the truth about electric cars
On the topic of fuel prices and price gouging, there is a site dedicated to the price of fuel, and for those that are not aware of it, it is petrolprices.com
Makes my comments all the more pertinent.
Oil moving thru Hormuz is pretty much back to pre Gulf war levels but it is several other factors adding to the landed cost. Insurance premiums are sky high, millions of USD per trip for Persian Gulf and Red Sea. Egypt put up the Suez transit costs massively Some Suezmax ships circa 140 kt or less still choose to take the South Africa route rather than Suez. Cost and tome, time is money, mean even if flows are back to normal the additional elements are stacking up landed cost. Saudi is reportedly going to discount crude picked up from Damman ie East coast ports to encourage tankers to go there. With strategic reserves at such a low and winter coming up fast some tough decesions and bidding will occur.
Nemo55 started following Skoda Superb Mk3 (2015 - 2023)
A prime example of how the lack of forethought and planning will always bite you on the bum is because we have numpties running the show who, through their process of chasing an idealistic dream and goal, have clearly demonstrated that no matter how noble the end goal is, you must always plan for the worst-case scenario. Part of that planning is in decommissioning the wells in the North Sea. For those that were supplying Grangemouth, we failed to put in place an agreement with those countries that we granted licences to for the extraction of oil that we, the UK, should have an automatic access to the finished product in sufficient quantities, alongside the countries doing the extraction and processing, at market rates. If the US can ban the export of finished products, so can other countries, and if that happened, we would be up **** creek without a paddle, and that includes all of those with EVs, as we still need access to oil, and that will always be the case, and about 99.9% of everything that we all take foregranted in the shops, hospitals, DIY sheds, etc., all got there via roads and using diesel. On the other hand, common sense might suddenly spring back to life, and the illegal war be stopped, and everything return to normal again, about the same sort of chance as winning the jackpot on the lottery. This could well turn out to be the perfect storm and could be far more catastrophic than the problem of climate change, even though everyone is actually living a longer life than our predecessors ever did.
Cracking prices. Use to be ASDA as well guaranteed to be several pence cheaper but now only Cosco and a few independent ones substantially cheaper. They say there is no cartel but it looks like one with a few garages actually breaking out with higher prices not lower ones. Looking forward to a trip to Cosco with one of the kids who has a car though they are the ones who have just change main vehicle from Caddy to Buzz but they also have a petrol Fabia and Toyota 2+2 cars so only started tge transition today.
- Octavia MK4 Eletric Tailgate Retrofit
Exhausts
Dragging this back up @MartiniB did you cut just before the start of the down turn and then fitted the trims to that?
Discussion on US diesel export ban gathering pace but US apply pressure on those European countries with large strategic reserves ie other than UK's meagre 42 day reserve of course. 12 hours away from VAT coming off home electricity so these two factors accelerating the transition to electric from fossil fuel.
Map Update
After 5 days maps are still 26.2. Anyone else got problems with offline update via USB 26.2 ->26.6? Tried formatting usb stick (KingstonDatatraveler 70 , 64GB usbC) on another laptop (exFAT, default allocation size, partition is MBR), nothing happens. My system info: (O4 2020 First edition) Part number: 5E3035816F Hardware: H56 software: 1989 Display unit: H44, 2088 Navigation database: 26.2 My previous update went without problems with same USB flash drive, from 23.11 to 26.2, but my infotainment was 1806. Two months ago dealership updated my OCU firmware and infotainment to 1989 because I couldn't become primary user. Right now I have Care Connect and Infotainment online trial versions.
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
Subject: Software update request for Kamiq Bolero (654035869B / SW 0464).
Subject: Hi. I’m hoping you might be able to help me source the latest firmware files and update instructions for the Bolero infotainment system in my Skoda Kamiq. I am currently experiencing frequent, random SmartLink (CarPlay/Android Auto) connection drops—sometimes it connects flawlessly, and other times it refuses to connect at all. Here are my current system details from the Service menu: Device part number: 654035869B Hardware: 040 Software: 0464 System Type: Panasonic MIB3 Any help or links to the correct software train updates to stabilize this unit would be greatly appreciated! Thank you so much for your time and for everything you do for the forum community. Best regards, [Your Name/Username]
jnuevo13 joined the community
When will Epiq be in showrooms.
