be necessary. Personally I'd replace it with a decent brand of AGM in a diesel.(as you've got OBD11 you can code it yourself.) Tayna supplied the last one I fitted for about £120. BUT - at 2.5 years old isn't it under warranty ? Or is there a mileage limit on the warranty ? Battery on my then new 1.6 TDi was replaced under warranty at 2 years and 10 months - probably because it was already damaged from going flat in the showroom (ex demo) - still going several years later - but I'm not a high mileage user.
  25. Yesterday
  26. I didn't mention it before but yes I also initially brought another used sensor from eBay and that seemed to have a fault where it worked and then every few seconds it gave an error, sort of like it the internal uC was rebooting. The fact is that many people just list things as 'used' and don't actually know if the sensor works, at work we used to call this 'customer testing' which was not a good thing if you want to be seen as professional! Thank you for adding to the thread, hopefully this will make it easier for the next poor soul who has to go through this journey.
  27. BazzY started following Vertu unfair charges
  28. owaispro123 joined the community
  29. the port on the mirror housing had become dislodged and slipped inside. Car is booked into local dealer on friday to fix but probably won't use that port as i have a hard wiring kit for my dashcam (Viofo) (Dont know why this is underlined underlined is not elected.
  30. This appears to be standard practice, I paid £10 for one day a while back at a Skoda dealer ,,a friend of mine paid £25 recently at a Nissan dealer. Check out the cover on your own insurance - I'm with LV and it was covered the last time on that, but you need to show proof of that to the garage supplying the courtesy car. Good luck !
  31. Post a photo with the covers off please.
  32. The guy I sold to has a longstanding relationship with a local independent. He's legit. I know many people would have rolled up in the car and let the dealer take the hit but I'd rather be honest in how I do things.
  33. I would definitely want it again but Skoda really messed us with the settings on the Superb. Comfort - Massively too soft and crashes into bump stops if you are not careful. Normal - Still too soft, floaty and underdamped. Takes too long to settle with a secondary bounce. Sport. Now firm and very well damped but the soft springs allow for a fair amount of body movement in bends. There's also a fair amount of suspension noise which I wasn't expecting. Switch to a Passat of the same vintage and there's not the same suspension noise and Comfort and Normal are better controlled. So it seems a design choice by Skoda. I now have an Enyaq vRS with DCC and it's night and day different, so much so I thought it had to be from a different manufacturer. But checked and no still Monroe. The Mk3 Superb really needs that slider mod in the DCC. Somewhere between Normal and Sport would be the sweet spot for daily driving.
