2024 vRS infotainment rebooting issue
Over the last few weeks reboots. It’s the same kind of reboot as a forced one by holding the power button. It won’t do it for weeks and then it reappears. It’s on the latest software. If it reboots i have noticed that it does it about 20-30 seconds after starting the car. It never does it during a drive.
Columbus Map Update 2026-2027 (MIB2 HIGH)
Isn't it this post by Viper above ?... in old language it would be the November 2026 release but brought forwards due to streamlined processing. The November release was always coded to the following year hence this has 2027 on it. Then the June release Id expect to say 2027-2028 and hopefully that will turn up in February 2027. Everything is brought forward by 4 months now thanks to connected cars and the streamlining that was put in.
Fuse box not matching up with diagram
There is a lot more to this! The fuse arrangement for the rear wiper on my 2012 Mk 2 HB Octavia does not match any of the information provided in this forum. Here's what AI told me which eventually get me to the right answer: "On face-lifted 2012 Skoda Octavia Mk2 models, your rear wiper is actually controlled by Fuse 40 (a 10 Amp red fuse), rather than position 41. The official Skoda owner manuals for 2011–2013 cars frequently feature a misprint that incorrectly points to position 41. If you look into your slot 41, you will likely notice that it completely lacks the internal metal pins needed to hold a fuse in place, causing any fuse you try to insert to simply fall straight out. [1, 2] Check the row right next to it: The Correct 2012 Fuse Configuration Fuse 40: Rear Windscreen Wiper (Red 10A Fuse). Fuse 41: Empty / Not Assigned (No metal contact pins inside). Fuse 42: Rear Windscreen Washer Pump (White/Clear 15A or Blue 15A Fuse). [1, 2, 3]" But then, when I told AI that there is no fuse or fuse carrier in position 40, I got this: "On 2012 Skoda Octavia models utilizing the alternative interior layout, your rear windscreen wiper is powered by Fuse 18 (a 15 Amp blue fuse). [1, 2] Because Skoda completely overhauled the central electrical control unit during the late Mk2 face-lift production run, the fuse boxes on 2012 vehicles can vary wildly from what is printed in the car's original handbook. [1, 2] The Alternative 2012 Layout Locate Fuse 18 in your interior dashboard fuse panel: Fuse 18: Rear window wiper (Blue 15A Fuse)." This turned out to be correct for my car. (if only the sticker attached to the removable panel covering the dashboard fusebox had the correct info, instead of telling me the rear wiper fuse was in position 41. Nice one Skoda!) Note that on some variants, including mine, the washer pump is powered through the Body Control Module (BCM) and it doesn't have an individual fuse
RobertPalgrave started following Fuse box not matching up with diagram
Exhaust gas getting into the coolant
Can I post this picture, it's a still from the block test. Could anybody tell me if they think the lower chamber looks green or blue.
Thanks, I found my engine code on the V5C. It is CRM but what does that mean?
JD52 started following Improve VRS handling?
- Columbus Map Update 2026-2027 (MIB2 HIGH)
Unfortunately, they were a bit twisted back then, but that has since been corrected. But this is also very nice. 🤩
Throttle Body issue
I used to clean a 2005 Polo throttle body but I did it in situ, remove air cleaner, switch on ignition and put a "brick" on the accelerator, this will/should open the throttle valve fully to allow gentle cleaning of most of the throttle body, the revs used be on the high side after the clean for a few miles of driving but used to settle back down to normal. I have VCDS but never used it after cleaning. Your 2004 Fabia may have still had a cable operated throttle valve but the idling is/was still done electronically, the motor on these used to fail occasionally, I replaced them on a few friends 2000 Boras with used ones, again (and I didn't have VCDS then), idling speed would normalize after a few miles. Also, as suggested above......"check the brake servo vacuum hose for splits or cracks at the junctions of the hard plastic sections"
Johngerard started following Throttle Body issue
the truth about electric cars
I don't think many would want the early EV crap either, and with fewer than 100 units built, the C1 ev'ie was converted by the Electric Car Corporation, which was based in Bedford, so it could hardly be called an EV generation. In fairness, can it? Agreed; it's a hoorah on the hidden door handles, but it will be some time before all of them are replaced.
Link?
I am still having trouble convincing the garage i bought the Octavia from that exhaust gases are getting into the coolant. I provided a video of a block test but they say the fluid is still blue when it is green. Could I direct some views to the video to see what they think?
wnbVRS joined the community
Hi all, I have a 2017 VRS Hatch on 55000 miles and i've noticed the handling doesnt seem as good as it once was. It feels like the whole car is twisting from the middle when turning left or right and feels unsettled on bad roads. Ive had the tracking done and new tyres to the front, but that hasnt helped. Sometimes I get a creaking noise from the rear over bumps but thats it. Its never had any issues come up when being inspected or serviced. Does anyone have any advice or experience with this?
hifromrich started following Improve VRS handling?
