Alasdair1 started following MOT success again
MOT success again
Just got my sons MK1 1.2htp through another MOT. Did front swing arms and console bushes. plus a few other ball joints while I was at it. Only advisories this year are front nearside tyre worn on edge and a slightly loose wing mirror glass. Not bad for a twenty year old car. Tyre is worn probably due to front bushes being shot plus had a slow puncture so may have been run soft. Will get alignment checked and maybe a new tyre. Very happy plus so is my son. He even got me a nice bottle of single malt as a thankyou. Thanks to Pete for advice on console bolts etc. Alasdair
MIB3 map update
I formatted the 2 pen drive in the two different ways (exfat & ntfs) just in case; dunno why none of the format worked out! I also thought I didn't have to put ALL the extracted folders in the root but it didn't work too! I unzipped with 7zip and Winzip but the result didn't change! I tried everytime with exfat pen one day and another with ntfs but nothing!
MIB3 map update
Exfat is the one you should be using and only just put one stick in. It may work with ntfs but exfat is the standard designed for. @MartiniB did have issues at one point, so too another. Those are on the map threads. I seem to recall they rolled back the map updates but you need to check. Early Cupra firmware had an issue I know that. Built in windows 11 unzip is the one to use. Drag and drop out the set of files into the route directory. There should be no other files on the blank drive. Don't use a mac, if you do use cleanmydrive or similar. Dusts of the mac junk.
From Amundsen to Columbus: mission almost accomplished!
I solved the problem and now everything works; what I don't understand is why system, everytime I start the car, asks me to migrate to 334 (I actually have the 330), 334 which I heard is not still very stable as the 330. Is there a way to disable this popup? @Cairus or @East_Yorkshire_Retrofits : can You help me?
My ŠKODA App - Send Route
I tried here in Rome (Italy) and it worked fine!
MIB3 map update
I formatted a pendrive as EXFAT and another as NTFS; copied the folders directly in the root and connected (one at once) on front LEFT usbc port to update the mpas with the maps latest version (26.6) and leave the pen inserted for one day each but maps do not update! How can I do?
Power boot lid issues.
Hi. I'm having some intermittent issues that may be related to the boot lid not being detected as closed.? It's a power boot lid on an Scout Estate. Yesterday when I locked my car via the remote, the indicators flashed every couple of seconds, and the boot open warning flashed up on the dash. Today, locking works ok, but the rear wiper has stopped working. I assume the wiper does not function when the boot is open. Has anyone had these issues and fixed them, please? Scan results. 19-CAN Gateway -- Status: Malfunction 0010 1 Fault Found: 131619 - Control Module for Rear Lid Electronics U1047 00 [008] - No Communication [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 246 Mileage: 125218 km Date: 2026.10.25 Time: 15:31:28 Terminal 30 power supply: 12.5 V Terminal 15: OFF
happyscout started following Power boot lid issues.
brotato joined the community
- Activating SmartLink on Swing 3
Looking for free VW Group vehicle databases, VIN data and APIs for my app
Hi everyone! I'm currently developing my own automotive application for Volkswagen Group vehicles (VW, Audi, Skoda, SEAT and CUPRA). I'm trying to find free or open-source databases, APIs or other resources that provide reliable vehicle information. I'm particularly interested in: VIN decoding and vehicle identification Factory equipment and PR codes Engine codes and vehicle specifications OEM part numbers and compatibility Service and maintenance information Diagnostic data and ECU information Does anyone know where I could find this kind of data for free? Maybe there are some public databases, GitHub projects, open-source tools or APIs that I haven't discovered yet. I'm especially interested in data that can legally be used in my own application. If anyone has experience working with VW Group vehicle data or knows where developers can obtain it, I'd really appreciate any advice! Thanks in advance for your help! P.S. I accidentally posted my previous question in Polish and couldn't edit it. Sorry for the duplicate!
