Past hour
Škoda Approved Used – should outstanding scheduled maintenance have been completed before sale?
Update on my Approved Used Octavia vRS – VAQ service, outstanding maintenance and Start/Stop Just wanted to give everyone an update and thank those who have offered advice so far. I've continued corresponding with the sales manager at Škoda North Wales regarding the servicing that appears to have been outstanding when I purchased the car under the Approved Used programme. Following several emails, they've now offered to reimburse the £199 cost of the VAQ front differential oil service as a gesture of goodwill, which I've accepted. However, they're still declining to cover the spark plugs (£140) and engine air filter (£55). I've gone through the independent Pro Tyre service invoices individually. Interestingly, there's a section for air-filter replacement on the paperwork, but it hasn't been ticked on any of the invoices. I also can't find any mention of the spark plugs having been replaced. The dealership maintains that its technicians considered the previous service documentation, Škoda's internal systems and the condition of the components when deciding what work was required. I've asked them to explain exactly what evidence they relied upon, particularly given that item 115 on the Approved Used inspection checklist was marked R (Requires Further Attention). This is the item stating that all serviceable items due within six months have been completed and the service history brought up to date. I'm still waiting for a response to those questions. Regarding the Start/Stop issue: The sales manager explained that the N/A recorded against the Start/Stop check on the inspection report was a technician's error and that it should have been marked as checked. Apparently, no relevant faults were recorded. However, the system still isn't operating as expected. I've now booked the car into Škoda Worthing for Tuesday 24 November for a Start/Stop investigation and battery health check. I'm also planning to have the VAQ service completed at the same appointment, subject to confirming the reimbursement arrangements with North Wales. For now, I've decided to hold off on the spark plugs and air filter while the discussion continues. I may ultimately get my trusted independent mechanic to do those jobs if the dealership won't contribute. I'm also considering raising the matter formally with Škoda UK, mainly because I'd like clarification of what the Approved Used preparation standards actually require, rather than simply arguing over the remaining £195. I'll update the thread once I've heard back from the dealership and have the results of the Start/Stop investigation. Thanks again to everyone who's contributed. The advice has been really helpful.
Rainworth Motors Ltd - Mansfield..
Bought a new Kamiq from Rain worth Skoda this year, brilliant dealership and recommend them.
[Octavia vRS 245 - 2019] Constant whistling noise under the rear seat when warm — Fuel pump?
Hi everyone, I could not find any topic covering this specific diagnosis so here is my first real post here! Looking for some real-world feedback before I order a replacement part for my 2019 Octavia vRS 245 (2.0 TSI 245hp, 129,000 km / ~80k miles, DKTB engine code). The issue: Once the car is fully up to operating temperature, there is a constant, fairly high-pitched whistling noise coming clearly from the rear (under the back seat / fuel tank area). Aside from the noise, the car runs great: no warning lights, no misfires, and it starts right up both cold and warm. What I've checked so far: A mechanic listened to the noise and agrees it's likely the low-pressure fuel pump (LPFP) inside the tank. I ran a few checks with OBDeleven showing the pump is working hard constantly (~70% duty cycle at idle, 85-90% under load), while everything else on the engine side (fuel rail pressure, fuel trims, EVAP purge valve) looks completely healthy. The underside of the fuel tank feels completely cool to the touch. Before I go ahead and swap in a new Bosch fuel pump unit, has anyone else experienced this exact symptom on their vRS (or a Golf GTI / Leon Cupra from the same generation)? Did replacing the pump permanently fix the whistling, or is there anything else around the tank worth checking (tank breather/ventilation, fuel pump control module, etc.)? Thanks in advance for any insights! Cheers, AD
Hi to all
Hi to all ! I'm the new owner of a 2019 Skoda Octavia vRS, 2.0TSI DKTB engine with 130'000km. I might post or participate in topics in relation to this car for any mechanical insight and help or regarding modifications and upgrades. I hope that I'll be able to share my experience and be helpful in any way. See you around !
MMX23 joined the community
L&K Front Fog light Bulb access?
I do notice the on/off when cornering lights come on at low speed is all or nothing and its noticeable, but I can't say that it bothers me per se. I prefer the white light on/off over the yellow light dimming. Down to personal preference.
piotr1_1 joined the community
ScrapMyCarUk joined the community
- Bixenon Headlights auto-adjustment problem
Today
maxpage joined the community
Thermostat Pipe O Ring
O ring purchased 👍
Ah didn’t think so, I quite like the dimming
Software Update available for Bolero?
Hi guys, My radio was stressing me so I bit the bullet. These were my steps... (0742 maybe not needed but I did it anyway) 0463 → 0469 → 0741 → 0742 → 1790 → 1798 → 1800 Radio seems to be working ok, my wifes car so I haven't spent mych time in it. Looks good and works with my phone now. Massive thanks the everyone on here who helped but especially to the tech-savvy heroes who risked their own radios, that first upgrade is the hardest!
Bonnet support clip come away
Can anybody do me a favour and take a picture from underneath the yellow clip, I’m wondering if there is some type of washer on the underside.
Considering getting rid of my 2020 SE L in favour of a 2023 VRS...