Thanks for that link. If they have in the UK now, I'll wait to hear from my dealer as to when they will be in to look at.
Issues with Mk 4 1.5 TSI
I agree with this, I have recently changed the battery on my 1.5 due to getting lots of random electoral errors, I bought one of these Yuasa YBX7027 Amazon Link if you don't have an OBD or are not technically minded, Amazon do offer a £50 fitting service from RAC that includes the coding.
Error: selector lever...
Same message I had. I was in France and the temperature was high 30s I have used OBD11 to enable me to see oil, coolant an gearbox temperatures, with the latter often in the 90s. The fault message however appeared when the car was started from cold.
CarlinKit Wireless carplay connected to USB in armrest Superb 3, controls fail when returning to the car after a short while
Hi there, I use a Carlinkit AIR2 wireless carplay kit for my Skoda Superb 3, for 2 reasons: Handy not having to get my phone out of my pocket. But more importantly: My wife still has a lightning connector and I have USB-C, to connect to the car. The Carlinkit basically does its job. But in the scenario of stepping out of the car and returning after a short while, the phone does connect to wireless carplay, but the controls, both touch screen and buttons on the steering wheel, wont work. I have to unplug the CarlinKit and plug it back in to make it work. Updating the firmware of the CarlinKit did not make a difference. What I found is that it could be related that the power stays on the USB port for quite some time. Ideally the USB power is cut off the moment I open the driver door (which is when the Columbus system switches itself off anyway.) But I havent found a way of achieving this. An ugly solution would be a USB cable with power switch, but it takes aways the effortless carplay experience. Do others have this problem and did anyone find a fix?
Long term lurker - about time I joined
Hi Giles and welcome, not to far away from you in Gloucestershire.
minsy started following Long term lurker - about time I joined
Skoda News
Skoda News when Skoda get around to making an announcement. In the EU/Europe-UK. Maybe even RECALL vehicles that might be affected by contacting Registered Keepers.
Skoda News
25 years of the Superb Škoda StoryboardKing of space and long-distance travel: Škoda Superb cele...The modern Škoda Superb has been on the market for 25 years. A symbol of comfort, spaciousness and technical sophistication, it has won over almost 1.8 million customers and continues to attract new o
DieselMonte's 2012 Monte Carlo Project. (175hp 6 speed swapped)
Twin sports cats look to have come a bit loose 😸 Gaz
Overlanding (Skodalanding?)
Whilst I'm not currently planning a trans-continental adventure, I like the equipment available for these trips because of the efficient use of space and aesthetics. The suppliers that I've found for both internal and external storage tend to have kit designed for a limited list of vehicles - that doesn't include any Skodas. Does anyone know of anywhere that already supplies equipment for a Kodiaq? I have seen some companies that offer make bespoke kit, but that understandably comes at a greater cost and involves visiting them for measurements and fitting, often at a greatbdistance from home (Poland or northern Italy anyone?). I'm particularly looking for boot shelves and roof racks similar to those below - an AI image of a roof rack on my Kodiaq and a screenshot of a low-cost Chinese supplier of internal storage solutions.
Sammycarp started following Overlanding (Skodalanding?)
Suspension upgrade installed
Fronts have been fine for squealing but the rear started to after a while - not getting enough heat in them. The rears on the 280s are a little oversized for the balance and the pads would glaze. Some enthusiastic braking would sort it but I wasn't about to stand the car on its nose a few times every other time I went out in the car. Went back to standard pads and all was fine. They're not R90 certified and I wonder if actually the DS Performance are more appropriate for road; lower dust, better cold bite - designed to work in the more appropriate operating window so less likely to glaze from under-use.