First test drive
I tested the Epiq (and the Peaq) on a drive from Munich to AUstria (Seefeld) and then back again. I am serioulsy thinking of replacing my Enyaq with an Epiq 55. Here's the video I made of the drive from Munich to Seefeld. https://youtu.be/1rWut1ialGM
Centre front arm rest
Dragging this up, do you need to have the correct BCM for this to work for a normal USB in the centre arm rest? With my step down being ripped apart by Skoda when doing my warranty work they have offered to pay for the parts etc so was wondering if I could go factory with this rather than factory USB socket in the arm rest and then step down (5v/12V) from the rear cig lighter to the usb.
tombee started following Centre front arm rest
Adaptive grille ahutter
While that will happen, Skoda's stated reason for having fitted adaptive cooling shutters to the Fabia when the Mk4 version was introduced in 2021 was (as I highlighted in my posting of October 17 above) to improve the car's aerodynamics and reduce its fuel consumption - the same reason for Skoda fitting 'aero' trims to some Fabia Mk 4 wheels. My late-2023-built Fabia Mk4 SE L car's standard specification included the aero wheel trims, but the trims were dropped from the specification for the following model-year. My car does not have the cooling shutters and, apparently, neither does the 2025 Monte Carlo Fabia owned by @Alvin600 This May 2026 article compares the Skoda Fabia Mk4 with the Mazda 2 https://carvago.com/articles/car-battle/mazda-2-vs-skoda-fabia Active cooling shutters are mentioned in the "Aerodynamics and innovation" section of the Fabia review, but I suspect that this is an assumption based on Skoda's press releases rather than the reviewer knowing it to be true. (Perhaps @BACUPIAN could check if his Fabia has the shutters?)
1.0 TSI manual: difficult to pull away smoothly
Today, I dropped off my Fabia (1.0 TSI – 110 PS, DLAA engine, 6-speed manual) for its scheduled 4-year service, even though the mileage is quite low at 35,000 km. I had noticed that, quite often, the car struggled to pull away smoothly and gently when applying a little throttle, but I didn't consider it a significant enough issue to address. So, taking the opportunity today, I mentioned it to the technician. He performed a few short test starts inside the workshop and suggested that there might be an issue with the clutch slave cylinder. He’s going to verify this, and if that is indeed the case, it will be replaced under warranty. Once I get the car back, I’ll provide an update on whether a replacement was actually necessary and if that was, in fact, the root cause of the problem.
fabiamk4man started following 1.0 TSI manual: difficult to pull away smoothly
Hello all, I've managed to activate smartlink, thanks for sharing all the steps. Now I have another problem, maybe someone else has a solution. connecting the phone with cable, all good, androind auto is working, no problems there. when I try to connect a wireless adapter in the car's USB port, connects with the infotainment, but when I pair the adapter with my phone via bluetooth, the infotainment gives a USB error end keeps resetting. It could be that the cars's USB port is low on amperage and keeps getting errors? Any advice or suggestions would be greatly appreciated. Thanks
hebi123 joined the community
No fluid in hybrid coolant header tank
Just take it to an Skoda/VW independant, it'll be a lot cheaper
Enabling extended tail light/drl (combi)
Hi! It’s still working perfectly! No error codes or anything like that!
Manoeuvre Braking
I experienced this neck-whiplash inducing emergency braking several times before I learned to manage it and now I only rarely encounter it. To my experience the trick is to constantly have some pressure on brake pedal and this prevents the emergency braking. If you let go the brake pedal even momentarily the car is going to take over. In my 265hp 4x4 the reverse gear is too tall anyway so I really do not mind reversing with constant brake application so that the clutch is slipping during the whole reversing motion and the car moves slower. I keep auto-hold enabled all the time but start reversing from so far away that slight blip on the loud pedal is not a problem. The same trick works also driving forward preventing the annoying collision alarm. If there is some car turning to side road and it would otherwise cause big beep you can prevent this by applying some constant slight brake pedal yourself the whole time when distance to this turning car shortens but because you are braking the car thinks you have situation under control.
JuSko started following Manoeuvre Braking
I need Bolero Update :-)
I have never heard about such firmware. Moreover, I have never found installation files for any newer software than MST2_EU_SK_P0359T. The solution you can use is to: Patch swdownload to enable installation of different firmware. Install VW firmware MST2_EU_VW_P0480T (metainfo2.txt must be adjusted to enable installation on your unit). Install patch to enable VW FEC/SWaP codes. Enable VW FEC/SWaP codes. Install modifed SKODA HMI.
Thank you!
Enyaq 85 sel 2026 tyre pressures
Where is my oil light!?
Back in 1991 when my mk2 Golf was built it had two pressure switches, one that covered the bottom end of the rpm spectrum, the other covered everything above that. I think some recent Skoda engines have gone back to having multiple switches, but only because oil pressure is being actively controlled to minimise wasted pumping effort. So that needs monitoring to know if the control system has failed.
- Where is my oil light!?
Hello @Krisz-III-FL ! I am looking for a solution for my 2018 Skoda-Superb and I have read here what you achieved. I will Try also on mine. How did your solution go so far? Thank you !
Thank you so much! Donated
Michal319 joined the community