A few things I'd look at on that one specifically, as a diesel auto vRS is quite a different car to a manual petrol SE L. 1. Warranty. Skoda's standard warranty is 3 years, but the third year has a 60,000 mile cap and it all ends three years from first registration. On a 2023 car there may only be months left, or it may already have ended, so check the registration date and ask exactly what cover comes with it. 2. Gearbox. The 200PS diesel's 7-speed DSG is the wet clutch type (DQ381), which has a fluid change in the schedule. VW Group's UK trade guidance puts it at 80,000 miles for that gearbox, so at low miles it won't be due yet, but ask the dealer to confirm the gearbox from the VIN and to show the service history on Skoda's own records rather than just stamps in a book. 3. Your driving. Think honestly about how many short trips you do. The Mk4 handbook says that if the particulate filter light comes on, you clean it by driving with the engine warm at 60 km/h or more with the revs at 2,000 or above, and if the light hasn't gone out within 40 minutes it hasn't worked and needs a garage. If most of your driving is short local runs, a diesel may not suit you however good the car is. 4. It uses AdBlue, which you top up yourself between services, so factor that in. 5. If you buy from a dealer, you've got 30 days to reject it if something is wrong, and for the first 6 months a fault is assumed to have been there when you bought it unless they can show otherwise. So use those first weeks to test everything, including the DSG from cold and in stop start traffic.
Heater Matrix Flush??
Is it possible to get to pipes that feed matrix from engine bay. Remove them from engine/coolant system and flush through with garden hose leaving matrix in situ? Alasdair
Alasdair1 started following Heater Matrix Flush??
- Vrs rear banjo bolt sizing
AKK joined the community
Skoda Rapid Radiator fan not working
What does your temperature gauge read in day to day driving it should be around 90c , is your thermostat working, can the fan be run bypassing the normal connection.
- Facelift Crystal Style taillights in the VFL
The two signals are just for the animation. You would, of course, need to wire your headlights to match the facelift version. As far as I know, the BCM supports this. I haven’t wired it up myself, as I personally feel the animation is pointless—though perhaps I’ll get around to it when I retrofit the LED headlights.
Pro1 started following Facelift Crystal Style taillights in the VFL
Suspect engine oil leak
https://www.briskoda.net/forums/topic/531352-petes-rescue-roomster/page/2/ Manifold valve shown in a post about one third of the way down page 2. But read first bit with diagrams to get an overview.
My car Skoda Rapid 2013 just overheated a bit, and complained about oil pressure, I newer hears my fan spin.. So I think this could help me.. Are you able to maybe support me in my srarch for the problem?
Claus@DK started following Skoda Rapid Radiator fan not working
Ciux23 joined the community
Top mount
It may be the spring that's broken too and taken the top mount with it. This is what happened on mine. I got a garage to do mine as I needed it done quickly, but I think it’s relatively straightforward if you’ve got the tools. You either have to split the hub from drive shaft to take the strut out or compress the spring in situ to remove the bottom end of the strut from the lower control arm. I have the workshop manual I can share with you if you require it. It would be a good opportunity to fit lowering springs/sport struts/coilovers etc etc 😃 Really good guide here:
- DataPlug app (trip log & refuel detection) – looking for Android testers
Yesterday
Fabiaidan joined the community
Skoda Superb Combi 3V539Z suspencion
Build code L08 means they are 5Q0411105GN front springs. According to Sachs this front spring has length 318mm and wire diameter 12.5mm. Build codes 1JA+0YE means they are 3Q0511115M rear springs. According to Sachs this rear spring has length 360mm and wire diameter 12.75mm. Kilen/Lesjofors list a front spring sold to replace 5Q0411105HS for the VW Passat B8 Alltrack. KYB sells a front spring to replace 5Q0411105HS with a 326mm length and a 13mm wire diameter. Kilen/Lesjofors list a rear spring sold to replace 3Q0511115AT for the VW Passat B8 Alltrack. KYB sells a rear spring to replace 3Q0511115AT with a 364mm length and a 13.75mm wire diameter. Although 326mm is only 8mm longer than 318mm, the 0.5mm increase in wire diameter should mean that the 5Q0411105HS front spring increases the front unladen ride height by about 15mm. Although 364mm is only 4mm longer than 360mm, the 1.00mm increase in wire diameter should mean that the 3Q0511115AT rear spring increases the rear unladen ride height by about 15mm. Conclusion: 5Q0411105HS front springs and 3Q0511115AT rear springs should give the car about 15mm of increased ride height and provide a much needed increase in stiffness.
Wiper blades for 2022 Karoq
I’ve also used Bosch aerotwin on other cars too, including Skoda Octavia & Fabia, & had trouble with fitting on one & ended up going to the local dealer for wipers & couldn’t get the twin pack to work & had to get two individual blades, I seem to remember that they have part numbers on the blades which I’ll have to look at
Our 2016 Vrs TDI came with an AGM battery as standard and we never had any issues, our 2019 Kodiaq came with an EFB which died after 3 years, replaced with a Yuasa AGM, recoded with OBDELEVEN all working perfectly. Our new Scala also came with EFB which had to be replaced after 3 months under warranty the replacement lasted another 3 months. Turned out the ECU was somehow killing the batteries. ECU replaced under warranty and a new AGM battery fitted all good after that. Think it's a bit of pot luck with the quality of some of the batteries Skoda fit as standard.
The car in question is diesel and an automatic, as opposed to my manual petrol SE L. If I was to go for it, it would be the first time I'd ever owned a diesel car in 30 years of driving, and the first auto I'd ever owned too. Just wondering for those with experience, if there's anything in particular I should look out for or be wary of? It's a fairly low mileage example with a supposed full service history, so in theory everything should be in good shape... Although as we all know, when it comes to the Mk4 any kind of theorem is little more than just a guess Appreciate any input, it's just an idea at present but interested in people's thoughts