Superb 3V3 tailgate struts - Beware Autodoc
A significant disadvantage of autodoc and its other companies masquerading as UK based with .co.uk addresses. Fine when the right parts are offered and delivered, PITA when not. Part number is very likely to be printed on your current struts. Use that - exactly, suffixes and all - to attempt to find aftermarket matches, autodoc may also be wrong about non-availability.
- Searching for the correct coding for 5F: Information Electronics after changing the sound settings with Car Scanner
Changing steering wheel
Hi, im struggling to find correct part number As my skoda is same a yours. Mines a 2014 Superb L and K
lonewolf26 started following Changing steering wheel
I'm a newbie Superb owner and felt my tailgate struts are not as efficient as they might be. Having entered Make, Model and Engine size as well as registration into both the AUTODOC site and app, I was presented with a long list of struts, all of which, I was informed, were suitable for the car. (You can see where this is going!). Ordered 2 x Stabilus 301171's which, on arrival, clearly did NOT fit. Challenged Autodoc who said I should have checked the VIN first with them by email - there is no guidance evident to do this and why would you, given the info they had and their site's confirmation of suitability. The upshot is that they reject any responsibility, offering to refund £44 cost but NOT my £9 postage. In addition I am required to spend £25 to return the items to Germany. When I gave them the VIN they advised they don't stock suitable struts as they are factory issue only - so why list umpteen struts as suitable? You'll see from the attached that my VIN details are actually held on the site in the second image and still the recommendations stand. My post is made purely as a warning if you are looking for Superb III struts on this site, do NOT take anything at face value. Highly UN-recommended. Apologies if this is in the wrong section or should not even be raised - I'll understand if Admin removes.
JacobSladder started following Superb 3V3 tailgate struts - Beware Autodoc
Throttle Body issue
what I read was exactly three mins so maybe critical and a low battery can cause all manner of spurious faults. Glad its back to normal for now and hope it stays that way. Worth scanning it anyway to see if theres any underlying problem. Alasdair
Throttle Body issue
Hi again, Okay, I left it on charger for the day and then disconnected battery and put the throttle body back in place. I then connected battery and did the 3 min with key on and it went through a bit more movement than it was last night. I then turned key back off and back on then started it. EPC light still on but limp mode gone. Drove it around a bit and EPC light stayed on. Got back to house shut it off and started it again and EPC light went off… no idea but seems to be fine. I still have the cord coming so will try and see if it gives any info when it comes but maybe a slightly low battery was causing issues? No idea what else it could have been. Thanks for the responses, always good to have someone responding when fighting through these things. Thanks, DDW
What wheels are these on a Mk3 Superb 2016
Hi all can anyone identify these wheels may not be Skoda but has VRS centre caps. They are on a 2016 Superb Estate.
Photography Thread
Got bored tidying the shed so went up floors castle this afternoon. Take a macro lens but wind was gusty so not much luck.
Dashboard set up 2023 Kodiaq Sportline
Just looked at a 2023 registered Kodiaq sportline, was trying to configure the dashboard to have rev counter to left and speedo dial to the right ...all traditional as it were fillowing test drive. Couldn't manage it, all i could have was largish central speedo with vaious ancillaries to left and right, is there more than one style of Electronic/virtual dash available as some photos clearly show it as possible? Apologies if this has been raised/answered before. Await a response, cheers.
DaveSkodaK started following Dashboard set up 2023 Kodiaq Sportline
DaveSkodaK joined the community
Superb 2 rear suspension sitting too low with new parts
If the car is too low, the springs are not stiff or long enough. That is a very clear explanation for the car hitting the end stops on speed bumps. You have a very common engine (2.0 TDI with DSG), so finding out the correct color code for your springs should be easy. Also, I do not understand your problem with skoda-parts.com. Simply make an account and add your car. If you have two Skoda's, make two accounts (with two different e-mail addresses). And regarding spring length: I already explained to you before that just measuring the free spring length is useless. You also have to compare the stiffness, which is determined by the wire diameter and the number of turns. But it all starts with the original specifications.
Automatic electronic handbrake
Thanks for the reply no other error light doors/ seatbelt appear to be working correctly. Doesn't appear to be a problem with the battery, it was replaced 6 months ago. I tried error checking with Carista and that came up with 8 errors.. I cleared them but 3 returned. 1 with the infotainment system 1 with telematics and 1 with the multi functional module I'm on holiday at the moment so further investigation when I get home
- HELP! Hot brake AFTER changing caliper and flexi-hoses
Rear Wiper Motor
It was indeed broken wiring between the the tailgate and vehicle body. You where spot on thanks so much.
