  2. The rivets are N 91078801 and are 6.4 x 10mm. I got a two handed rivet gun to do my sons when the regulator totaled itself. Got them on ebay for around £10 for 10. Put part number into search and a few should ping up. Make sure your not paying a fortune for just one rivet! Alasdair
  3. Is the 2023 Superb MK3 2.0TSI 272PS 4x4 a hatchback or estate? Does the car have standard ride height suspension or lowered ride height suspension? Does the car have DCC (electronic damping control) shock absorbers? When it comes to the springs, the front springs are the same on both the hatchback and estate, when all other things are equal...but the rear springs are usually a little stiffer on the estate compared to the equivalent hatchback. Lowered ride height suspension is also known as sports suspension. Lowered ride height suspension has a nominal 15mm lower ride height compared to standard ride height suspension. On the Superb MK3, the springs on the lowered ride suspension are about the same stiffness as the springs on the standard ride height suspension. Hence, even lowered ride height cars have soft suspension. Bilstein B6 shock absorbers are for use with standard ride height springs, and Bilstein B8 shock absorbers are for use with lowered ride height springs. The main difference between Bilstein B6 shock absorbers and Bilstein B8 shock absorbers is that the Bilstein B8 shock absorbers are about 20mm shorter than the Bilstein B6 shock absorbers. Bilstein B6 shock absorbers (Superb MK3) (without DCC) (standard ride height) Front 35-229872 Rear 24-229890 Bilstein B8 shock absorbers (Superb MK3) (without DCC) (lowered ride height) Front 35-229919 Rear 24-229937
  4. Legend88 joined the community
  5. Wondered if anyone could recommend a discrete dash cam for an elroq. But nervous because the 5V charger is in the boot and seemed complicated to install?
  6. HaleImp started following Dashcams on Elroq
  7. HaleImp joined the community
  8. Skomaz - thanks for replying and for the suggestion. I've put some clear tape all the way along the join of the glass and plastic body of the headlight and so will see what happens. The dust cap seals both seem fine and from what I can see, there aren't any cracks or hairline fractures anywhere in the headlight. So puzzling and annoying as on a dry sunny day the condensation disappears within a couple of hours and it's evident there isn't any collection of water and so it seems to be a breather type issue rather than a cracked or damaged headlight. Typically the MOT is due in January and so the condensation is usually worse than ever. Last year they failed it but then cleared it with compressed air but I'm desparate to get to the bottom of the issue as I'm not so sure they'll be so understanding this year. Thanks again.
  9. Yes, I unmount every connector in the panel and was the main light switch (the one lighting in the picture above). It seems a bit burned on the other side.
  10. Today
  11. Update on this. Rear donk solved. Bottom droplink bolt on the passenger side wasn't tight (the one bottom right of the 2nd pic). Jacked up the hub so all under load and torqued it up properly. Checked the other side which was ok. As I jacked the hub up and compressed the spring, there was the donk sound but I tried it a couple of times and couldn't see what was moving to make the sound. Did the same after the work was done and silent. Test drive was silent too. Spring looked fine sat in the cup and looked fine under compression so not sure what was up. One thing sorted. Work booked for end of next week - helicoil my dogbone mess, front arb switched to H&R, front topmounts, check the wheel speed sensors then 4wa and hopefully that's it...
  12. I was sitting in the warranty managers office reading Skoda's reply to him with attachments from the ombudsman supporting the VW group's stance. They were recent rejections so VW have probably come up with a more robust "excuse" for not coughing up which the ombudsman now agrees with. Missing inspection reports weren't mentioned, purely the location. If it can be rubbed or collect dirt causing corrosion it's a no. He reconned if it was just the small bubble about a half inch into the panel it would have probably been ok but as you can see a small area where the edge of the rubber filler surround meets the bodywork they've decided it is "edge and fold". As you say it's cobblers. My only real option is the ombudsman which I have started but they quote a 6 month wait before they'll even look at it but it appears they'll side with VW anyway. I may have to bite the bullet and get it sorted myself.
  13. It is necessary to drill out the rivets to get to almost everything in the door such as replacing the window winder or door lock - both have been done on mine. The window winder is mounted on that metal panel so you also have to be aware of how to connect and disconnect the glass. It is shown in the Haynes manual. The rivets are a large and non standard size but are easily available from motor factors who stock VAG parts. You may need a larger rivet gun than a diy tool. It may be better to pay a garage for 1 hour of labour. I used an auto electrician as they do this all the time on VAG cars but local garages may not have any experience.
  14. The only relay I can think of is R7 (X-contact), which powers wipers, headlights and other power hungry devices. It's also connected to the BE connector mentioned earlier. But it's driven by the ignition switch, so it can be either the switch or the relay.
  15. Has anyone with a mk4 DSG upgraded their shifter switch from the cheap plastic one to somewthing like this? Black Forest IndustriesMK8 GS2 Air Leather (VW MQB Evo Auto/DSG)Get rid of your "chicken nugget" shifter and replace it with an actual knob! Since the introduction of the MK8 Golf platform, Volkswagen's choice of control surfaces has been a sore spot for many owne Would love to see what one looked like installed on a VRS mk4 DSG , shame they don't do a VRS badged version to match the car. They are designed for the Golf mk8 but should fit an octavia, how hard to install one and what will it look like? They do different colour options.
  16. oajh23 joined the community
  17. Can u plz send me MSTD_EU_SK_P6230? cant find it on internet
  18. IlyaKud joined the community
  19. http://briskoda.net/forums/topic/528055-successful-warranty-claim
  20. JonEm joined the community
  21. It is cobblers. Not specified anyplace & whoever came up with the tripe needs to show where they come up with this. Skoda have covered nothing, they are at it. Have you seen the Final Decisions of the Ombudsman in writing concerning other claims. There are those that have successfully made claims under the warranty on exactly the same corrosion issue in exactly the same location on the car.
  22. I now have a reason for the claim being rejected. It is corrosion caused by "edge and fold" not from the middle of a panel; if corrosion starts inside on a seam or edge it's tough. Sounds like cobblers to me and not specified in the warranty. I have also now discovered this has been the reason quoted to the motoring ombudsman which they have accepted and then rejected customer appeals. Seems Skoda have covered their backsides and have the ombudsman on their side.
  23. Skoda or whoever is telling this nonsense should know that there are vehicles out there that they failed to engineer into the 'Normal operational noise'. Where is this person based and are they an Automotive Engineer or a desk jokey?
  24. Haldex is at 3 years / 30,000 miles. So i would be wanting it done know as well as the Brake Fluid change if not done in the past 2 years. As far as the DSG i would want that now and the Warranty covering it. Not left till 80,000 miles.
  25. worth a shot. On mine it overboosted and randomly you just heard a very slight blow off sound. Almost like a blip of a siren in the distance then loss of power. Alasdair
  26. Szaki joined the community
  27. From MOT history up until 2022 was doing roughly 10k miles per year, from 2022 yearly mileage is roughly 7k per year, suggesting either a change in circumstances or change of owner. Modern diesels don't like low annual mileages, and the last 4 years between 5k and 8k per year is low, whilst DPF may be OK the EGR valves are prone to clogging with short journeys or low annual mileages, a more likely issue is Ad Blue problems due to crystalisation on the sensors and injector due to low use. Haldex is every 3 years - its nearly due again. more importantly is what were the dates of the previous Haldex services, should have had one in 2021. DSG ask for the oil to be changed and the oil filter to be cleaned - Skoda say every 80k miles - independent specialists advise 40k. Engine oil and filter changes - ideally every 12 months or 10k miles which ever is sooner, consider carefully if the vehicle has been on the Flexible service scheme which extends the intervals to 20k miles or 2 years, so should have had 8 service may only have had 3 or possibly 4. Brake fluid and Coolant should have been changed at least twice if they haven't been done then ask for then to be done. Check the rear tyres for uneven tread wear or an odd wear pattern, assuming the tyres have not been replaced - at around 80K miles the the rear suspension lower arm bushes may have worn - not enough to be an MOT advisory but sufficient to cause uneven tread wear. Cambelt ask for it to be changed along with any other rubber belts (the oil pump is driven by a separate wet belt) , tensioner and water pump if applicable. If they don't want to do this then ask for a warranty to cover the cambelt for the next 50,000 miles. If you are familiar with DSG gearboxes then you will know what it should drive like. If you are not familiar have a really long test drive with lots of stop start traffic, leave the Stop/Start switched ON - even if you don't like it this can expose issues with the DSG. Check Hill Hold and Auto Hold work properly without and with throttle. It should creep smoothly on tickover even up a slight incline in first and reverse.
  28. Isn't that also known as 'running a business'?
  29. zoe1981 joined the community
  30. Try a factory reset of the infotainment & it should prompt you to set up from scratch. It's a PITA though as you'll lose all your setting, including radio stations & stored destinations in the SatNav. As for the secret solution sent to a dealer, I went through this recently for a different issue & the "fix" didn't work. At least it was covered by warranty. I wouldn't entertain writing the blank cheque being suggested to you.
  31. Skoda dealers are all mercenaries - extract as much as possible from owners seems to be their main aim………
  32. superpatate joined the community
  33. Ja56 joined the community
  34. mr_simon joined the community
  35. Hi everyone! I’m new here, and following this thread with interest. My late-2024 1.5 MHEV (non-DCC) has the same hollow knocking noise. After numerous visits with various attempts to resolve the issue (including changing the top mounts and applying copious amounts of grease to the potential problem areas), the Skoda workshop replaced my steering rack. Like everyone here, the issue was only temporarily resolved, with the knocking sound returning after 2 weeks. Skoda is now saying that this is a ‘normal operational noise’. The Skoda dealership where I’m based (Singapore) is directly owned by the Volkswagen Group. I’d have expected much better technical competence and ability to rectify faults, but that is not the case at all!
  36. For some reason the infotainment system started asking for a pin number. I couldn’t remember it and after 3 attempts I got locked out. Now I get the message no primary user. After trying numerous times to become primary user and following numerous hints on the internet I am no further forward. Every time I start the car I get an email saying that Skoda Connect services are deactivated as the vehicle is in private mode. Even though It is actually set to share my position. I contacted Skoda and was told that they have an update to solve the problems if I book the car into the dealer and let them know who the dealer is they will send an update to that dealer to sort out the problem. I visited the dealer to ask how much this would cost and was told that they would charge an initial Diagnostic charge of £185 plus a charge per hour for doing the update. As they don’t know how long the update would take they couldn’t give me a final cost. I have complained that the cost is extortionate to correct a problem with poorly written software that 100s of people all over the world are complaining about. I am hoping that the OTA update 0334 might solve the problems but there are conflicting reports on whether you only get the update if the car has a primary user registered. I am currently running version 0332.Any advice please.
  37. moley replied to Lee01's topic in Motoring News
    Skoda boss on his way to Volvo. AutocarSkoda boss Klaus Zellmer named as new CEO of Volvo | AutocarVW Group lifer Zellmer will take over from long-serving Hakan Samuelsson by this time next year
  38. If the ignition switch was fully switching off, I think it a little unlikely that an earth (mass) cable issue would be the cause. I suppose a welded-closed relay contact could be the cause if the ignition switch tests out as Ok - but I'd be testing that switch first.
